  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.1k Views 69 Watching
  • P Pete357
    @ferro Thank you, didnt know they have own eshop. I should have been looking for it before.
    I suggest to put this link into MySensors Store instead of that ebay link, for others looking where to buy it and not to make the same mistake as I did.
    Pete
    Very ugly modules indeed, I'm not familiar with ebay but you should have some sort of buyer protection ?
    I could easily get money back on Aliexpress with mines that were looking better, so on ebay it should not be a problem.
    • P Pete357
      Hi all,
      I have used MEAN WELL IRM-10-5, 5V/2A/10W for some of my projects, since they were available in my local store. They are ok, robust, good quality.
      But as they are much bigger, 10W and cost me 7,5 EUR per piece I wanted to try HLKs for some projects.
      This was my 1st order of HLKs. As I had no experience and wanted to avoid fakes I used ebay link from Power Sources at MySensors Store, this one:
      http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5574962087&toolid=10001&campid=5337834143&customid=nodebb&mpre=http%3A%2F%2Fwww.ebay.com%2Fitm%2F261985573055
      BTW it is the same seller and store as mentioned by some other members here on forum.
      I was impatiently waiting for them. Finally yeasterday (after 3 weeks) I found the package on my desk. First look when I unpacked it indicates something is not ok. Came back to this thread to see how to check the fakes ... unpleasant findings ... poor enclosure, thinner pins, every at different lenghts, non blocking mechanism on pins, no quality labels, no bar codes, no dot mark on top, different markings on top...
      These ones look much worse as I could even expect from fakes:
      3_1510045929288_IMG_7585-001.jpg 2_1510045929288_IMG_7584-001.jpg 1_1510045929288_IMG_7583-001.jpg 0_1510045929288_IMG_7579-001.jpg
      Please can somebody more experienced with HLKs recommend really reliable source where to buy the right modules?
      Pete
      dbemowskD
      dbemowskD
      @Pete357 I had an issue with some modules that I bought that were not packed well. When they arrived, I had one or two that had at least one pin bent nearly all the way over. Some had case damage that was slight, but still usable. I contacted the seller and got half my money back. I tested all the modules and they all functioned properly. I use MOVs and fuses on the input power, so I figure I should be pretty protected in the event of a failure. I am not pushing them anywhere near the limits either. Do what you feel is necessary for your case though.
        Ok, removed the ebay link from the buying guide. If someone finds an alternative ebay seller with genuine modules, let me know.
        • dbemowskD
          dbemowskD
          Sorry, I didn't mean to imply that I bought them from that link. Never the less, it sounds like those are not genuine.
            matz
            wrote on last edited by matz
            #397
            Hi Guys,
            What a huge topic :)
            Has anyone tested this 3,2 $ module ? Do you think it is safe to put it in the wall socket ?
            AC-DC Isolated AC 110V / 220V To DC 5V 600mA Constant Voltage Switch Power Supply Converter Module
            In the comments on guy disassembled it :
            Regards
            Matz
            korttomaK 1 Reply Last reply
            • M matz
              Hi Guys,
              Regards
              Matz
              korttomaK
              korttomaK
              korttoma
              @matz why not use the HLK-PM01 that is known to be safe?
              http://www.hlktech.net/product_detail.php?ProId=54
              • Tomas
                matz
                Hi
                I understood that the HLK-PM01 can not be directly used out of the box, and that we need to solder it to a pcb with Varistor etc. but i may be wrong
                I dont have the skills to do that for something potentially dangerous. I need something that can be used out of the box and connect it directly to a wemos mini d1
                Nca78N 1 Reply Last reply
                • M matz
                  Hi
                  wrote on last edited by Nca78
                  #400
                  @matz said in Safe In-Wall AC to DC Transformers??:
                  Hi
                  But from the pictures, it doesn't look like this is safer than an HLK... much more like the opposite.
                  They didn't even bother to make slots to increase creepage, while high voltage and low voltage sides are clearly way too close. You can compare with layout on the HLK here, there's way more distance between the too sides of the board, but still they added a wide slot under the optocoupler (on the side, next to R6) to increase creepage.
                  http://lygte-info.dk/pic/USB PS/P01 Hi-Link HLK-PM01/DSC_1454a.jpg
                  There's also no filling in the enclosure for extra isolation, to even the heat generated and to protect components from environmental pollution. It should be ok for dust because opening is small but not at all for humidity...
