  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 339.4k Views 37 Watching
  • parachutesjP parachutesj
    @doug I did some quick tests and I can confim that the modules work better with less voltage. I made best experience with 2.5-2.6V. However they are still much much worse than all others I have and not worth the hassle IMHO.
    NeverDieN
    NeverDieN
    Which other ones do you have that perform better? It would be very useful to know.
    parachutesjP 1 Reply Last reply
      @doug I do have the same ones bought at alice from the shop link. I also have issues and basically not functioning. I will try your "fix" and see how it goes. Did you do some shielding?
      Cheers,
      SJ
      SparkmanS
      SparkmanS
      Sparkman
      Cheers,
      SJ
      FWIW, I use these exact ones and I get very good range with them, without additional shielding.
      Cheers
      Al
      • NeverDieN NeverDie
        parachutesjP
        parachutesjP
        parachutesj
        @NeverDie
        I have the shielded ones from IC-Station:
        http://www.icstation.com/22dbm-100mw-nrf24l01ppalna-wireless-transmission-module-p-4677.html
        Back to the ones discussed here:
        When doing the basic test from earlier in this thread I am getting massive packet loss even if the modules are very close together. Ok, maybe it needs to be shielded, power too high etc and tried having them separated with no luck, still massive packet losses. Of course this is no scientific research.
        Without tweaking, modifications, special antenna orientation the shielded IC-Station ones just worked for me. I am not saying the others don't work, they just perform not in my setup very well.
        Also as a comparison, I have some cheep modules from Aliexpress they outperform the ampliefied ones (at least within the house):
        http://www.aliexpress.com/item/10PCS-LOT-NRF24L01-wireless-data-transmission-module-2-4G-the-NRF24L01-upgrade-version/1593276910.html
        Those modules look very poor build to be honest but seem to be ok. They came in one single back, some pins bent but nothing which couldn't be fixed. Minor packet losses and antenna orientation seems to be key.
        In comparison, I also bought some more expensive ones, which claim to be original:
        http://www.aliexpress.com/item/Free-shipping-Original-Genuine-NRF24L01-Wireless-Module-2-4G-wireless-communication-module-2-54mm-Interface-2/1781618813.html
        Those came in a nice protected box and look very well made.
        They work, I even think better than the others - but I already blew two of them. Not sure what went wrong :-(
        Just received some SMD ones which haven't been tested yet.
        • loralgL
          loralgL
          loralg
          Does anyone know if the NRF24L01 and the +PA+LNA modules can be mixed and matched? Will the regular modules and the longer range versions talk to each other? I would like to use one of the long range modules on my gateway in the house and on some sensors around my yard that are a fair distance from my house. But then to save some money I was wondering if I could use the regular modules around the rest of my house. My concern is if I use regular modules on the sensors in my house if they will still be able to communicate with the longer range version module I have on my gateway?
          A 1 Reply Last reply
          • loralgL loralg
            A
            A
            arraWX
            wrote on last edited by arraWX
            #265
            @loralg I successfully use a nRF24L01+PA+LNA on the gateway and regular nRF24L01+ on the sensors.
            There is a lot of information and hints available in the forum regarding the nRF24L01+PA+LNA . See e.g. here:
            https://forum.mysensors.org/topic/3719/nrf24l01-vs-nrf24l01-pa-lna/2
            In my case, however, the nRF24L01+PA+LNA works fine without any fix or special attention.
            • afenoA
              afenoA
              afeno
              What is the best way to measure the performance of one module at a given distance? I mean, how can I measure the number of packets lost?
              Does anybody already created a "performace test sketch" to perofrm a better test?
              NeverDieN 1 Reply Last reply
              • afenoA afeno
                NeverDieN
                NeverDieN
                I posted a sketch earlier in this thread.
                  alexsh1A
                  alexsh1A
                  alexsh1
                  How did you decrease the voltage on nrf24l01+ PA? I have a voltage regulator providing 3.3V.
                  afenoA parachutesjP 2 Replies Last reply
                  • dougD
                    dougD
                    doug
                    I have also found that the higher the voltage the more capacitance you need. Guess that makes sense. Still can't get them to work reliably at 3.3v though.
                    I am realising the important thing is a good power supply you need to choose the right regulator to ensure the voltage doesn't tank too far when the current spikes (~180mA). caps help to some degree and I have found ceramic are better than the aluminium ones.
                    I am now using a single cell lipo and 2 regulators one at 3.3 and one at 2.7 for the radio. Also easier to get a low IQ with 2 regulators rather than one big one.
                    I am still learning and need to start doing some playing with a greater range of modules. Especially as your experience of these is that they are pretty poor.
                    • alexsh1A alexsh1
                      afenoA
                      afenoA
                      afeno
                      @alexsh1
                      I'm wondering the same as @alexsh1 . How can I get 2.5-2.6V? There is an easy/cheap way to do it?
                      AWIA 1 Reply Last reply
                      • afenoA afeno
                        @alexsh1
                        AWIA
                        AWIA
                        AWI
                        @afeno The cheap way is a diode in the vcc line. The voltage drop over a normal silicon diode (i.e. 1N4001) is around 0.7V. This has proven to be a working solution.
                        • alexsh1A alexsh1
                          parachutesjP
                          parachutesjP
                          parachutesj
                          @alexsh1
                          as it was just a test, I used a table power supply to have the exact voltages.
                          • afenoA
                            afenoA
                            afeno
                            I'm creating a "ping" sketch to measure the % of packet lost using the tmrh20 library. I will post it once it is finished but it is just a modification of the "GettingStarted" sketch.
                            It is very simple:
                            • Node 1 send a value to node 2.
                            • Node 2 receive the message and send it back to node 1.
