  3. Rain Guage
Rain Guage
128 Posts 23 Posters 156.2k Views 21 Watching
    @petewill
    here is some (untested) mods to update the 5 day rainfall history once per day at midnight. Take a look, let me know what you think (any problems issues). It turns out I was overthinking the problem and it really only needed minor mods...
     Arduino Tipping Bucket Rain Gauge
     April 26, 2015
     Version 1.4.1 alpha
     Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
     gateway you can measure and sense local rain.  This sketch will create two devices on your
     Vera controller.  One will display your total precipitation for the last 24, 48, 72, 96 and 120
     hours.  The other, a sensor that changes state if there is recent rain (up to last 120 hours)
     above a threshold.  Both these settings are user definable.
     This sketch features the following:
     * Allows you to set the rain threshold in mm
     * Allows you to determine the interval window up to 120 hours.
     * Displays the last 5 days of rain in Variable1 through Variable5
       of the Rain Sensor device
     * Configuration changes to Sensor device updated every hour
     * SHould run on any Arduino
     * Will retain Tripped/Not Tripped status and data in a power interruption, saving small ammount
       of data to EEPROM (Circular Buffer to maximize life of EEPROM)
     * LED status indicator
     by @BulldogLowell and @PeteWill for free public use
    #include <math.h>
    #include <Time.h>
    #define NODE_ID 24
    #define SKETCH_NAME "Rain Gauge"
    #define SKETCH_VERSION "1.4.1a"
    #define DWELL_TIME 125  // this allows for radio to come back to power after a transmission, ideally 0
    #define DEBUG_ON  // comment out this line to disable serial debug
    #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
    #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
    #define EEPROM_STATE_LOCATION 0 // location to save state to EEPROM
    #define EEPROM_BUFFER_LOCATION 1  // location of the EEPROM circular buffer
    #define BUFFER_LENGTH 121
    #define CALIBRATE_FACTOR 100 // e.g. 5 is .05mm (or 5 hundredths of an inch if imperial) per tip
    #ifdef  DEBUG_ON
    #define DEBUG_PRINT(x)   Serial.print(x)
    #define SERIAL_START(x)  Serial.begin(x)
    #else
    MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
    MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
    MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
    MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
    MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
    MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
    MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
    MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
    MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
    MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
    boolean metric = true;
    int eepromIndex;
    int tipSensorPin = 3; // Must be interrupt capable pin
    int ledPin = 5; // PWM capable pin required
    unsigned long dataMillis;
    const unsigned long serialInterval = 10000UL;
    const unsigned long oneHour = 3600000UL;
    unsigned long lastTipTime;
    unsigned long startMillis;
    unsigned int rainBucket [24] ; /* 24 hours = 1 day of data */
    unsigned int rainRate = 0;
    volatile int wasTippedBuffer = 0;
    byte rainWindow = 72;         //default rain window in hours
    int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
    byte state = 0;
    byte oldState = -1;
    int lastRainRate = 0;
    int lastMeasure = 0;
    boolean gotTime = false;
    byte lastHour;
      SERIAL_START(115200);
      // Set up the IO
      pinMode(tipSensorPin, INPUT_PULLUP);
      attachInterrupt (1, sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
      pinMode(ledPin, OUTPUT);
      digitalWrite(ledPin, HIGH);
      //Let's get the controller talking to the Arduino
      gw.begin(getVariables, NODE_ID);
      gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
      delay(DWELL_TIME);
      gw.present(CHILD_ID_RAIN_LOG, S_RAIN);
      delay(DWELL_TIME);
      gw.present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
      delay(DWELL_TIME);
      DEBUG_PRINTLN(F("Sensor Presentation Complete"));
      state = gw.loadState(EEPROM_STATE_LOCATION); //retreive prior state from EEPROM
      DEBUG_PRINT(F("Previous Tripped State (from EEPROM): "));
      DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
      gw.send(msgTripped.set(state));
      delay(DWELL_TIME);
      //Sync time with the server, this will be called hourly in order to keep time from creeping with the crystal
      while(timeStatus() == timeNotSet)
        gw.process();
        gw.requestTime(receiveTime);
        Serial.println("getting Time");
        delay(1000); // call once per second
        Serial.print(".");
      //retrieve from EEPROM stored values on a power cycle.
