  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • bjornhallbergB
    bjornhallbergB
    bjornhallberg
    Hmmm. I got the 5.5V DC varistor from another AliExpress seller and I'm a bit puzzled as to why it starts smoking after a few seconds. Tried several of them. The HLK gives a solid 5V output. I'm assuming I got some lower voltage varistors by mistake?
    m26872M 1 Reply Last reply
    • S shabba
      So the regulator needs swapping about and the BOM cap values are incorrect from post (http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board/37) above that states :::
      C1 100nF capacitor
      C2 100uF capacitor
      C3 4.7uF capacitor
      AWIA
      AWIA
      AWI
      @shabba Right... if you look at the schematics upload-a10f80dc-0eda-4c4b-aa49-e0bbc6f827a8 you can see that the two capacitors can be swapped without consequences
      S 1 Reply Last reply
        m26872M
        m26872M
        m26872
        @bjornhallberg Maybe I've missed reading something, but why use a varistor for 5 Vdc and not a zener diode?
        • AWIA AWI
          shabba
          @AWI Thanks! Very true!
          • m26872M m26872
            bjornhallbergB
            bjornhallbergB
            bjornhallberg
            @m26872 You're probably right, I just followed the BOM. I'll see if I can stock up on some diodes from AliExpress for future use.
            • korttomaK
              korttomaK
              korttoma
              #116
              Whould a 5.1V zener work?
              edit: removed the link to the product so that no one would buy it the specs of it is to tight to be used with HLK.
              • Tomas
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Just a stupid question, the "G3MB-202P DC-AC PCB SSR In 5VDC,Out 240V AC 2A " What happens if I forget and plug something more power-hungry like a toaster or a microwave-owen? does any of the fuses blow or does the relay break ?
                • korttomaK
                  korttomaK
                  korttoma
                  there is no fuse on the relay switch so I guess either the PCB or the relay will fail.
                  • Tomas
                  • m26872M
                    m26872M
                    m26872
                    I've seen commercial products with a thermal fuse glued to the switching side of the relay. Maybe that would help some in such situation.
                    • korttomaK korttoma
                      m26872M
                      m26872M
                      m26872
                      wrote on last edited by m26872
                      #120
                      @korttoma A 5.1V zener is probably too tight. The HLK seems rated 5+/-0.2V.
                      • m26872M m26872
                        bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        @m26872 Indeed, mine is 5.08V (with no load). I ordered some 5.1V and 5.6V 1206 SMD diodes from Ali for future use. Plus some 3.6V. And a set of DIP diodes.
                        rvendrameR 1 Reply Last reply
                          rvendrameR
                          rvendrameR
                          rvendrame
                          Just to remember, the typical zeners are 1W , which gives a max of 200mA of output capacity, pretty enough for Arduino+radio, but maybe not enough for many relays / Leds etc. And if they burn due overload, they will allow all voltage/current flowing from PSU into arduino.
                          That explains why we suggested the varistor, in order to short the PSU output and trigger its internal protection. Strange that your varistors didn't survive... Bad lot? Maybe they are not 5.5V as stated?
                          ESP8266 GW + mySensors 2.3.2
                          Alexa / Google Home
                          • rvendrameR rvendrame
                            m26872M
                            m26872M
                            m26872
                            @rvendrame
                            No.
                            The zener will only lead current during over voltage condition and only needs to dissapate enough energy till one of your (multiple?) over current protection trips. Just as your varistor setup is supposed to work.
                            • m26872M m26872
                              @rvendrame
                              No.
                              rvendrameR
                              rvendrameR
                              rvendrame
                              @m26872 , is it also true in case the PSU itself fail? And what happens if the circuit consumes more current than zener rating? I'm my (poor) knowledge, zeners are more relevant for stabilization, while varistor are effective 'protection' devices...
                              Alexa / Google Home
                              • M mvdarend
                                I spoke too soon... the unit seems to work well, but I hadn't tested if the relay actually switched or not. The status seems to change fine in the serial monitor, but it doesn't seem to be actually switching. I'll have to do some more troubleshooting.
                                shabba
                                @mvdarend You discover your issue with the relay?
                                  m26872M
                                  m26872M
                                  m26872
                                  @rvendrame
                                  since we're discussing the PSU secondary side (output side), I think we already presume errors with the PSU. A fuse (over current protection) on the secondary is not just there as a back-up if the PSU internal over current protection fails. The fuse will also prevent your over voltage protection (zener, varistor, ...) from overload/burn/start a fire.
                                  The current from PSU to load will not pass through the zener and hence the rating is irrelevant from that perspective. In other applications where a zener is used as voltage regulator, the full load current will pass through the zener when in idleing and then the rating is critical.
                                  korttomaK 1 Reply Last reply
                                  • m26872M m26872
                                    @rvendrame
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    @m26872 so how do we need to rate the zener? Should the zener be rated so that the fuse will blow before the zener brakes from the current it passes due to an over voltage situation? Or is it OK that the zener brakes to as long as it takes out the fuse first. Then an automatic fuse will no longer work.
                                    • Tomas
                                    • S shabba
                                      mvdarend
                                      Sorry, since that post I tried a few small things. But then I got caught up in other projects/work/family :) and haven't had time time to look into it further.
                                        m26872M
                                        m26872M
                                        m26872
                                        #129
                                        @korttoma Good questions. As always a trade-off of risk, cost, space, taste, etc. They should already be answered in the varistor case though. Personally I think it's overkill with additional overvoltage protection at the low volt secondary side of a good quality PSU and an inexpensive load - fuse, capacitors and regulators should be more than enough. Focus should be the primary side protections.
                                        Edit: Btw. Found some reading. See p.44
                                        • bjornhallbergB
                                          bjornhallbergB
                                          bjornhallberg
                                          Just a quick post to confirm I got the relays working as well (with Domoticz). I didn't read the schematic at first and just assumed how the mains and relay external wiring should be done. Still no idea about the smoking varistor.
