  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 339.4k Views 37 Watching
  • cimba007C cimba007
    Just to add my 2cent .. I mainly use the LNA+PA ones (cheap from ebay) and complained some time for their "bad" performance.
    Just recently I noticed they are quite nice but .. RF24_PA_MIN is your friend! I got nearly zero packet-loss ~20m (one wall between) with RF24_PA_MIN. This might just be a subjective opinion but as they only cost 2-3$ a piece they are a good option (at least for me).
    Getting "genuin" chips for a reasonable price is very difficulty in germany.
    NeverDieN
    NeverDieN
    @cimba007
    I think I read somewhere in a different thread on this forum that the PA+LNA ones work better if powered from a lower voltage.
    cimba007C 1 Reply Last reply
    • karlheinz2000K
      karlheinz2000K
      karlheinz2000
      I ordered modules from ITEAD. They seem to have real nordic chips populated. Each module comes in paper box and ESD bag. The modules look like the cheap ebay stuff, but with 0402 components.
      With these modules I got rid of my issue with repeated messages.
      (https://forum.mysensors.org/topic/5588/multiple-messages-with-same-content-received)
      gohanG YveauxY 2 Replies Last reply
      • karlheinz2000K karlheinz2000
        @karlheinz2000
        did you check the chip print if it is genuine or fake? There are some guides if you search. Those modules are quite cheap and that makes me wonder.
        • karlheinz2000K
          karlheinz2000K
          karlheinz2000
          wrote on last edited by karlheinz2000
          #284
          I checked the print and it is different to the cheap ones. But, I got genuine NRF24 chips (just the ICs) from mouser and this print is similar to the cheap ones!!??
          Edit:
          The print quality of cheap modules is not as good as genuine one and more space between dot and first line.
          Genuine parts differ in little dot or square.
          ITEAD
          IC from Mouser
          Cheap Ali/ebay
          gohanG 1 Reply Last reply
            Edit:
            ITEAD
            IC from Mouser
            Cheap Ali/ebay
            wrote on last edited by gohan
            #285
            @karlheinz2000
            The first 2 definitely look similar, but the top left logo doesn't look genuine to me. But actually I don't care much about being genuine or not, the import thing is how they perform in terms of reliability and range
            NeverDieN 1 Reply Last reply
            • NeverDieN NeverDie
              @cimba007
              cimba007C
              cimba007C
              cimba007
              @NeverDie: In addition to using RF24_PA_MIN I power most of my nodes from 2x AA Alkaline Batteries .. so they have 2.2V - 3,0V VCC. This might contribute to my pretty good reception.
              Earlier nodes used 3,3V LDO in connection with lithium-ion batteries. So I can't say what really improved my reception the most ... lowering the voltage or putting the RF24_PA_MIN.
              parachutesjP NeverDieN 2 Replies Last reply
                parachutesjP
                parachutesjP
                parachutesj
                @gohan @karlheinz2000
                just for comparison, my "geniune" has also the same logo and the cheap one looks much "better" but one can see the bad production quality
                top one is GC supermarket, bottom genuine
                  NeverDieN
                  NeverDieN
                  Anyone know what the optimal voltage range is for running the PA_LNA versions? It would be good to know for future reference.
                    @karlheinz2000
                    NeverDieN
                    NeverDieN
                    @gohan said:
                    @karlheinz2000
                    Agreed. And it's not just the chip that will determine that, but rather the entire ball of wax.
                      YveauxY
                      YveauxY
                      @karlheinz2000 @parachutesj @gohan It appeared to be pointless to compare markings of nRF24L01+ IC's to determine if they are genuine or not.
                      Nordic is fabless and uses different fabs to produce their IC's. Each fab will have a different way of marking the chips.
                      I had a discussion with a Nordic representative in the past and even he could only say for sure if an IC was genuine or not by putting the part in X-Ray.
                      He had 3 different modules analyzed which I mailed to Nordic (China versions); all 3 appeared to be fakes...
                      The blob ones however are fake for sure.
                      • YveauxY Yveaux
                        @Yveaux
                        So basically we are stuck at trying modules from a supplier and share on the forum if they work or not, right?
                        • sundberg84S
                          Since its impossible to determine if a radio is genuine, fake or even working (power consumtion in sleep mode for example) is there a good sketch and/or PCB to test the radio module?
                          YveauxY 1 Reply Last reply
                            Another user wrote me a few days ago that there are modules that work best with 4.7uF cap while others need higher capacity, so that makes it also more difficult to make a test rig. In addition I don't remember if there is a way to get signal quality from NRF24 (but I don't think there is) to help the tests
                            • sundberg84S sundberg84
                              YveauxY
                              YveauxY
                              @sundberg84 not that I'm aware of. I tried to differentiate them based on power usage, but didn't get far.
                                @Yveaux
                                NeverDieN
                                NeverDieN
                                #295
                                @gohan said in Which are the *best* NRF24L01+ modules?:
                                @Yveaux
                                WRONG. If you read this thread (search for "nailed it"), and if you have an oscilliscope, I show what seems like a 100% reliable way to differentiate between genuine and fake chips.
                                  NeverDieN
                                  NeverDieN
                                  #296
                                  In this particular instance, if you're unsure which cap value to pick, pick the one with the biggest value. Overkill is better than underkill.
                                    @NeverDie
                                    He claimed to have run some tests and it came out that bigger isn't necessarily better.
                                    And I don't have an oscilloscope to test chips
                                    • NeverDieN
                                      NeverDieN
                                      When I tested the iTead modules (see earlier posts in this thread), they proved out to be genuine. Since you're unequipped to make a determination yourself, then if you're just wanting a simple answer, I suggest you try those.
                                      gohanG VItaria VMV 2 Replies Last reply
                                        @NeverDie
                                        I'll keep in mind for next purchase, tnx
                                          VItaria VMV
                                          VItaria VMV
                                          VItaria VM
                                          @NeverDie Hi there! So as a summary were you able to get a few trusted suppliers (sellers) to buy these modules from to get genuine ones?
                                          Is this one a good one to buy from.
                                          Aliexpres item
