  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 346.1k Views 68 Watching
  • sundberg84S
    You could connect the regular switch like a binary button, for example between D3 and Grd. The node could monitor both incoming messages from the controller and the state on D3.
    • n3roN
      n3roN
      n3ro
      i hope i can buy this board in the near future =)
      pimatic + MySensors + Homeduino + z-way
      https://github.com/n3roGit/MySensors_n3ro
      • zrom69Z
        zrom69Z
        zrom69
        Hello
        I'm putting a home automation system I want to put in the cabinet
        electric power supply to power pc wholes my Arduino pro mini cable this method and these can be well card she could withstand power pc. thank you in advance for aid
        • RJ_MakeR RJ_Make
          @korttoma Say what...? You measure .4 ohms on your Varistor? I think you found your problem. :angry:
          I have only ever used Varistor protection on the primary side, so I've got no experience with low voltage Varistors, but I don't think it should ever read .4.. Should be infinite.
          korttomaK
          korttomaK
          korttoma
          I how received a new batch from another seller and these varistors show infinite resistance, unfortunately they are 0603 footprint so they are really tiny.
          I bet the other seller (Unionup Electronic Mall) just sent me random crap because all of them show 0 resistance at first and then increase to 0.4 ohms, to bad it is too late to open dispute now. Just stay clear of Unionup Electronic Mall in the future.
          • Tomas
          RJ_MakeR 1 Reply Last reply
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            #145
            is it the brown or blue varistors that is defective?
            Edit: sorry the brown ones are fuses
            korttomaK 1 Reply Last reply
              korttomaK
              korttomaK
              korttoma
              @Cliff-Karlsson the 5.5V SMD varistors I recieved from Aliexpress seller "Unionup Electronic Mall" do not work for me. Now running my circuit with out it instead.
              • Tomas
              • korttomaK korttoma
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @korttoma Thanks for the heads up on Unionup.
                RJ_Make
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  I don't have any ceramic capacitors. Can I replace them with regualr ones?
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    Nevermind the capacitor question I found some ceramic capacitors now. But Is the "BOM" that shows component placement in the beginning of the thread accurate? only the transistor needs to be turned around?
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      @bjornhallberg said:
                      @m26872 You're probably right, I just followed the BOM. I'll see if I
                      I think the first post should be edited with the right components. In the doc it says
                      100nF + 100pF Capacitors 0.02 Euro AliExpress Link
                      but in the post is says:C2 100uF capacitor
                      I have a couple of 100uF 16v but I guess that wont work, correct?
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Sorry for spamming but regarding fuse 2. Can someone post a link to a fuse that works well. I got alot of those brown PTC fuses but the holes in the PCB are too small. I tried drilling them up but then I got no contact so I had to solder a separate separate wire from 5v to the fuse to get any power to the arduino and the rest of the components.
                        Or has there been a mistake on my PCB with too small holes for fuse 2?
                          korttomaK
                          korttomaK
                          korttoma
                          #152
                          @Cliff-Karlsson the holes for Fuse2 are to smal and this has been mentioned a few times before in this thread. I drilled mine out with a 0.8mm drill and could then use the recommended fuse without any extra wires.
                          • Tomas
                          • T
                            tomkxy
                            Since the 5.5V varistor is not available from the linked AliExpress shop I wonder whether this varistor would work as well?
                            https://www.conrad.de/de/smd-varistor-we-vs-82537040-4-v-wuerth-elektronik-we-vs-82537040-1-st-1086820.html
                            • zrom69Z
                              zrom69Z
                              zrom69
                              greeted everyone
                              look what concerns island link tests on this HLK-PM01
                              http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
                              • S
                                sebas
                                A question about the fuses. The BOM in the Word document links to two 230V fuses, the PTC and slow blow fuse. If I read the schematic correctly one fuse is on the AC side and one is on the DC side. How does a 230V fuse help on the DC side where there should not be more than 5Vdc? Or am I missing something? As I'm quite new to this I'm probably not reading the schematic correctly or missing something :-)
                                • A aproxx
                                  For those who wanted to see some pictures of the board:
                                  IMG_20150921_194059 (Small).jpg IMG_20150921_194039 (Small).jpg IMG_20150921_194035 (Small).jpg IMG_20150921_194023 (Small).jpg IMG_20150921_192748 (Small).jpg IMG_20150921_192737 (Small).jpg IMG_20150921_192728 (Small).jpg
                                  Small notice: These pictures are of a slightly older design. The newer design has a few minor changes like better component placement and a permanent fuse instead of this resettable fuse. But these pictures should at least give you an idea on how everything looks like, and shows how really small it actually is.
                                  Also, I reinforced the traces of the 230v lines, which I absolutely recommend to do! (Although I do recommend to do it slightly more professional than I did on this prototype :))
                                  the cosmic gateT
                                  the cosmic gateT
                                  the cosmic gate
                                  I really like this design, but it would be even nicer when this fits a ESP8266 :) Maybe the PCB could be even smaller . And it works together with link text .
                                  So is there maybe one of the PCB designer guys who can build /draw / design this 230v to ESP8266 PCB ?
                                  There's more than meets the eye
                                  • Michel - ItM
                                    Michel - ItM
                                    Michel - It
                                    WOW, REALLY GREAT JOB!
                                    • B
                                      B
                                      Brijesh Mishra
                                      Hello everyone,
                                      This is a gr8 project, i am looking forward to make few sensor for my home. As i don't have any experience with electronics and very new to all these terms and components.
                                      I would request anyone of you to, kindly post some pictures of the board with components in place that i can copy and make my boards.
                                      **Specially 3 pin regulator and Capacitors **
                                      My first assembled board is not working, it looks like m doing something wrong with either the capacitors or the regulator. I checked my NRF24l01 VCC pin and not getting any voltage at all.
                                      Please help me guys......
                                      Thanks and Regards
                                      Brij
                                      • B Brijesh Mishra
                                        Hello everyone,
                                        Thanks and Regards
                                        Brij
                                        @the-cosmic-gate has already posted images above.
                                        Perhaps you should post a picture of what you've done?
                                        • B
                                          B
                                          Brijesh Mishra
                                          Thanks a lot for your response, this is what i have done so far.
