  3. Rain Guage
Rain Guage
128 Posts 23 Posters 157.4k Views 21 Watching
  • FrancoisF
    FrancoisF
    Francois
    @BulldogLowell I also busy building an rain gauge. How is your one performing? Now did you set this up in the arduino? How did you do the calculation?
    Regards
    Francois
    • FrancoisF Francois
      Regards
      Francois
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Francois
      yes is working still, I mentioned how I did the math above...
      • FrancoisF
        FrancoisF
        Francois
        wrote on last edited by Francois
        #23
        @BulldogLowell do you mind sharing the sketch I not seeing in this forum or on the Build pages of MySensor.org
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @Francois
          Sure, but I have that running at my 'other' house and it is on older version of MySensors (haven't upgraded there yet ;)
          I'll take a whack at updating if you like... it needs to get done anyway... here it is:
           Arduino Tipping Bucket Rain Gauge
           June 15, 2014
           Version 1.00b
           Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
           gateway you can measure and sense local rain.  This sketch will create two devices on your
           Vera controller.  One will display your total precipitation for the last 24, 48, 72, 96 and 120
           hours.  The other, a sensor that changes state if there is recent rain (up to last 120 hours)
           above a threshold.  Both these settings are user definable.
           This sketch features the following:
           * Allows you to set the rain threshold in mm
           * Allows you to determine the interval window up to 120 hours.
           * Displays the last 24, 48, 72, 96 and 120 hours total rain in Variable1 through Variable5
             of the Rain Sensor device
           * Configuration changes to Sensor device updated every 3 hours.
           * SHould run on any Arduino
           * Will retain Tripped/Not Tripped status and data in a power outage, saving small ammount
             of data to EEPROM (Circular Buffer to maximize life of EEBPROM
           * There is a unique setup requirement necessary in order to properly present the Vera device
             variables.  The details are outlined in the sketch below.
           * LED status indicator
           by BulldogLowell@gmail.com for free public use
          #include <EEPROM.h>
          #include <RF24.h>
          #include <Sensor.h>
          #define STATE_LOCATION 513 // stay away from EEPROM used with Sensor.h
          #define EEPROM_BUFFER 514  // location of the EEPROM circular buffer
          #define BUFFER_LENGTH 121
          Sensor gw;
          boolean metric = false;
          int eepromIndex;
          int tipSensorPin = 3;
          int ledPin = 5; //PWM capable required
          unsigned long dataMillis;
          unsigned long serialInterval = 10000UL;
          const unsigned long oneHour = 60000UL;
          unsigned long lastTipTime;
          unsigned long lastBucketInterval;
          unsigned long startMillis;
          int dayBuckets [5] [2] = {
           { V_VAR1, 24 },
           { V_VAR2, 48 },
           { V_VAR3, 72 },
           { V_VAR4, 96 },
           { V_VAR5, 120},
          volatile byte rainBucket [120] ; // 5 days of data
          const unsigned long calibrateFactor = 1UL; //Calibration in milimeters of rain per single tip
          unsigned long rainRate = 0;
          float currentRain = 0;
          boolean wasTipped = false;
          boolean updateVera;
          int rainCount;
          volatile int tipBuffer = 0;
          byte rainWindow = 72;//default rain window in hours
          int rainSensorThreshold = 15;//default rain sensor sensitivity in mm
          byte hourCount = 24;
          byte state;
          byte oldState = -1;
          unsigned long ledPulseTime = 500UL;
          unsigned long pulseStart;
            Serial.begin(115200);
            gw.begin();
            pinMode(tipSensorPin, OUTPUT);
            attachInterrupt (1, sensorTipped, CHANGE);
            pinMode(ledPin, OUTPUT);
            digitalWrite(ledPin, HIGH);
            gw.sendSketchInfo("Rain Guage", "1.00b");
            gw.sendSensorPresentation(1, S_RAIN);
            gw.sendSensorPresentation(2, S_MOTION);
            Serial.println(F("Sensor Presentation Complete"));
            pinMode(tipSensorPin, INPUT);
            state = EEPROM.read(STATE_LOCATION);
            for (int i = 0; i < BUFFER_LENGTH; i++)
              byte locator = EEPROM.read(EEPROM_BUFFER + i);
              if (locator == 0xFF)
                eepromIndex = EEPROM_BUFFER + i;
                loadRainArray(eepromIndex);
                Serial.println(eepromIndex);
                break;
            gw.sendVariable(2, V_TRIPPED, state);
            dataMillis = millis();
            startMillis = millis();
            lastTipTime = millis() - oneHour;
            // uncomment the following block the first time you include this device.  The delays
            // are necessary in order to create the five Variable buckets in the correct order.
