  3. my first weather station
19 Posts 4 Posters 12.9k Views 4 Watching
  • Andy PepA
    Andy PepA
    Andy Pep
    hello :)
    i would like to say a big thank you for this easy to understand libraries and tutorials :) great fun and habbit forming lol.
    so far i have put together a serial gateway , a uno with a bmp180 and a dht11 as a node.. and its all working nice and stable throu domoticz..
    i have found at the bottom of my garden an old maplin weather station tipping bucket rain gauge it was on some kind of 433 proto ..after imspection of the unit i gutted all of the old electronics ect out of it and gave it a good clean.. the plastics are in very good order and i managed to salvage the reed switch ..its a 5mil bucket aswell .
    with thanks to Salmoides and his solar powerd mini weatherstation i managed to cobble up some of his code to get my sensor pack running. now i would like to add the ability to use my raingauge hooked up to my uno wireing it up is not an issue but the code may as well be in klingon lol ..i am no good at all codeing .. i left that bahind in the 1980s and i have only just got back in to doing it .
    helppppppp
    ps has anyone in the uk seen this ... could be an addition aswel http://www.maplin.co.uk/p/maplin-replacement-anemometer-for-n25fr-n76nf
    hopefully
    andy
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      No pictures,......... it didn't happen... :innocent:
      RJ_Make
      • Andy PepA
        Andy PepA
        Andy Pep
        lol ok .. pictures it is :)
        • Andy PepA
          Andy PepA
          Andy Pep
          this is the recycled tipping bucket rain gauge i found at the bottom of my garden
          this is my sensor node .. fake uno bnp180 dht11 with a nrf radio .. all running an upcycled laptop batterys at 8volts 2c balenced lipos (home made)
          heat shrinked sensors with plenty of air flow and venting with nrf radio
          orignal radio and mcu for the rain gauge
          some of todays data
          see it did happen ...
          lol
          andy
          • Andy PepA
            Andy PepA
            Andy Pep
            went to the local thrift store today and picked up a archos win7 tablet for 10ukp its working but dog slow ..
            dual core 1.20 atom gig of ram wifi bluetooth usb 80 gig hdd but i may boot a compact flash ..
            so lastnight i did a 3 wipe format and a fresh install (win7 home basic) got it updated installed security and a fresh copy of domoticz.
            so now i have a display and control hub with cloud data backup working very well with mysensors serial gateway and my small sensor package....lol..
            i am loving this btw ...
            i have orderd the mcu and radio for the tipping bucket refurb i decided for that to go as a stand alone device ..
            i am now thinking of makeing an air and polloution sensor pack as i am near to a main road and i have breathing issues so some kind of local alarm would be good.
            what sensors would you use .. i know current useage are very high and i have opted for a enclosed box with a airpump ect so i can power it via the mains ..and inside .
            any advice on air and gas sensors would be great..
            cheers
            andy
            NeverDieN 1 Reply Last reply
            • Andy PepA Andy Pep
              cheers
              andy
              NeverDieN
              NeverDieN
              cheers
              andy
              Maybe consider 1. a CO sensor, and 2. a particulate sensor/counter, and 3. a sulfur sensor? You've probably heard of acid rain, which can come from sulfur pollutants becoming sulfuric acid when it comes into contact with water vapor. So, perhaps it's eating holes into your lungs.
              • NeverDieN
                NeverDieN
                Here's a project giving details of a particulate sensor made by Sharp:
                http://www.elektor-labs.com/project/air-pollution-level-display-solar-powered.14541.html
                • Andy PepA
                  Andy PepA
                  Andy Pep
                  cheers neverdie :)
                  seams like a good starting point ...i have found the sharp particle sensor cheap on ebay i have got a combined mq-135 that is a one sensor package that covers a lot of gas's and poloution
                  data sheet for the mq-135 is here https://www.olimex.com/Products/Components/Sensors/SNS-MQ135/resources/SNS-MQ135.pdf
                  it covers everything i need includeing sulphers :) and its one package that helps keep the power useage down .. just the heaters in the sensor pulls 300ma so it will have to be a heavy duty lipo and mains powerd.
                  just need to think of a sample chamber ..
                  cheerd for the link
                  andy
                  • NeverDieN
                    NeverDieN
                    I wonder if the results would be thrown off by pollen levels?
