  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.5k Views 69 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    That is similar to the HLK-PM01, but without any of the certifications the HLK-PM01 received. And it is completely open, so unsafe in my view.
    • P
      P
      pdey
      I use these in Australia:
      https://www.clipsal.com/Trade/Products/Electrical-Accessories/Electronic-Accessories/USB-Charger
      AS/NZ safety certified, etc.
      • C
        C
        Chester
        @pdey What is the per unit cost of those? And do they fit easily inside the wall box say sideways to allow for arduino etc to also fit?
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          I looked around a little and they where pretty hard to find but the prices I found where 30-35 $/unit + shipping. To expensive for me.
          • P
            P
            pdey
            @Chester: They're usually about $30-35 per unit. On the expensive side, but I'd prefer to have something buried in my wall that I know I won't have to pull out in 12 months time - and also that is unlikely to start a fire...
            They're quite small. Designed to fit into the Clipsal faceplates for Cat5/Cat6 jacks.
            • sundberg84S
              #266
              http://www.ebay.com/itm/Ceramic-Slow-Blow-Fuse-3-6-x-10mm-Axial-Leads-125V-250V-0-1A-6-3A-10-30pcs-/111433875797?var=&hash=item19f1fa0155
              Hi all! I tested the Slow BLow fuse after @m26872 was a bit suspissions and it didnt blow. Looks like its some sort of bi-directional TVS and not a fuse. I could "run" a 1000Watt vaccum on this "fuse" which at 240v/200mA should blow at 48 Watt.
              Good find by m26872
              petewillP 1 Reply Last reply
              • sundberg84S sundberg84
                Good find by m26872
                petewillP
                petewillP
                petewill
                @sundberg84 Thanks for posting this. I'll have to take a look at mine to see if I got the same thing. That sucks that you didn't get what you ordered. Can you post a link when you find some new ones that you plan on using?
                • petewillP petewill
                  Does anyone know of any 120V AC to 5V DC transformers that are safe to put in a wall electrical box? I have been using old cell phone chargers for most of my projects but I was recently pondering putting something right in the wall. Since shipping can take so long I thought I'd ask now before I even start on the project.
                  I did some searching and couldn't find anything so I thought I'd ask the experts here.
                  Thanks in advance!
                  EDIT 9/7/2016
                  Watch out for Fakes! Read more here: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/355
                  If in doubt you can get them directly from the vendor here: http://www.hlktech.net/product.php?CateId=10
                  EDIT 12/28/2015
                  After MUCH discussion on this here are the findings of this thread (as of now):
                  Here is the diagram for how things should be wired:
                  These are the parts I ordered. I haven't tested any of these parts yet as this project has been put on the back burner for now :(. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
                  Also, see these posts for more discussion/ideas if interested:
                  http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board
                  http://forum.mysensors.org/topic/2488/in-wall-pcb
                  Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                  73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
                  250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
                  HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                  Pete
                  N
                  N
                  nunver
                  @petewill Thank you very much for this excellent thread. It's great to see the community is in agreement on how to implement a safe power supply.
                  Just one comment; for 220V, shouldn't we opt for a lower amp rating fuse? If we stay with 300 mA, I am thinking we will not protect the device?
                  • dakkyD
                    dakkyD
                    dakky
                    wrote on last edited by dakky
                    #269
                    hmm have some questions too:
                    1. is this setup only needed/recommended for in wall setups? or do you use this for all ac/dc converters?
                    2. does someone has a picture for me to share, how this looks in reallive?
                      I'm not shure how to build my node in this case
                    3. what kind of cables (profile) do you use for the "high voltage" parts?
                    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                    Software: MySensors 2.0development
                    • sundberg84S
                      @nunver - A question i have also asked myself doing my PCB - i dont know if it makes any difference but HLK has a maximum imput of 200mA (1A spikes) according to its datasheet. What is the logic here and why - anyone that can explain?
                      @dakky I think this would be just as great for a outside ad/dc converter, the main idea is to protect us but in-wall you dont have the ability to remove the heat made from the HLK that easy. Pictures from my PCB here (Not completed) but based on this thread.
                      • N nunver
                        petewillP
                        petewillP
                        petewill
                        @nunver I am by no means an expert in this (which is why I started the post :)) but it is my understanding that the fuses are there to protect your house (not sensor) from damage if something goes wrong. I can't remember where I read it but it was advised if the 300ma fuse blows the HLK should be replaced as a safety precaution.
                        @dakky
                        So far I have always used phone chargers for all my sensors which haven't been in the wall. I have never had an issue. I use the phone chargers because I can usually get them free from work when they are recycled. The HLK is much smaller though so it's a great option.
                        I'm not shure how to build my node in this case what kind of cables (profile) do you use for the "high voltage" parts?
                        Good question. I'd be curious to hear what others are doing. I haven't had time to build an in-wall sensor yet but I was planning to use 14 gauge wire because that's what is in most of my house.
                        N 1 Reply Last reply
                          @dakky
                          N
                          N
                          nunver
                          wrote on last edited by nunver
                          #272
                          @petewill I am no expert either, which is why I am reading this thread :smiley:. It is true that we protect the home, not the device. But fire starts at the device if not properly protected. The rating of the device says absolute maximum 0.2 A. This translates to 24W for 120 V and 44 W for 220 V, if my math is correct. Since this is way above the supply rating of the device, we must consider 0.2A as really absolute maximum. So, if we want to protect, in my opinion, we need 0.2A fast acting fuse.
                          Again, not an expert, so please disregard this post if I make no sense :smiley:
                          • sundberg84S
                            What about that the HLK can manage spikes up to 1A (according to datasheet). If so, this will blow the fuse even it its not necessary, atleast if you have a fast one?
                            • HenryWhiteH
                              HenryWhiteH
                              HenryWhite
                              Here's some more valuable information about the HLK: http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
                                N
                                N
                                nunver
                                @sundberg84 Correct, need to move the fuses out of varistor loop, between varistor and HLK.
                                • sundberg84S
                                  #276
                                  @nunver - Its not a good idea to have the varistor before the fuses i think... we have discussed this above and here
                                  Since varistors only can handle a short period with high load you need the fuses first.
                                    N
                                    N
                                    nunver
                                    @sundberg84 Yes you are correct there as well. Maybe two fuses like you have but different locations?
                                    • TD22057T
                                      TD22057T
                                      TD22057
                                      FYI: Here's an emissions test of the HLK-PM01. I don't have any experience with this sort of thing so I'm not sure what to make of the results:
                                      https://skippy.org.uk/quick-look-at-the-hlk-pm01/
                                      • P
                                        P
                                        punter9
                                        this doesn't mention specifically but a good read
                                        • TD22057T TD22057
                                          petewillP
                                          petewillP
                                          petewill
                                          @TD22057 Thanks for posting! It's great to get more info on this. Maybe someone else can weigh in who has more experience but this is comforting "While it is not great, I would consider using it on my own projects..."
