  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 675.9k Views 99 Watching
  • L
    L
    LastSamurai
    Ok, I will keep an eye on this one and stay with the serial gateway for now.
    • A
      A
      Andrew Currie
      After moving from my ubuntu laptop to RP3 I have had success!!
      Flashed the sd card with the latest openhabian, waited for everything to auto install on the RP3 and could then install the my sensors (ethernet) gateway on the pi and also open a karaf console to log openhab2 via a remote/headless ssh. My remote browser could open the paper ui via openhabianpi:8080 and I added the ethernet gateway successfully. Adding the motion sensor needed the node id 2 and child id 1 as set by the Arduino sketch. The light level sensor was then turned on and it just showed up as my sensors (2,2) in the paper ui inbox so this level of discovery works! The sensors now show tripped status/light level in the paper ui control.
      Looks like I can now progress to using My Sensors to control the mi-lights already working in openhab2.
      Thanks Tim for all your work on the binding
      • AndrewZA
        AndrewZA
        AndrewZ
        @TimO , I just noticed a weird behavior - I've changed configuration for another binding and restarted it from the console but that killed mysensors binding:
        2017-03-04 13:07:19.110 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.things'
        2017-03-04 13:07:19.123 [ERROR] [col.serial.MySensorsSerialConnection] - Interrupted reset time wait
        2017-03-04 13:07:19.124 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
        2017-03-04 13:07:19.125 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
        2017-03-04 13:07:19.125 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
        2017-03-04 13:07:21.141 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
        2017-03-04 13:07:21.149 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
        2017-03-04 13:07:33.161 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
        2017-03-04 13:07:33.163 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
        Complete stop/start of OH is the only solution so far.
        andreacioniA 1 Reply Last reply
        • AndrewZA AndrewZ
          andreacioniA
          andreacioniA
          andreacioni
          Hi @AndrewZ , yes this is a known issue (I just openend an issue here) with the binding. Just out of curiosity, have you changed something in things file?
          AndrewZA 1 Reply Last reply
          • andreacioniA andreacioni
            AndrewZA
            AndrewZA
            AndrewZ
            @andreacioni thank you
            Yes, it was a change in the .things file, but it was related to another binding.
            • AndrewZA AndrewZ
              andreacioniA
              andreacioniA
              andreacioni
              @AndrewZ things file update trigger a reload of all binding declared inside it, nothing strange. ;) Follow the above link to keep track of the status of this issue.
              • L
                L
                LastSamurai
                I just tried to get the openhab 2 binding up and running. I have a serial gateway and domoticz + openhab running on a pi. I stopped the domoticz service and installed the serial and mysensors addons for openhab like mentioned in the github readme (bundle:list showed them both). I also added the openhab user to the dialout group.
                I then created a demo.things file in config/things with
                Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSB0", sendDelay=200 ] {
                    /** define things connected to that bridge here */
                The log of openhab shows these errors though:
                2017-03-19 00:03:59.855 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                2017-03-19 00:03:59.897 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:46)
                Any idea why? This works just fine:
                cat /dev/ttyUSB0
                • L LastSamurai
                  cat /dev/ttyUSB0
                  AndrewZA
                  AndrewZA
                  AndrewZ
                  wrote on last edited by AndrewZ
                  #408
                  @LastSamurai please check the group ownership
                  $ ls -l /dev/ttyUSB0
                  Make sure the port you're using is included in EXTRA_JAVA_OPTS as described here
                  • L
                    L
                    LastSamurai
                    Thank you, that helped! Should anyone ever face the same problem: after changing the EXTRA_JAVA_OPTS I also needed to restart openhab (more likely the java vm).
                    • L
                      L
                      LastSamurai
                      So openhab is running now and discovers my sensors when I restart them while scanning. My RGBW controller nodes pop up as RGBW sensors though. The on/off switch works, but what do I have to do to actually control the colors?
                      I tried editing the 4 variables but that doesn't seem to change the lights.
                      0_1490048386134_upload-9bf82cdd-ddd8-4249-973e-65bd30a3a959
                      • T
                        TimO
                        wrote on last edited by TimO
                        #411
                        @LastSamurai : What does your sketch expect? One ASCII formated RGB code like described here: https://www.mysensors.org/download/serial_api_20 or a value between 0 and 100% per color (r,g,b,w)? I see different implementations (in openhab and in mysensors) and maybe we have to adjust the binding.
                        • L
                          L
                          LastSamurai
                          @TimO Right, I guess thats the problem. I have written my sketch against domoticz, so it expects either a 6 bit hex string (rgb = e.g. ff00ff) or a 9 bit (idk why) rgbw hex string (e.g. #ff00ff00).
                          According to the mysensors docu "ff00ff00" would be right, I guess.
                          T RVMRVMR 2 Replies Last reply
                          • AndrewZA
                            AndrewZA
                            AndrewZ
                            Just noticed in the log:
                            [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                            Is that normal or any additional configuration is needed?
                            Thanks!
                            T 1 Reply Last reply
                            • AndrewZA AndrewZ
                              Thanks!
                              TimO
                              @AndrewZ hmmmm, a child that represents itself with an id of 255 shouldn't exist. 255 is used for battery status for example. What's the message that comes in before that?
                              • L LastSamurai
                                TimO
                                @LastSamurai I'm working on a solution! RGB seems easy, but I haven't looked at RGBW. The Colopicker in OpenHAB only sends RGB.
                                L 1 Reply Last reply
                                • T TimO
                                  AndrewZA
                                  AndrewZA
                                  AndrewZ
                                  @TimO here is the output:
                                  2017-03-23 20:51:32.531 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                                  2017-03-23 20:51:33.754 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                                  2017-03-23 20:51:33.772 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                                  • AndrewZA AndrewZ
                                    TimO
                                    @AndrewZ the message occurs right after startup and before the bridge gets connected?! Just ignore the message if everything else is working fine. :D
                                    I'll release the refactored version soon. It's already available via the new IoT marketplace.
                                    • T TimO
                                      AndrewZA
                                      AndrewZA
                                      AndrewZ
                                      @TimO yes, message occurs on startup and I'm already using version from marketplace, I see it as market:binding-3328323 - 1.0
                                      • AndrewZA AndrewZ
                                        TimO
                                        @AndrewZ oh okay! I will look at it!
                                        • T TimO
                                          L
                                          L
                                          LastSamurai
                                          @TimO Cool, I'll test it once you are done. Domoticz only allows to either use the white channel or a RGB value (without the white) at the moment. Perhaps it can be done similarly in openhab.
