  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 583.2k Views 69 Watching
  • Nca78N Nca78
    @matz said in Safe In-Wall AC to DC Transformers??:
    Hi
    I understood that the HLK-PM01 can not be directly used out of the box, and that we need to solder it to a pcb with Varistor etc. but i may be wrong
    I dont have the skills to do that for something potentially dangerous. I need something that can be used out of the box and connect it directly to a wemos mini d1
    But from the pictures, it doesn't look like this is safer than an HLK... much more like the opposite.
    They didn't even bother to make slots to increase creepage, while high voltage and low voltage sides are clearly way too close. You can compare with layout on the HLK here, there's way more distance between the too sides of the board, but still they added a wide slot under the optocoupler (on the side, next to R6) to increase creepage.
    http://lygte-info.dk/pic/USB PS/P01 Hi-Link HLK-PM01/DSC_1454a.jpg
    There's also no filling in the enclosure for extra isolation, to even the heat generated and to protect components from environmental pollution. It should be ok for dust because opening is small but not at all for humidity...
    If you look at the product description of the exact same power supply (without the box) on AliExpress you can see they advise much more extra components than for the HLK: input fuse and at the output: RC filter, extra ceramic capacitor for high frequency noise, TVS diode and Y2 safety capacitor.
    https://www.aliexpress.com/store/product/1PCS-SANMIN-AC220V-to-DC3-3V-600MA-3W-Power-supply-Isolated-switching-power-supply-module-220V/923896_32799372973.html
    If you don't trust an HLK with extra safety (fuse + MOV) in your wall you shouldn't trust that thing. It doesn't seem to have much consideration for high/low voltage sides isolation and it's just been put in a plastic box like it is a complete and safe power supply, while the safety components advised by the original maker were not added...
    matz
    @nca78
    Thanks a lot for this complete answer. I understand that i should use HLK but put in on a PCB and add varistor and fuse like described in the edit of the first post. The problem is that I really don't know a lot about eletronic. For arduino things in 5v or 3,3v I have no problem to try to do myself, in order to learn, but for 220v i prefer to use a finished product... Is there exist somewhere a finished product with the HLK and all necessary pieces, ready to wire to the 220 v and to the arduino/nodemcu ?
    Regards
    Matz
    • M matz
      @nca78
      Regards
      Matz
      @matz I have made a breakout board. But using this and the pre-defined components you are on the right track. It's all easy to solder components (temp fuse can be a little tricky) . I don't have much time to source and solder assembled projects but have a look and you might get some ideas.
      https://www.openhardware.io/view/504/HLK-PM01-breakout-board
      M 1 Reply Last reply
      • sundberg84S sundberg84
        matz
        @sundberg84
        Thanks a lot it is very useful and i'm sure i can do it myself with tour board already designed.
        Juste one question : what are the sizes of the bard in all 3 dimensions ? I need to be sure it will fit in the wall where i need to put it before ordering the components. I could not find these info on the page you sent me.
        • M matz
          @sundberg84
          @matz hmm, traveling now so can't measure but 50 long I'm sure. It's probably 35-40mm wide.
            matz
            wrote on last edited by matz
            #405
            @sundberg84
            Quite small, so.
            In a link above i've seen a review of the HLK from one guy who seems to know about electronics.
            He recommends using the VIGORTRONIX VTX-214-005-105 AC/DC PCB Mount Power Supply . He said "for only a few quid more you win a switch mode PSU that stands a chance of not requiring external components to pass Class B!"
            Anyone here has tested the Vigortronix ? Is it better than HLK ?
            dbemowskD 1 Reply Last reply
            • M matz
              @sundberg84
              Quite small, so.
              dbemowskD
              dbemowskD
              @matz Never tried the Vigortronix, but I tried some from a company called Recom that were pretty good. Quite a bit higher in price though too.
              • dbemowskD dbemowsk
                matz
                @dbemowsk
                Ok thanks. I will try to build the sundberg84 board but i will try also to find a case built with a 3D printer as i prefer not to let all this stuff unprotected in case someone else than me in the futur open the wall socket
                • M matz
                  @dbemowsk
                  dbemowskD
                  dbemowskD
                  @matz Now that I have had my 3D printer for a year, I don't know why I didn't get one sooner. FOr these very reasons. If I need a case for something, I cad it out and make it.
                    matz
                    @dbemowsk
                    I'm planning to buy one, i'm sure there are plenty usage of it (sorry for my bad english i'm french :))
                    Concerning the PSU, one question : we could just disasemble an iphone charger, the small one is 5cm x 1,5cm x 3 cm, and reuse it in the wall. IMHO it is more safe than build ourselves a PSU. Has anybody tried this ?
                    dbemowskD sundberg84S 2 Replies Last reply
                    • M matz
                      @dbemowsk
                      dbemowskD
                      dbemowskD
                      @matz Why disassemble it other than to solder on some external power wires. Leave the original protection in place and you shouldn't have to worry about shorting anything out.