                            • Node 1 receive the message.
                            I'm measuring the number of packets lost and the turnaround time.
                            But doing some tests, I realised about something very strange that I don't understand...
                            Based on the sketch described above, both the node 1 and 2 are sending and receiving the same amount of data.
                            They both use the same commands to send and receive.
                            I have two hardware sensors/devices (let's call it A and B ) based on arduinos nano.
                            When I use A as Node 1 it gets 0.2% of packets lost. (B is used as Node 2)
                            When I use B as Node 1 it gets 15% of packets lost!! (A is used as Node 2)
                            Remember: Both nodes are sending and receiving the same amount of data.
                            I understand that the current, radio, noise, etc. might have an impact on the performance and range but why it is working fine on one way? And not in the other way? This is making me crazy. Both sensors are sending and receiving the same data. If one of them is not sending (or receiving) well, the performance still should be the same independent on who is acting as node 1 or 2.
                            What I am missing?
                            Thank you!
                            • afenoA afeno
                              It is very simple:
                              What I am missing?
                              Thank you!
                              NeverDieN
                              NeverDieN
                              @afeno
                              Interesting asymmetry.
                              This sounds basically the same as the sketch I posted earlier. Perhaps post a photo of the two nodes? Maybe something will jump out.
                              If you really want to solve it, try also
                              testing the packet loss on the individual links instead of only roundtrip. I suspect it will reveal something.
                              • afenoA
                                afenoA
                                afeno
                                Sorry for my ignorance... But how can I measure the packets lost on individual links?
                                Do you mean to check the packets lost in a 1-way trip? Only from node1 to node2?
                                • cimba007C
                                  cimba007C
                                  cimba007
                                  wrote on last edited by cimba007
                                  #276
                                  I thought it might be best to contribute to this thread rather then making a new one. I have some NRF24L01+ for like 2-3 years. Some of them are the normal ones and a few LNA+PA.
                                  The following explanation requires some "advanced" knowledge about the RF24 library and the test-sketch I added. Please forgive me as I was not able to write a more simple sketch and explanation.
                                  From day one I had problems using the modules at 250kbps with autoack. The Reception (RPD) was very poor and I had very high packet loss.
                                  For a few days now I have been tinkering with mysensors and just recently noticed .. wait what???
                                  250kbps + autoack is default.
                                  As mysensors is not ideal for testing modules I used another well known library:
                                  http://tmrh20.github.io/RF24/
                                  To get access to a very important register to debug autoack issues I modified "RF24.h" to get the low level functions public:
                                  **public:**
                                     * @name Low-level internal interface.
                                     *  Protected methods that address the chip directly.  Regular users cannot
                                     *  ever call these.  They are documented for completeness and for developers who
                                     *  may want to extend this class.
                                  After that I hooked up an single WS2812B-LED to pin 4 and tinkerd together a little test-sketch:
                                  0_1469476423782_getting_started_250kbps_minimum2.zip
                                  Note: You have to write the values 0 and 1 to EEPROM.Address 0 ONCE. 0 is the static pong back node and 1 is the mobile node with the WS2812B LED. This allows moving freely and check reception in your home.
                                  After writing the values to the eeprom you can comment out the code and don't have to worry when uploading the sketch to the "pongback"-node or the mobile "ping" node.
                                  //EEPROM.write(0,0); // 0 = PongBack
                                  If you don't want to use the WS2812B you have to remove some code but that should not be too hard.
                                  The important parts come now:
                                  settings[autoack] = 0;
                                  settings[retry] = 15;
                                  settings[delay_rf] = 15;
                                  Disabling autoack I could get an improved reading of RDP and very little PacketLoss. I now can cover distanced much larger like through 2-3 walls more then before.
                                  My modules are all powered from 3,3V dedicated LDO or 3V (2x AA) Battery and run @ 8MHz
                                  Long story short:
                                  If you have reception problems even after checking your Supply and even after trying the "ugly fix" and still got nowhere .. i suggest your try disabling auto ack. Although this it not intiutive on mysensors and would leave you vulnerable to packetloss I suggest you to test it out with this library (http://tmrh20.github.io/RF24/) and my example sketch.
                                  Sorry for not presenting a whole solution but I thought it might be worth to point people having reception problems into one possible "direction".
                                  PS: Autoack works fine on my modules if I switch to 1MBPS so this might be viable too.
                                    At current date, is there anybody that can suggest a place to buy good NRF24 modules? I live in Italy so probably US shops would be a little expensive on shipping cost.
                                      parachutesjP
                                      parachutesjP
                                      parachutesj
                                      @gohan
                                      I would not like to make a suggestion and rather reply my opinion on it:
                                      The worst experience I made was with the probably original ones (greenish on reference design). Not that the reception was bad but 4-5 already broke during testing and had to be exchanged.
                                      Therefore I buy the cheapest ones from GC supermarket or other big ALI-shops.
                                      However if you want a amplified version, I would spent the extra dollar and get a premium one. I posted it here somewhere and really made good experiences with it.
                                      gohanG 1 Reply Last reply
                                        @gohan
                                        @parachutesj
                                        I read your earlier post but after 7 months I was trying to get an update, you know things can change quickly :)
                                        • cimba007C
                                          cimba007C
                                          cimba007
                                          Just to add my 2cent .. I mainly use the LNA+PA ones (cheap from ebay) and complained some time for their "bad" performance.
                                          Just recently I noticed they are quite nice but .. RF24_PA_MIN is your friend! I got nearly zero packet-loss ~20m (one wall between) with RF24_PA_MIN. This might just be a subjective opinion but as they only cost 2-3$ a piece they are a good option (at least for me).
                                          Getting "genuin" chips for a reasonable price is very difficulty in germany.
