  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 583.2k Views 69 Watching
  • dpressleD
    dpressleD
    dpressle
    what do you guys say about this PSU? i really liked that the mains are separated much more then the HLK.
    And how is the suggested full circuit use they have:
    0_1491802881073_upload-7646dbcb-7521-420a-9726-966b93b98d34
    • K
      K
      ksya
      Is using a genuine HLK-PM01 safe when directly connected to mains? I see here that they used extra components for safety.
      • MiKaM
        MiKaM
        MiKa
        Varistor and fuse is always good to use as a protection ;)
        Its lot of cases of start the fire in house from cheap AC/DC converters.
        Regards,
        MiKa
        • dbemowskD
          dbemowskD
          I have not only been adding a standard 0.75 amp fuse and MOV in my projects, but a thermal fuse also for added protection. I have been finding the thermal fuses a bit hard to work with as I have burned out a couple just with the heat of the soldering iron. They are good added protection though.
          • dbemowskD
            dbemowskD
            I find it crazy that in all the googling I have been doing on these, I have not found ONE review of how well they work or don't. The claim is that they are a replacement for the HLK-PM01 modules.
            0_1497566454517_upload-a7b7ea51-e26b-43a8-a3f8-4428d9f13192
            YveauxY 1 Reply Last reply
            • dbemowskD dbemowsk
              YveauxY
              YveauxY
              @dbemowsk said in Safe In-Wall AC to DC Transformers??:
              How good is your Russian? https://youtu.be/qnk4jksXdO4
              dbemowskD 1 Reply Last reply
              • YveauxY Yveaux
                dbemowskD
                dbemowskD
                @Yveaux I skipped that class in grade school......LOL
                alexsh1A 1 Reply Last reply
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @dbemowsk this is a good review - go ahead and try them
                  • alexsh1A alexsh1
                    dbemowskD
                    dbemowskD
                    @alexsh1 Thanks, they are a bit cheaper than the HLK-PM01s and they appear to be a pin compatible replacement for them.
                    • P
                      P
                      Pete357
                      Hi all,
                      I have used MEAN WELL IRM-10-5, 5V/2A/10W for some of my projects, since they were available in my local store. They are ok, robust, good quality.
                      But as they are much bigger, 10W and cost me 7,5 EUR per piece I wanted to try HLKs for some projects.
                      This was my 1st order of HLKs. As I had no experience and wanted to avoid fakes I used ebay link from Power Sources at MySensors Store, this one:
                      http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5574962087&toolid=10001&campid=5337834143&customid=nodebb&mpre=http%3A%2F%2Fwww.ebay.com%2Fitm%2F261985573055
                      BTW it is the same seller and store as mentioned by some other members here on forum.
                      I was impatiently waiting for them. Finally yeasterday (after 3 weeks) I found the package on my desk. First look when I unpacked it indicates something is not ok. Came back to this thread to see how to check the fakes ... unpleasant findings ... poor enclosure, thinner pins, every at different lenghts, non blocking mechanism on pins, no quality labels, no bar codes, no dot mark on top, different markings on top...
                      These ones look much worse as I could even expect from fakes:
                      3_1510045929288_IMG_7585-001.jpg 2_1510045929288_IMG_7584-001.jpg 1_1510045929288_IMG_7583-001.jpg 0_1510045929288_IMG_7579-001.jpg
                      Please can somebody more experienced with HLKs recommend really reliable source where to buy the right modules?
                      Pete
                      ferroF dbemowskD 2 Replies Last reply
                      • P Pete357
                        Hi all,
                        Pete
                        ferroF
                        ferroF
                        ferro
                        @Pete357 said in Safe In-Wall AC to DC Transformers??:
                        To be sure you get genuine module buy it directly from the vendor:
                        http://www.hlktech.net/product.php?CateId=10
                        P 1 Reply Last reply
                        • ferroF ferro
                          P
                          P
                          Pete357
                          @ferro Thank you, didnt know they have own eshop. I should have been looking for it before.
