MQTT Gateway - Stuck on "Started!"
@Zed , the antenna-version of nRF officially consumes up to 115mA (cheap clones can easily drawn more). The w5100 running at 100Mbps may consume ~140mA. That still leave some room for your arduino. Have you measured the DC adapter with full load on it?
@rvendrame No, I have not measured the DC adapter with full load on it. I will do it in the following days and I will report my findings.
I still have some trouble... Although this seems like a Domoticz question, I'll post it here because I think that the problem is related to my Ethernet GW and not to Domoticz.
So, I upgraded my GW to mySensors 1.5 and I made a Temperature/Humidity sensor as it is described here using a DHT22. On the serial monitor I get:
find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: sensor started, id=255, parent=255, distance=255 find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: T: 31.00 find parent send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc: H: 44.40I don't really understand the message (could someone explain a little bit), however I suppose that the sensor works. Then, on the serial monitor of the ethernet gateway I get:
0;0;3;0;9;gateway started, id=0, parent=0, distance=0On Domoticz I have added the Ethernet GW to the hardware list. However when I open the web interface i see the following:
and in the log I get:
2015-08-03 17:03:45.650 Domoticz V2.2657 (c)2012-2015 GizMoCuz 2015-08-03 17:03:45.758 Sunrise: 06:31:00 SunSet:20:31:00 2015-08-03 17:03:45.763 Active notification subsystems: (0/8) 2015-08-03 17:03:46.164 Webserver started on port: 8008 2015-08-03 17:03:46.171 Webserver started on port: 443 2015-08-03 17:03:46.172 Hardware Monitor: Started 2015-08-03 17:03:48.509 Incoming connection from: 127.0.0.1 2015-08-03 17:03:49.837 Incoming connection from: 192.168.1.14 2015-08-03 17:03:50.191 MySensors: connected to: 192.168.1.152:5003Questions:
- Does the GW message mean that the GW is not working properly?
- I've set the IP of the GW to be 192.168.1.152 and Port 5003. Does this mean that the same port has to be free on the server side?
- What is the inclusion button. Do I have to add it to the GW?
So, any suggestions for troubleshooting? :bowtie:
PS: Configuration summary
Arduino IDE: 1.6.5
OS: Mac OS X Yosemite 10.10.4 (for the sketches) and Windows 10 for Domoticz
MySensor Library: 1.5 -
Looks like GW has started correctly but no messages seems to reach the gateway from the node. The node is broadcasting a find-parent-request with no answer from the gateway.
Hard to say what the problem is.. Have you changed any channels settings in MyConfig.h before compiling gateway/node?
@hek No, I didn't change anything. Should I?
I am experimenting now with MYSController. I send a version request to the gateway and I get a proper reply.
8/3/2015 20:18:04 TX 0;0;3;0;2; 8/3/2015 20:18:04 RX 0;0;3;0;2;1.5(If I ask for the sketch name or version I do not get a reply)
I am suspecting that the radio module of the gateway may not work properly. Is there a way to check this without de-soldering the module and replacing it by another one?
Arduino IDE: 1.6.5
You might have the same problem described here:
http://forum.mysensors.org/topic/1736/release-1-5-and-ethernet-gatewaySeems like you have to send something from gateway before you can receive anything.. A bug.
@hek Probably this is not the case. I downgraded everything to 1.4.1. Now on the sensor serial monitor I get:
req node id send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail: req node id send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail: req node id send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail: req node id send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail: T: 31.30 req node id send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail: send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail: H: 38.50 req node id send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail: T: 31.20 req node id send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail: H: 39.70If understand it correctly the sensor still is not able to get an ID from the GW. Probably I will make a serial gateway in the following days for testing.
Sorry @Zed, replied to the wrong post. (Tip! Don't have too many forum windows open at the same time)
Everything works now. I made another Ethernet gateway using an Arduino Uno, a compatible Ethernet Shield and a RF24L01+ module without the antenna. Now the sensors get their reply from the gateway and they report to Domoticz seamlessly.
It seems that the problem was with the antenna version RF24L01+ module I was using. Probably it got destroyed when I replaced its pins.
Some guidelines for troubleshooting that may help others:
- check that the power supply is good enough. If you are using one of these cheap breadboard power supplies with the ams1117 regulators, check that you provide enough voltage for the regulators to work properly. Do not expect from a capacitor to save you from a faulty power supply, especial when you use batteries. Have in mind that some of these supplies are shipped with faulty regulators and provide as high voltage as their input.
- verify that the Ethernet module works properly. Just upload a simple sketch and get an IP. eg. test this.
- verify that the nrf24 modules work properly. You can try this. Actually a test circuit to check the RF modules before using them may save you a lot of time.
- Get the latest mySensor sketches from github.
- Use MYScontroller to monitor the messages the getway and the sensors exchange.