                  If you look at the product description of the exact same power supply (without the box) on AliExpress you can see they advise much more extra components than for the HLK: input fuse and at the output: RC filter, extra ceramic capacitor for high frequency noise, TVS diode and Y2 safety capacitor.
                  https://www.aliexpress.com/store/product/1PCS-SANMIN-AC220V-to-DC3-3V-600MA-3W-Power-supply-Isolated-switching-power-supply-module-220V/923896_32799372973.html
                  If you don't trust an HLK with extra safety (fuse + MOV) in your wall you shouldn't trust that thing. It doesn't seem to have much consideration for high/low voltage sides isolation and it's just been put in a plastic box like it is a complete and safe power supply, while the safety components advised by the original maker were not added...
                  • Nca78N Nca78
                    Hi
                    matz
                    @nca78
                    Thanks a lot for this complete answer. I understand that i should use HLK but put in on a PCB and add varistor and fuse like described in the edit of the first post. The problem is that I really don't know a lot about eletronic. For arduino things in 5v or 3,3v I have no problem to try to do myself, in order to learn, but for 220v i prefer to use a finished product... Is there exist somewhere a finished product with the HLK and all necessary pieces, ready to wire to the 220 v and to the arduino/nodemcu ?
                    Regards
                    Matz
                    • M matz
                      @nca78
                      Regards
                      Matz
                      sundberg84S
                      sundberg84S
                      @matz I have made a breakout board. But using this and the pre-defined components you are on the right track. It's all easy to solder components (temp fuse can be a little tricky) . I don't have much time to source and solder assembled projects but have a look and you might get some ideas.
                      https://www.openhardware.io/view/504/HLK-PM01-breakout-board
                      • sundberg84S sundberg84
                        matz
                        @sundberg84
                        Thanks a lot it is very useful and i'm sure i can do it myself with tour board already designed.
                        Juste one question : what are the sizes of the bard in all 3 dimensions ? I need to be sure it will fit in the wall where i need to put it before ordering the components. I could not find these info on the page you sent me.
                        • M matz
                          @sundberg84
                          sundberg84S
                          sundberg84S
                          @matz hmm, traveling now so can't measure but 50 long I'm sure. It's probably 35-40mm wide.
                            matz
                            #405
                            @sundberg84
                            Quite small, so.
                            In a link above i've seen a review of the HLK from one guy who seems to know about electronics.
                            He recommends using the VIGORTRONIX VTX-214-005-105 AC/DC PCB Mount Power Supply . He said "for only a few quid more you win a switch mode PSU that stands a chance of not requiring external components to pass Class B!"
                            Anyone here has tested the Vigortronix ? Is it better than HLK ?
                            dbemowskD 1 Reply Last reply
                            • M matz
                              @sundberg84
                              Quite small, so.
                              dbemowskD
                              dbemowskD
                              @matz Never tried the Vigortronix, but I tried some from a company called Recom that were pretty good. Quite a bit higher in price though too.
                              • dbemowskD dbemowsk
                                matz
                                @dbemowsk
                                Ok thanks. I will try to build the sundberg84 board but i will try also to find a case built with a 3D printer as i prefer not to let all this stuff unprotected in case someone else than me in the futur open the wall socket
                                • M matz
                                  @dbemowsk
                                  dbemowskD
                                  dbemowskD
                                  @matz Now that I have had my 3D printer for a year, I don't know why I didn't get one sooner. FOr these very reasons. If I need a case for something, I cad it out and make it.
                                    matz
                                    @dbemowsk
                                    I'm planning to buy one, i'm sure there are plenty usage of it (sorry for my bad english i'm french :))
                                    Concerning the PSU, one question : we could just disasemble an iphone charger, the small one is 5cm x 1,5cm x 3 cm, and reuse it in the wall. IMHO it is more safe than build ourselves a PSU. Has anybody tried this ?
                                    dbemowskD sundberg84S 2 Replies Last reply
                                    • M matz
                                      @dbemowsk
                                      dbemowskD
                                      dbemowskD
                                      @matz Why disassemble it other than to solder on some external power wires. Leave the original protection in place and you shouldn't have to worry about shorting anything out.
                                        matz
                                        @dbemowsk
                                        I'm afraid it won't fit in the wall socket because of the metal stem, so it would be better to solder the power wires to it :
                                        • M matz
                                          @dbemowsk
                                          Ce n'est pas une excuse valable :P
                                          @dbemowsk
                                          It doesn't look like an official charger, or even a branded one ? Then you would meet the same safety problems than the cheap power supplies. In that case have a look at http://lygte-info.dk/ to check if you can find a charger that's on the "safer side" of things.