                          I suggest to put this link into MySensors Store instead of that ebay link, for others looking where to buy it and not to make the same mistake as I did.
                          Pete
                          Nca78N 1 Reply Last reply
                          • P Pete357
                            Pete
                            Nca78N
                            Nca78N
                            Very ugly modules indeed, I'm not familiar with ebay but you should have some sort of buyer protection ?
                            I could easily get money back on Aliexpress with mines that were looking better, so on ebay it should not be a problem.
                            • P Pete357
                              Hi all,
                              Pete
                              dbemowskD
                              dbemowskD
                              @Pete357 I had an issue with some modules that I bought that were not packed well. When they arrived, I had one or two that had at least one pin bent nearly all the way over. Some had case damage that was slight, but still usable. I contacted the seller and got half my money back. I tested all the modules and they all functioned properly. I use MOVs and fuses on the input power, so I figure I should be pretty protected in the event of a failure. I am not pushing them anywhere near the limits either. Do what you feel is necessary for your case though.
                                Ok, removed the ebay link from the buying guide. If someone finds an alternative ebay seller with genuine modules, let me know.
                                • dbemowskD
                                  dbemowskD
                                  Sorry, I didn't mean to imply that I bought them from that link. Never the less, it sounds like those are not genuine.
                                    matz
                                    wrote on last edited by matz
                                    #397
                                    Hi Guys,
                                    What a huge topic :)
                                    Has anyone tested this 3,2 $ module ? Do you think it is safe to put it in the wall socket ?
                                    AC-DC Isolated AC 110V / 220V To DC 5V 600mA Constant Voltage Switch Power Supply Converter Module
                                    In the comments on guy disassembled it :
                                    Regards
                                    Matz
                                    korttomaK 1 Reply Last reply
                                    • M matz
                                      Hi Guys,
                                      Regards
                                      Matz
                                      korttomaK
                                      korttomaK
                                      korttoma
                                      @matz why not use the HLK-PM01 that is known to be safe?
                                      http://www.hlktech.net/product_detail.php?ProId=54
                                      • Tomas
                                        matz
                                        Hi
                                        I understood that the HLK-PM01 can not be directly used out of the box, and that we need to solder it to a pcb with Varistor etc. but i may be wrong
                                        I dont have the skills to do that for something potentially dangerous. I need something that can be used out of the box and connect it directly to a wemos mini d1
                                        • M matz
                                          Hi
                                          Nca78N
                                          Nca78N
                                          wrote on last edited by Nca78
                                          #400
                                          @matz said in Safe In-Wall AC to DC Transformers??:
                                          Hi
                                          But from the pictures, it doesn't look like this is safer than an HLK... much more like the opposite.
                                          They didn't even bother to make slots to increase creepage, while high voltage and low voltage sides are clearly way too close. You can compare with layout on the HLK here, there's way more distance between the too sides of the board, but still they added a wide slot under the optocoupler (on the side, next to R6) to increase creepage.
                                          http://lygte-info.dk/pic/USB PS/P01 Hi-Link HLK-PM01/DSC_1454a.jpg
                                          There's also no filling in the enclosure for extra isolation, to even the heat generated and to protect components from environmental pollution. It should be ok for dust because opening is small but not at all for humidity...
                                          If you look at the product description of the exact same power supply (without the box) on AliExpress you can see they advise much more extra components than for the HLK: input fuse and at the output: RC filter, extra ceramic capacitor for high frequency noise, TVS diode and Y2 safety capacitor.
                                          https://www.aliexpress.com/store/product/1PCS-SANMIN-AC220V-to-DC3-3V-600MA-3W-Power-supply-Isolated-switching-power-supply-module-220V/923896_32799372973.html
                                          If you don't trust an HLK with extra safety (fuse + MOV) in your wall you shouldn't trust that thing. It doesn't seem to have much consideration for high/low voltage sides isolation and it's just been put in a plastic box like it is a complete and safe power supply, while the safety components advised by the original maker were not added...
                                          M 1 Reply Last reply
