  3. pb compilation MEGA2560 + sketch W5100
6 Posts 3 Posters 3.9k Views 1 Watching
  • B
    B
    brakc
    I'm Mysensors user newbie ;-) and I want create Ethernet Gateway
    I use:
    • Arduino 1.6.4 on Yosemit
      --> IDE in System/Applications
      --> library are in /Volumes/Data/Documents/Arduino/Arduino-master (or Arduino-development)
    • MEGA2560
    • Ethernet Shield W5100 (like this : https://www.arduino.cc/en/Guide/ArduinoEthernetShield)
    • NRF24L01+ (1436AH)
    • MySensors Arduino Library v1.5
    Pin configuration:
    CE : 10
    CSN : 11
    MISO : 50
    MOSI : 51
    SCK : 52
    I uncommented #define SOFTSPI in MyConfig.h
    But compilation doesn't work. Can you help me please?
    EthernetGateway.ino:59:90: fatal error: DigitalIO.h: No such file or directory
    compilation terminated.
    For information:
    • I tryed master and development branch and it's the same
    • I tryed without Ethernet Shield W5100, same again
    Thank you for your help,
    Fabrice.
    mntlvrM 1 Reply Last reply
    • B brakc
      I use:
      • MEGA2560
      Pin configuration:
      CE : 10
      CSN : 11
      MISO : 50
      MOSI : 51
      SCK : 52
      For information:
      Fabrice.
      mntlvrM
      mntlvrM
      mntlvr
      I use:
      • MEGA2560
      Pin configuration:
      CE : 10
      CSN : 11
      MISO : 50
      MOSI : 51
      SCK : 52
      For information:
      Fabrice.
      Where is your "mysensor" library?
      Digital.io is in the utilities directory of "mysensors".
      • B
        B
        brakc
        DigitalIO
        /Volumes/Data/Documents/Arduino/libraries/Arduino-master/DigitalIO
        MySensors
        /Volumes/Data/Documents/Arduino/libraries/Arduino-master/MySensors
        I don't have utilities directory in MySensors
        For information, if I use EthernetGatway exemple in mysensor site : http://www.mysensors.org/build/ethernet_gateway
        If I comment "#include <DigitalIO.h>" I have a same problem with other include : MySigningNone.h, MyTransportRFM69.h ...
        Only SPI.h is OK
        Thanks for your help
          Development branch should be working for you.
          B 1 Reply Last reply
            B
            B
            brakc
            wrote on last edited by brakc
            Branch development is same :disappointed:
            MyConfig.h
            // Enable SOFTSPI for NRF24L01 when using the W5100 Ethernet module
            #define SOFTSPI
            #ifdef SOFTSPI
            	// Define the soft SPI pins used for NRF radio
            	const uint8_t SOFT_SPI_MISO_PIN = 50;
                const uint8_t SOFT_SPI_MOSI_PIN = 51;
                const uint8_t SOFT_SPI_SCK_PIN = 52;
            And I use default example EthernetGateway.ino
            Other suggestion please?
            • B
              B
              brakc
              compilation OK !!!
              In fact I move in directory /Volumes/Data/Documents/Arduino
              • DigitalIO
              • list itemMySensors (branch development)
              • list itemPinChangeInt
              ping OK
              but I have fail msg in serial : 0;0;3;0;9;radio init fail
              One suggestion please?