            // Once you create them, you can comment out these lines and re-upload to your arduino
            for (int j = 0; j < 5; j++)
             delay(2000);
             gw.sendVariable(1, dayBuckets[j] [0], 1);
             delay(2000);
             gw.sendVariable(2,V_VAR1, 1);
             delay(2000);
             gw.sendVariable(2,V_VAR2, 1);
            rainWindow = atoi(gw.getStatus(2, V_VAR1));
            delay(2000);
            rainSensorThreshold = atoi(gw.getStatus(2, V_VAR2));
            gw.sendVariable(1, V_RAINRATE, 0);
            Serial.print(F("Radio Done"));
            analogWrite(ledPin, 20);
            unsigned long measure = 0; // Check to see if we need to show sensor tripped in this block
            for (int i = 0; i < rainWindow; i++)
              measure = measure + rainBucket [i];
            measure >= rainSensorThreshold ? state = 1: state = 0;
            if (millis() - pulseStart < ledPulseTime)
              analogWrite(ledPin, 255);
            else
            if (state != oldState)
              EEPROM.write(STATE_LOCATION, state);
              oldState = state;
            if (millis() - lastTipTime >= oneHour)// timeout for rain rate
              if (rainRate != 0)
                rainRate = 0;
                gw.sendVariable(1, V_RAINRATE, rainRate);
            if (updateVera)
              updateVera = false;
            if ( (millis() - dataMillis) >= serialInterval)//Comment back in this block to enable Serial prints
              for (int i = 24; i <= 120; i=i+24)
                updateSerialData(i);
            if (tipBuffer > 0)
              Serial.println(F("Sensor Tipped"));
              rainBucket [0] ++;
              pulseStart = millis();
              if (rainBucket [0] > 253) rainBucket[0] = 253; // odd occurance but prevent overflow
              int dayTotal = 0;
              for (int i = 0; i < 24; i++)
                dayTotal = dayTotal + rainBucket [i];
              gw.sendVariable(1, V_RAIN, dayTotal);
              unsigned long tipDelay = millis() - lastTipTime;
              if (tipDelay <= oneHour)
                rainRate = ((oneHour) / tipDelay);
                Serial.print(F("RainRate= "));
                Serial.println(rainRate);
              lastTipTime = millis();
              updateVera = true;
              tipBuffer--;
            if ( (millis()- startMillis) >= oneHour)
              Serial.println("one hour elapsed");
              //EEPROM write last value
              EEPROM.write(eepromIndex, rainBucket[0]);
              eepromIndex++;
              if (eepromIndex > EEPROM_BUFFER + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER;
              EEPROM.write(eepromIndex, 0xFF);
              for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values
                rainBucket [i + 1] = rainBucket [i];
              rainBucket[0] = 0;
              gw.sendVariable(1, V_RAIN, tipCounter(24));// send 24hr tips
                int total = 0;
                for (int i = 0; i < dayBuckets[j][1]; i++)
                  total = total + rainBucket [i];
                gw.sendVariable( 1, dayBuckets[j] [0], total);
              hourCount++;
              if (hourCount >=3)//8 times daily update the Sensor variables
                if (rainWindow < 6)
                  rainWindow = 6;
                  gw.sendVariable( 2, V_VAR1, rainWindow);
                if (rainWindow > 120)
                  rainWindow = 120;
                  gw.sendVariable( 2, V_VAR2, rainWindow);
                delay(2000);
                if (rainSensorThreshold < 1)
                  rainSensorThreshold = 1;
                  gw.sendVariable( 2, V_VAR2, rainSensorThreshold);
                if (rainSensorThreshold > 1000)
                  rainSensorThreshold = 1000;
                hourCount = 0;
          void sensorTipped()
            static unsigned long last_interrupt_time = 0;
            unsigned long interrupt_time = millis();
            if (interrupt_time - last_interrupt_time > 200)
              tipBuffer++;
            last_interrupt_time = interrupt_time;
          unsigned long tipCounter(int x)
            int tipCount = 0;
            for ( int i = 0; i < x; i++)
              tipCount = tipCount + rainBucket [i];
            return tipCount;
          void updateSerialData(int x)
            Serial.print(F("Tips last "));
            Serial.print(x);
            Serial.print(F("hours: "));
            int tipCount = 0;
            for (int i = 0; i < x; i++)
            Serial.println(tipCount);
          void loadRainArray(int value)
            for (int i = 0; i < BUFFER_LENGTH - 1; i++)
               value--;
               Serial.println(value);
               if (value < EEPROM_BUFFER)
                   value = EEPROM_BUFFER + BUFFER_LENGTH;
               byte rainValue = EEPROM.read(value);
               Serial.println(rainValue);
               if (rainValue < 255)
                 rainBucket[i] = rainValue;
               else
                 rainBucket [i] = 0;
          • T
            tomrask
            Hey Francois
            Thanks for a nice projekt. I am thinking on building one myself. But is it possible to log the rain for everyday and writing the data to a csv file so I can use the data in Excel on Windows.