      boolean isDataOnEeprom = false;
      for (int i = 0; i < BUFFER_LENGTH; i++)
        byte locator = gw.loadState(EEPROM_BUFFER_LOCATION + 2 * i); //<<<<<<<<<<<
        if (locator == 0xFF)  // found the EEPROM circular buffer index
          eepromIndex = EEPROM_BUFFER_LOCATION + 2 * i;
          //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
          loadRainArray(eepromIndex);
          isDataOnEeprom = true;
          DEBUG_PRINT("EEPROM Index ");
          DEBUG_PRINTLN(eepromIndex);
          break;
      if (!isDataOnEeprom) // Added for the first time it is run on a new arduino
        eepromIndex = 1;
        gw.saveState(eepromIndex, 0xFF); // store the EEPROM index marker...
        gw.saveState(eepromIndex + 1, 0xFF);
      dataMillis = millis();
      startMillis = millis();
      lastTipTime = millis() - oneHour;
      //Get sensor time window and threshold from controller
      gw.request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
      delay(DWELL_TIME);
      gw.request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
      delay(DWELL_TIME);
      DEBUG_PRINTLN(F("Radio Setup Complete!"));
      gw.process();
      if (state)
        prettyFade();  // breathe if tripped
      else
        slowFlash();   // blink if not tripped
    #ifdef DEBUG_ON  // Serial Debug Block
      if ( (millis() - dataMillis) >= serialInterval)
        for (int i = 24; i <= 120; i = i + 24)
          updateSerialData(i);
      // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
      int measure = 0; // Check to see if we need to show sensor tripped in this block
      for (int i = 0; i < rainWindow; i++)
        measure += rainBucket [i];
        if (measure != lastMeasure)
          DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
          DEBUG_PRINTLN(measure);
          lastMeasure = measure;
      state = (measure >= rainSensorThreshold);
      if (state != oldState)
        delay(DWELL_TIME);
        gw.saveState(EEPROM_STATE_LOCATION, state); //New Code
        DEBUG_PRINT(F("New Sensor State... Sensor: "));
        DEBUG_PRINTLN(state? "Tripped" : "Not Tripped");
        oldState = state;
      unsigned long tipDelay = millis() - lastTipTime;
      if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
        DEBUG_PRINTLN(F("Sensor Tipped"));
        DEBUG_PRINT(F("rainBucket [0] value: "));
        DEBUG_PRINTLN(rainBucket [0]);
        int dayTotal = 0;
        for (int i = 0; i < 24; i++)
          dayTotal = dayTotal + rainBucket [i];
        DEBUG_PRINT(F("dayTotal value: "));
        DEBUG_PRINTLN(dayTotal);
        gw.send(msgRain.set(dayTotal, 1));
        delay(DWELL_TIME);
        wasTippedBuffer--;
        rainRate = ((oneHour) / tipDelay);
        if (rainRate != lastRainRate)
          gw.send(msgRainRate.set(rainRate, 1));
          delay(DWELL_TIME);
          DEBUG_PRINT(F("RainRate= "));
          DEBUG_PRINTLN(rainRate);
          lastRainRate = rainRate;
      if (tipDelay > oneHour)
        rainRate = 0;
      if (millis() - startMillis >= oneHour)
        DEBUG_PRINTLN(F("One hour elapsed."));
        for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values back into the array
          rainBucket [i + 1] = rainBucket [i];
        rainBucket[0] = 0;
        gw.send(msgRain.set(rainTotal(24), 1)); // send 24hr tips
        delay(DWELL_TIME);
        delay(DWELL_TIME);
        delay(DWELL_TIME);
        gw.saveState(eepromIndex, highByte(rainBucket[0]));
        gw.saveState(eepromIndex + 1, lowByte(rainBucket[0]));
        eepromIndex++;
        if (eepromIndex > EEPROM_BUFFER_LOCATION + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER_LOCATION;
        DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
        gw.requestTime(receiveTime); // sync the time every hour
        delay(DWELL_TIME);
      if (hour() == 0 and lastHour == 23)
        transmitRainData();
      lastHour = hour();
    void sensorTipped()
      unsigned long thisTipTime = millis();
      if (thisTipTime - lastTipTime > 100UL)
        rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
        wasTippedBuffer++;
      lastTipTime = thisTipTime;
    int rainTotal(int hours)
