  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 581.7k Views 69 Watching
  • B
    B
    Bertb
    @ThinkPad I am not sure it is still safe to operate.
    T 1 Reply Last reply
    • B Bertb
      ThinkPad
      wrote on last edited by ThinkPad
      #142
      @Bertb The idea was to put it on my desk (with a mains cord soldered to it) running a resistor load, and then shoot some thermal pics of it
      . I wasn't planning to touch the unit with my bare hands while it is powered hahaha
      B 1 Reply Last reply
      • T ThinkPad
        B
        B
        Bertb
        @ThinkPad Well its your desk, so its fine with me.
        Is there a way to get your address without shouting it from the rooftops?
        • A
          A
          Atomfire
          Don't suppose anyone could tell me what components (values) need to be purchased for 230v (UK)? I have bought 10 of these and wish to make them as safe as I can.
          • B Bertb
            ThinkPad
            @Bertb Have sent you a chat, see the chat balloon top right corner.
            • A Atomfire
              B
              B
              Bertb
              @Atomfire I will come back to that tomorrow.
              petewillP 1 Reply Last reply
              • B Bertb
                petewillP
                petewillP
                petewill
                @Bertb Once again, thank you for all your work with this! I can't wait to start building with this! This will be so helpful to have a safer method instead of just dismantling old phone chargers and rolling the dice.
                I couldn't open the schematic. What is the file extension? Also, would you mind posting the required parts for 110v if they are any different than what you will be providing @Atomfire?
                Thanks!
                Pete
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Hey guys, I wrote to the owner of the site suggested by @Moshe-Livne. He replied saying that he can test the HLK.
                  He mentioned that usually he takes at least two units (so if one burn he can continue the testing). I will send one from my lot, perhaps we have a brave guy to gave up one more? (a sacrifice of few to save many ) ;-) Let me know and I will share the address via PM (Denmark).
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                  Moshe LivneM B DidiD 3 Replies Last reply
                  • rvendrameR rvendrame
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @rvendrame Considering cost of postage and logistics involved it would probably be cheapest to just order two units from Ali to him? its 8$ including shipping if i remember correctly
                    • petewillP petewill
                      Thanks!
                      Pete
                      B
                      B
                      Bertb
                      @petewill The schematic is just a simple draft. It can be seen with IE.
                      • B Bertb
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @Bertb I tried adding "html" suffix to it but it didn't work.
                        • A
                          A
                          aproxx
                          One option is to click on the link and download the file. After the file is completely downloaded, just add the extention .jpg to it.
                          The result is as following:
                          • B
                            B
                            Bertb
                            Something went wrong with uploading the file, I think.
                            Herewith a new schematic with a suggested bill of material.
                            It is highly experimental still, but I ordered the components yesterday.
                            I am specially interested in working with the PTC fuse.
                            I hope the proposed circuit works for you. Please keep the maximim continuous output power in mind. It is only 3 Watts (600 mA).
                            In some cases you might need to add C1's (rule of thump 1 per chip or chip VCC) and/or need to increase the value of C2. This depends on the fluctuations in the power demand.
                            With the proposed values for C1 and C2, the ripple remained below 50 mV at 500 mA.
                            Also keep in mind that a remaining oscillation frequency residue appears in the output of some 60kHz.. If capacitors are not able to filter that out, a small coil might be needed.
                            Well it is experimenting that makes this fun, isn't it?
                              B
                              B
                              Bertb
                              I am in for this.
                                DidiD
                                DidiD
                                Didi
                                I will send him a powersupply too. :stuck_out_tongue_winking_eye:
                                if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
                                • B Bertb
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @Bertb can now see the scheme! thanks. But can't see the BOM
                                  • B
                                    B
                                    Bertb
                                    ... it must be friday ...
                                    voeding.doc
                                    DidiD 1 Reply Last reply
                                    • B Bertb
                                      voeding.doc
                                      DidiD
                                      DidiD
                                      Didi
                                      @Bertb said:
                                      voeding.doc
                                      can you make a pdf, i have no microsoft office
                                      • B
                                        B
                                        Bertb
                                        As you please ...
                                        voeding.pdf
                                        • B Bertb
                                          As you please ...
                                          voeding.pdf
                                          DidiD
                                          DidiD
                                          Didi
                                          @Bertb said:
                                          As you please ...
                                          thank you