            Hope that you can help my.
            Tom
            • T tomrask
              Hey Francois
              Tom
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @tomrask
              Tom,
              Are you wishing to
              1. log to an SD card
              2. collect data controller side (e.g. Vera or other controller)
              3. transmit data directly to a server
              4. something else....?
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @hek
                are we still required to steer clear of MySensor's EEPROM in addresses 0-512?
                hekH 1 Reply Last reply
                • T
                  tomrask
                  I use a vera light with a USB key where the data can be stored. It vill be better if I the date was on my dropbox og sendt to my NAS.
                  But I have not fount a way to do it.
                  Tom
                    @hek
                    @hek
                    Use the saveState()/loadState() function in the MySensors library
                      @BulldogLowell
                      Neodymium magnet in and works fine. I had to clean out the countersink hole with a drill to get it in and used E6000 glue to hold it.
                      Now onto the hall effect sensor, wiring it up and of course the sketch.
                      The 123D Design file is also attached if anyone wants to make one, play with the design, make fun of it, etc. The .stl file is 13Mb, I can email that if you want.
                      If you want a print, let me know. I also have a few magnets and sensors, so I can send what you need for the project.
                      I think I'm going to design a housing for the electronics too. I'm not sure I can find the right project box for this (I really just want to print more parts :)
                      TippingBucket.123dx
                      N
                      N
                      nostradamux
                      @BulldogLowell
                      Hi!!
                      I was searching for a long time in internet any place where someone offers a design of this mechanism of rain gauge. Finally I've found you!. I really interested in having one, but I don't have a 3D (not jet!). Could you provide me one print? Let me know how is the process to get one, please ! (I am in Spain!)
                      Thank you
                      • N nostradamux
                        @BulldogLowell
                        Hi!!
                        Thank you
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @nostradamux
                        I actually used www.3dhubs.com which I believe is a Dutch company. I looked, they have service in Spain!
                        the service connects you with owners of 3D printers who make money using their personal machines.
                        • 5546dug5
                          5546dug5
                          5546dug
                          @nostradamux I had one printed using @BulldogLowell design and thru 3Dhubs.com the build was good and I used abs also for material. My cost in USA was approx. $17 usd and took a day to print and receive, looks good.
                          However I have not gotten far with project due to other issues unrealated just with I had more time and experience.
                          But this group is most helpful for newbies!
                          Good luck
                          • epierreE
                            epierreE
                            epierre
                            @BulldogLowell could you convert your 123D file to STL so that the 3DHub could be used please ?
                            this is how to do it:
                            http://sitesupport.123dapp.com/entries/20540436-How-to-export-an-STL-file-for-3D-printing-in-123D
                            thanks,
                            z-wave - Vera -> Domoticz
                            • epierreE epierre
                              thanks,
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @epierre
                              exceeds max file size, so here is a link:
                              https://drive.google.com/file/d/0B3KGTJHUgpw1MVpaYnUyUDUwN0E/view?usp=sharing
                              • petewillP
                                petewillP
                                petewill
                                @BulldogLowell Did you ever get around to updating the sketch to work with version 1.4.1? I'm finally getting around to making a rain gauge and I didn't want to recreate the wheel if you already made it and I missed it somewhere.
                                Thanks,
                                Pete
                                • BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @petewill
                                  Sorry for the lag time, I've been on Easter vacation with the family!