      int total = 0;
      for ( int i = 0; i < hours; i++)
        total += rainBucket [i];
      return total;
    void updateSerialData(int x)
      DEBUG_PRINT(F("Tips last "));
      DEBUG_PRINT(x);
      DEBUG_PRINTLN(F(" hours: "));
      int tipCount = 0;
      for (int i = 0; i < x; i++)
        tipCount = tipCount + rainBucket [i];
      DEBUG_PRINTLN(tipCount);
    void loadRainArray(int value) // load stored rain array from EEPROM on powerup
      for (int i = 0; i < BUFFER_LENGTH - 1; i++)
        value--;
        DEBUG_PRINT("EEPROM location: ");
        DEBUG_PRINTLN(value);
        if (value < EEPROM_BUFFER_LOCATION)
          value = EEPROM_BUFFER_LOCATION + BUFFER_LENGTH;
        byte rainValueHigh = gw.loadState(value);
        byte rainValueLow = gw.loadState(value + 1);
        int rainValue = (rainValueHigh << 8) & rainValueLow;
        rainBucket[i] = rainValue;
        DEBUG_PRINT(F("rainBucket[ value: "));
        DEBUG_PRINT(i);
        DEBUG_PRINT(F("] value: "));
        DEBUG_PRINTLN(rainBucket[i]);
    void transmitRainData(void)
      int rainUpdateTotal = 0;
        rainUpdateTotal += rainBucket[i];
      gw.send(msgRainVAR1.set(( float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 24; i < 48; i++)
      gw.send(msgRainVAR2.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 48; i < 72; i++)
      gw.send(msgRainVAR3.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 72; i < 96; i++)
      gw.send(msgRainVAR4.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 96; i < 120; i++)
      gw.send(msgRainVAR5.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
    void getVariables(const MyMessage &message)
      if (message.sensor == CHILD_ID_RAIN_LOG)
        // nothing to do here
      else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
        if (message.type == V_VAR1)
          rainWindow = atoi(message.data);
          if (rainWindow > 120)
            rainWindow = 120;
          else if (rainWindow < 1)
            rainWindow = 1;
          if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
            gw.send(msgTrippedVar1.set(rainWindow));
        else if (message.type == V_VAR2)
          rainSensorThreshold = atoi(message.data);
          if (rainSensorThreshold > 10000)
            rainSensorThreshold = 10000;
          else if (rainSensorThreshold < 1)
            rainSensorThreshold = 1;
          if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
            gw.send(msgTrippedVar2.set(rainSensorThreshold));
    void prettyFade(void)
      float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
      analogWrite(ledPin, val);
    void slowFlash(void)
      static boolean ledState = true;
      static unsigned long pulseStart = millis();
      if (millis() - pulseStart < 100UL)
        digitalWrite(ledPin, !ledState);
    void receiveTime(unsigned long time)
      DEBUG_PRINTLN(F("Time received from controller..."));
      setTime(time);
      char theTime[26];
      sprintf(theTime, "The current time is %d:%2d", hour(), minute());
      DEBUG_PRINTLN(theTime);
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @BulldogLowell
    Wow, just wow man.... that is a thing of beauty!!
    RJ_Make
    • RJ_MakeR RJ_Make
      @BulldogLowell
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @ServiceXp
      waiting for the 3D prints from China, I'll post when I get them!
      • marceltrapmanM
        marceltrapmanM
        marceltrapman
        I would love to see the .stl files for this.
        It has turned into something really amazing imho.
        Fulltime Servoy Developer
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          wrote on last edited by BulldogLowell
          #84
          I'll post, but I wanted to print and check first...
          @marceltrapman here you go...
          Posted to GoogleDrive
          • 5546dug5
            5546dug5
            5546dug
            @BulldogLowell this has been quite a project to watch unfold and develop into just the greatest project. I am learning more just following you programing wizards, than I learn surfing . Thanks for the project and the inside tracks on programming etc.