                        matz
                        @dbemowsk
                        I'm afraid it won't fit in the wall socket because of the metal stem, so it would be better to solder the power wires to it :
                        Nca78N 1 Reply Last reply
                        • M matz
                          @dbemowsk
                          Nca78N
                          Nca78N
                          Ce n'est pas une excuse valable :P
                          @dbemowsk
                          It doesn't look like an official charger, or even a branded one ? Then you would meet the same safety problems than the cheap power supplies. In that case have a look at http://lygte-info.dk/ to check if you can find a charger that's on the "safer side" of things.
                          • M matz
                            @dbemowsk
                            @matz the problem with phoneadapters are all the fake and truly unsafe ones. Just Google phone charger teardown. If you are sure you are buying a genuine one it's most likely quite expensive. Safety vs money is one of the key aspects in this thread and offcourse you can probably buy smaller and safer ones but you are going to pay for it.
                            jeremushkaJ 1 Reply Last reply
                            • A
                              A
                              arp5z5
                              wrote on last edited by arp5z5
                              #414
                              Hi guys (and gals?) new member here, and probably an absolute novice compared to most of you; however, I have been following this thread for quite some time. I recently acquired the components listed out by @petewill (thank you for the inspiration to try the project), and I have constructed the circuit in tune to the schematic also generously provided by @petewill. The only difference in my set up is that I have gone with a WeMos D1 mini instead of the arduino/radio combo solely due to having one laying around. The WeMos to relay connection works (as in flicks on/off the LED on the relay) in tune with the automation software I am using when the WeMos is being powered by micro USB. However, when attempting to power the circuit via a 120V outlet, I seem to keep blowing the 250V 300mA Slow Blow Fuse. In short, the LED on the WeMos briefly emits light, and then shuts off. When troubleshooting the circuit with a multimeter, I find that no current is flowing through the Slow Blow Fuse (therefore blown). I was wondering if anyone might have some ideas as to why this is happening despite the fuse being rated with the proper current and voltage ratings. I assume that there is a short occurring somewhere in the circuit; however, due to my novice knowledge, I have no idea why. I would greatly appreciate any and all pointers/criticism! Thank you. https://imgur.com/0Iy0UwY https://imgur.com/a/ZuSlb
                              • A arp5z5
                                @arp5z5 - my first thought was just like you said - a short. I would 1) remove everything from the DC side and replace the fuse. Then with a multimeter in continuity-mode see that you dont have a short on the AC side between Hot and Neutral. Did you wire everything correctly? If so - might be a bad varistor? If you dont get a beep - (with a new fuse) power everything up (without DC parts and see what happens. Works ok? Continue to add DC parts untill something happens.
                                A 1 Reply Last reply
                                  A
                                  A
                                  arp5z5
                                  @sundberg84 Thank you for the advice! I will take a look at it tomorrow and see what I can find.
                                  • O
                                    O
                                    Omemanti
                                    wrote on last edited by Omemanti
                                    #417
                                    hey,
                                    anyone have experience with:
                                    https://nl.mouser.com/ProductDetail/RECOM-Power/RAC01-05SGB?qs=sGAEpiMZZMuWiaalG5TUgCAeS4T2q9hep7l40%2FsKBt80J%252brWHE6eLg%3D%3D
                                    It looks affordable and more regulated than the Chines modules.
                                    some other variations: https://nl.mouser.com/RECOM/Power/Power-Supplies/AC-DC-Power-Modules/_/N-dv0g5?P=1yx5k7vZ1yzk8kkZ1yxt78rZ1yxt794Z1yxt791&Ns=Pricing|0
                                    • O Omemanti
                                      hey,
                                      dbemowskD
                                      dbemowskD
                                      @omemanti I have used some other RECOM modules and they are pretty solid. I like the fact that the incoming power leads are spread out to the edges rather than close in the center on the HLK modules. That alone makes them a heap safer.
                                      • SoloamS
                                        SoloamS
                                        Soloam
                                        wrote on last edited by Soloam
                                        #419
                                        I give up on soldering Temperature Fuses, for every one that I'm able to solder I blow up 5 of temperature rising from the solder. It would be a good safety improvement, but I'm going crazy with fazes burning :white_frowning_face: :neutral_face: :triumph: any recommendation? Who are you guys soldering without blowing them up?
                                        • SoloamS Soloam
                                          dbemowskD
                                          dbemowskD
                                          @soloam I too had great trouble with this. The best trick that I found was to have the side of the board with the fuse on it resting on a frozen gel pack while soldering. As long as you keep the fuse cold it should not blow. It is called a thermal fuse for a reason. I have talked to others that have had some success with aluminum heat sink clips like these that you would clamp on the lead that you are soldering to pull the heat away before it reaches the fuse.
                                          I still prefer the gel pack solution though. If you set yourself up right with the gel pack, you can have the cold pack pressing the thermal fuse against the power supply module as you solder which is where you want it anyway.