                    If I could track pollen levels cheaply and accurately, I'd be very interesting in doing so.
                    • Andy PepA
                      Andy PepA
                      Andy Pep
                      i just found this for the sharp sensor "Sensitivity
                      These results are true only when the sensor is used with factory settings. The variable resistor shouldn't be changed. Attach:output.jpg Δ The table demonstrates that for every 0.1 mg more of dust, the voltage increases by 0.5 Volts.
                      There are other environmental sensors in the market that can detect particles with the size of 1 micrometer (1�m). This scale means that even pollen grains, and mildew spores can be detected. There is no information about this on GP2Y1010AU's datasheet except that it is stated that it can detect cigarette smoke.
                      0.6 mg/m3 of dust doesn't seem much when National Institute for Occupational Safety and Health (NIOSH)'s recommended wood dust is 1 mg/m3 and used to be 5mg/m3 for softwoods. "
                      so yes it can do pollen ..and mould ...
                      looks like a good addition to my sensor network
                      more info here https://itp.nyu.edu/archive/physcomp-spring2014/sensors/Reports/GP2Y1010AU.html
                      with the mq-135 and a sharp sensor i can measure a lot of different gases and nasty stuff..
                      • NeverDieN
                        NeverDieN
                        Looks as though you'll need to measure temperature and humidity also in order to compensate for their effects on your mq-135 sensor.
                        I don't know enough about pollution to know whether that sensor is sensitive enough or not. i.e. is 10ppm sensitive enough, or does it need to measure parts per billion or parts per trillion? I have no idea what levels are considered safe versus unsafe. Perhaps you know already from research that you may have finished.
                        Good luck! I'd be interested to hear how it works out for you, regardless of whether it's success or failure.
                        • Andy PepA
                          Andy PepA
                          Andy Pep
                          cheers for your kind comments :) ..
                          yes its going to be a learning curve ..but after finding mysensors my mind has woken up :)
                          some more sensor data http://www.staceyk.org/airSensors/sensorsetup.php
                          you know in this day and age air polloution is someting to think off.. it effects everyone.. and mysensors could be a very usefull resorce for this kind of remote sensing :)
                          now i have to finish my tipping bucket rain gauge and deploy that :)
                          ..and now in the project list
                          make gateway box and add 433.
                          place mcu power radio in tipping bucket
                          assemble and test airqualty package
                          .. i am also thinking of useing a gyro mcu radio and power in to a 3d printed weather vane..
                          busy times ahead :)
                          regards
                          andy
                          • DrJeffD
                            DrJeffD
                            DrJeff
                            Got to love Sites like this one that challenge your brain and you have fun with physical items to show what you have been doing!
                            • Andy PepA
                              Andy PepA
                              Andy Pep
                              Indeed Drjeff ...
                              i have learned more in the past 4 weeks in starting this journey than i did for a year makeing flashy led stuff lol. mind you i am thinking of a neopixel display lol
                              and the good thing is i can give back..the data collected will be of use to someone if not myself :)
                              andy :)
                              • NeverDieN
                                NeverDieN
                                Have a look at this post: http://forum.mysensors.org/topic/147/air-quality-sensor/91
                                and it will likely save you a lot of time.
                                • Andy PepA
                                  Andy PepA
                                  Andy Pep
                                  cheers neverdie for the link to the post it has helped alot :)
                                  my sensors arrived today im just awaiting on some nrf and esp radios and im away ..
                                  tipping rain gauge retrofit will be started today or tomorrow :)
                                  regards
                                  andy
                                  • Andy PepA
                                    Andy PepA
                                    Andy Pep
                                    little update
                                    mq135 is now up and running ..need to be callabrated but its close enough untill i have finished testing it ... and thay do eat some power...300ma just for the sensor.
                                    i just need to get some potting compound for the rain gauge
                                    just added a pir sensor .
                                    this is getting addacting lol
                                    • Andy PepA
                                      Andy PepA
                                      Andy Pep
                                      slowly getting there........... just waiting on a slow boat from china with the rest of my parts :) almost.jpg
                                      • Andy PepA
                                        Andy PepA
                                        Andy Pep
                                        well thats cool .. my recycled tipping bucket works and seams to be close to accurate ..