            I have got my tripping gage back from my local 3d hub shop and the job looks good I hope to have it running hardware and soft before I return to and take it to Florida this fall.
              @BulldogLowell , @petewill
              A page for your new creation has been deployed here:
              http://www.mysensors.org/build/rain
              Please let me know if I missed something or spelling needs to be corrected.
              petewillP 1 Reply Last reply
                petewillP
                petewillP
                petewill
                @hek Looks great! Thanks!
                blaceyB 1 Reply Last reply
                • petewillP petewill
                  blaceyB
                  blaceyB
                  blacey
                  @petewill - another outstanding tutorial video.
                  • blaceyB blacey
                    petewillP
                    petewillP
                    petewill
                    @blacey Thanks! Couldn't have done it without @BulldogLowell and @hek
                      wrote on last edited by hek
                      #90
                      @petewill, @BulldogLowell
                      Received my off the shelf tipping bucket sensor today. http://www.ebay.com/itm/331525977548?rmvSB=true
                      To my surprise it contained a dummy 2xAAA battery compartment. It might be possible to squeeze in a sensebender and nrf-radio (with some slight modification).
                      coffeeaddictC 1 Reply Last reply
                      • petewillP
                        petewillP
                        petewill
                        @hek Cool! Looks like you may even have some room on the other side if you can figure out a way to waterproof it?
                          coffeeaddictC
                          coffeeaddictC
                          coffeeaddict
                          @hek
                          Did you ever wire this up with sensebender & radio squeezed in?
                          I have this same guage I want to use with sensebender
                            No, never had time to finish my rain gauge this summer.
                            But it should be doable. But the big pcb in there has to be modified, or even better is probably to move the reed switch directly to the sensebender.
                              coffeeaddictC
                              coffeeaddictC
                              coffeeaddict
                              ok thanks
                              • mrc-coreM
                                mrc-coreM
                                mrc-core
                                Hi.
                                i'm having some trouble whit my rain gauge...
                                My rain gauge is a Aercus KW9015, using the code provided i'm getting rain count every hour whit no rain at all.
                                I don't know what to do to fix this.
                                Over the rain gauge i have 4 connections.
                                1 - GND
                                2 - TX1 --- Temperature sensor
                                3 - TX2 --- Rain sensor
                                4 - VCC
                                Why i'm i getting reads of rain ever 1h when there is no rain ?
                                Can anyone help me whit this problem ?
                                • mrc-coreM mrc-core
                                  Hi.
                                  1 - GND
                                  4 - VCC
                                  petewillP
                                  petewillP
                                  petewill
                                  @mrc-core
                                  Are you actually getting a rain value or is it just sending 0? The code is designed to send an update to your gateway every hour with the total rain for the day whether there is rain or not.
                                  • mrc-coreM
                                    mrc-coreM
                                    mrc-core
                                    Some times i do get value 0 but other times i get rain value a big rain value for example values above 10mm of rain.
                                    The update is made every hour. Yesterday the rain value was 148mm when there was no rain at all. It doesn't rain for the last month.
                                    Ill try today reassembling the arduino, clear cd rom and flash again the rain gauge code.
                                    But i don't understand why i get this values.
                                    I even beleaved that the sensor was sendind data because off the wind... but it's not the problem.
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @mrc-core
                                      how is it connected electronically?
                                      • mrc-coreM
                                        mrc-coreM
                                        mrc-core
                                        wrote on last edited by mrc-core
                                        #99
                                        At the rain gauge i have an arduino nano conneting PIN "d3" to TX2 over the rain gauge circuit, the arduino is powered at pins VIN and GND.
                                        The rain gauge gets its power from the 3.3V over the arduino.
                                        im posting two images from the rain gauge circuit:
                                        IMG_1
                                        IMG_2
                                        Starting to believe i had connect someting rong like for example had switched TX1 and TX2 at the rain gauge
                                        • mrc-coreM
                                          mrc-coreM
                                          mrc-core
                                          Looking over the IMG_2 should i connect arduino pin d3 to T1 just above the reed switch?
                                          Or i'm i correct using the TX2 connection.