                                  Yes, I did update it, but I don't have my laptop with me here. I'll post it when I return home, early next week.
                                  petewillP 1 Reply Last reply
                                    @petewill
                                    petewillP
                                    petewillP
                                    petewill
                                    @BulldogLowell Great, thanks! You are a way better coder than me and I was struggling to understand the code. I did learn quite a bit about interrupts when I was trying to figure it out though.
                                    • petewillP
                                      petewillP
                                      petewill
                                      @BulldogLowell Any luck finding the sketch? Sorry to bug you, I was just hoping to get this project completed soon so I can work on the irrigation controller next. It's almost time to start watering the lawn/plants... Thanks!
                                      BulldogLowellB 2 Replies Last reply
                                      • petewillP petewill
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        wrote on last edited by BulldogLowell
                                        #39
                                        @petewill
                                        I am embarrassed to tell you that after updating my arduino software a while back, I cannot locate a compilable sketch!
                                        I have Time Machine, but still can't find it... and it is running on my rain guage!!!
                                        Here is a version that I have (which is titled RainGuage_V1.4.1.ino in my directory) which i found but cannot compile, it looks like a first save without edit?
                                        I need to completely update Arduino, the version and mySensors but please look at this:
                                         June 15, 2014
                                         Version 1.00b
                                        #include <EEPROM.h>
                                        #include <RF24.h>
                                        #include <Sensor.h>
                                        Sensor gw;
                                        int eepromIndex;
                                         { V_VAR1, 24 },
                                         { V_VAR2, 48 },
                                         { V_VAR3, 72 },
                                         { V_VAR4, 96 },
                                         { V_VAR5, 120},
                                        boolean updateVera;
                                        int rainCount;
                                        byte state;
                                        byte oldState = -1;
                                          gw.begin();
                                              break;
                                           delay(2000);
                                           delay(2000);
                                           delay(2000);
                                          delay(2000);
                                          else
                                            oldState = state;
                                            if (rainRate != 0)
                                              rainRate = 0;
                                          if (updateVera)
                                            updateVera = false;
                                          if (tipBuffer > 0)
                                            rainBucket [0] ++;
                                            int dayTotal = 0;
                                            updateVera = true;
                                            tipBuffer--;
                                            eepromIndex++;
                                            rainBucket[0] = 0;
                                              int total = 0;
                                            hourCount++;
                                              if (rainWindow < 6)
                                                rainWindow = 6;
                                                rainWindow = 120;
                                              delay(2000);
                                              hourCount = 0;
                                        void sensorTipped()
                                            tipBuffer++;
                                          int tipCount = 0;
                                          return tipCount;
                                          Serial.print(x);
                                          int tipCount = 0;
                                             value--;
                                             else
                                               rainBucket [i] = 0;
                                        @petewill
                                        I will convert this this weekend.
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @petewill
                                          Her is an untested go at it, and a very down and dirty update... I will test it probably Wednesday night, when I am back home. Let me know if you can!
                                           April 26, 2015
                                           Version 1.01b for MySensors version 1.4.1
                                             of data to EEPROM (Circular Buffer to maximize life of EEPROM)
                                          #include <EEPROM.h>
                                          #define RADIO_ID 99
                                          #define BUFFER_LENGTH 121  // buffer plus the current hour
                                          MyMessage msgRainRate(1, V_RAINRATE);
                                          MyMessage msgRain(1, V_RAIN);
                                          MyMessage msgRainVAR1(1, V_VAR1);
                                          MyMessage msgRainVAR2(1, V_VAR2);
                                          MyMessage msgRainVAR3(1, V_VAR3);
                                          MyMessage msgRainVAR4(1, V_VAR4);
                                          MyMessage msgRainVAR5(1, V_VAR5);
                                          MyMessage msgTripped(2, S_MOTION);
                                          MyMessage msgTrippedVar1(2, V_VAR1);
                                          MyMessage msgTrippedVar2(2, V_VAR2);
                                          int eepromIndex;
                                            { V_VAR1, 24 },
                                            { V_VAR2, 48 },
                                            { V_VAR3, 72 },
                                            { V_VAR4, 96 },
                                            { V_VAR5, 120},
                                          boolean updateVera;
                                          int rainCount;
                                          byte rainWindow = 72;         //default rain window in hours
                                          int rainSensorThreshold = 15; //default rain sensor sensitivity in mm
                                          byte state;
                                          byte oldState = -1;
                                            gw.begin(getVariables, RADIO_ID);
                                            gw.sendSketchInfo("Rain Guage", "1.01b");
                                            gw.present(1, S_RAIN);
                                            gw.present(2, S_MOTION);
                                            state = EEPROM.read(STATE_LOCATION);    //retreive prior state from EEPROM
                                            gw.send(msgTripped.set(state), false);  //send state to Vera
                                            delay(250);                             // recharge the capacitor
                                            boolean isDataOnEeprom = false;
                                              if (locator == 0xFF)  // found the EEPROM circular buffer index
                                                isDataOnEeprom = true;
                                                break;
                                            if (!isDataOnEeprom)
                                              // load all zeroes to EEPROM?
