  3. PA Level settings
PA Level settings
3 Posts 2 Posters 2.8k Views 1 Watching
  • marceltrapmanM
    marceltrapmanM
    marceltrapman
    I am struggling/playing with the PA_LEVEL settings and I am a bit confused:
    For the sensors the MAX level is set by default in the config file without any comments (other than available levels).
    I have non amplified radio's from 2 suppliers.
    One supplier says:
    Transmit Power: (max) 4.5: +7 dB
    Receiver Sensitivity: ≦-90dB
    1. Q: What settings do I use?
    I also have radio's that do not have any documentation at all :(
    2. Q: Any idea how to find out what settings I should use?
    The amplified radio is simple (I hope), I am going to use it for the gateway and the config file says 'Tune here if using an amplified nRF2401+ in your gateway.'
    The documentation says 'In the 2Mbit / s rate @ 0dBm output peak current of 11mA'.
    3. I assume that I have to set the level for these to RF24_PA_MAX
    4. But, what If I have a relay node or other sensor with an amplified antenna. can I simply override the config settings in the .ino sketch or do I have to change these in the config.h?
    Suggestion: would it not be better to supply only a 'config.default' file to avoid overriding an existing config.h file?
    Cheers,
    Marcel
    Fulltime Servoy Developer
    axillentA 1 Reply Last reply
    • marceltrapmanM marceltrapman
      One supplier says:
      Cheers,
      Marcel
      axillentA
      axillentA
      axillent
      @marceltrapman in most cases the default MAX level is a best choice.
      Only in some very special cases you will probably need to decrease levels. It can be useful if two devices are too close to each other.
      sense and drive
      • marceltrapmanM
        marceltrapmanM
        marceltrapman
        @axillent OK, thank you. I will leave it default then.