                                              // I gotta check this out!!!
                                            // reset the timers
                                            gw.request(2, V_VAR1);
                                            delay(250);
                                            gw.request(2, V_VAR2);
                                            delay(250);
                                            gw.process();
                                            pulseLED();
                                            // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
                                            int measure = 0; // Check to see if we need to show sensor tripped in this block
                                              measure += rainBucket [i];
                                            state = (measure >= rainSensorThreshold);
                                              delay(250);
                                              oldState = state;
                                            // Now lets reset the rainRate to zero if no tips in the last hour
                                              if (rainRate != 0)
                                                rainRate = 0;
                                                gw.send(msgRainRate.set(0));
                                                delay(250);
                                            // if tipped,send updates to VERA
                                            if (updateVera)
                                              gw.send(msgRainRate.set(rainRate));
                                              delay(250);
                                              updateVera = false;
                                              for (int i = 24; i <= 120; i = i + 24)
                                            if (tipBuffer > 0)
                                              rainBucket [0] ++;
                                              int dayTotal = 0;
                                              gw.send(msgRain.set(dayTotal));
                                              delay(250);
                                              updateVera = true;
                                              tipBuffer--;
                                            if (millis() - startMillis >= oneHour)
                                              eepromIndex++;
                                              rainBucket[0] = 0;
                                              gw.send(msgRain.set(tipCounter(24)));// send 24hr tips
                                              delay(250);
                                              transmitRainData(); // send all of the 5 buckets of data to controller
                                          void sensorTipped()
                                              tipBuffer++;
                                          int tipCounter(int hours)
                                            int tipCount = 0;
                                            for ( int i = 0; i < hours; i++)
                                            return tipCount;
                                            Serial.print(x);
                                            int tipCount = 0;
                                              value--;
                                              else
                                                rainBucket [i] = 0;
                                          void transmitRainData(void)
                                            int rainUpdateTotal = 0;
                                              rainUpdateTotal += rainBucket[i];
                                            gw.send(msgRainVAR1.set(rainUpdateTotal));
                                            delay(250);
                                            for (int i = 24; i < 48; i++)
                                            gw.send(msgRainVAR2.set(rainUpdateTotal));
                                            delay(250);
                                            for (int i = 48; i < 72; i++)
                                            gw.send(msgRainVAR3.set(rainUpdateTotal));
                                            delay(250);
                                            for (int i = 72; i < 96; i++)
                                            gw.send(msgRainVAR4.set(rainUpdateTotal));
                                            delay(250);
                                            for (int i = 96; i < 120; i++)
                                            gw.send(msgRainVAR5.set(rainUpdateTotal));
                                            delay(250);
                                          void getVariables(const MyMessage &message)
                                            if (message.sensor == 1)
                                              // nothing to do here
                                            else if (message.sensor == 2)
                                              if (message.type == V_VAR1)
                                                rainWindow = atoi(message.data);
                                                  rainWindow = 120;
                                                else if (rainWindow < 6)
                                                  rainWindow = 6;
                                                if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                                                  gw.send(msgTrippedVar1.set(rainWindow));
                                              else if (message.type == V_VAR2)
                                                rainSensorThreshold = atoi(message.data);
                                                else if (rainSensorThreshold < 1)
                                                if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                                                  gw.send(msgTrippedVar2.set(rainSensorThreshold));
                                          void pulseLED(void)
                                            static boolean ledState = true;
                                            static unsigned long pulseStart = millis();
                                            if (millis() - pulseStart < 500UL)
                                              digitalWrite(ledPin, !ledState);
