  3. relay actuator fails to presenting itself
12 Posts 2 Posters 4.2k Views 1 Watching
  • Y Offline
    Y Offline
    yury
    wrote on last edited by yury
    I took Example sketch showing how to control physical relays and modified it a bit to use fixed NodeID in the sensor.
    It is not presenting it self in the gateway. I was trying to use MYSController to debug but the actuator node also was not appearing there.
    If I flush to the same hardware setup I use for actuator the sample code for switch it works like a charm. All radios communicates well.
    Really lost here...
    IDE 1.6.4
    my sensors 1-5
    nano Arduino board
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define RELAY_1 5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      #define NodeID 55
      gw.begin(incomingMessage, NodeID, false,5);
      gw.sendSketchInfo("Relay", "1.0");
        gw.present(NodeID , S_LIGHT);
        pinMode(RELAY_1, OUTPUT);
        digitalWrite(RELAY_1, gw.loadState(NodeID)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    actuator monitor log
    send: 55-55-5-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=fail:1.5
    send: 55-55-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:5
    sensor started, id=55, parent=5, distance=1
    send: 55-55-5-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=fail:Relay
    send: 55-55-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
    send: 55-55-5-0 s=55,c=0,t=3,pt=0,l=0,sg=0,st=fail:
    gateway monitor log
    • hekH Offline
      hekH Offline
      You seem to have had-coded parent to 5. Is that really correct?
      • Y Offline
        Y Offline
        yury
        Yes. I use switch as parent with ID ==5
        like this :
        #include <Bounce2.h>
        #define CHILD_ID 55
        #define BUTTON_PIN  5  // Arduino Digital I/O pin for button/reed switch
        Bounce debouncer = Bounce();
        int oldValue=-1;
        MyMessage msg(CHILD_ID,V_LIGHT);
          #define NodeID 5
          gw.begin(NULL, NodeID, false);
        //  gw.begin();
         // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          gw.present(CHILD_ID, S_LIGHT);
        • hekH Offline
          hekH Offline
          wrote on last edited by hek
          And what does the repeater (5) log look like?
          As you can see (ack fail) the node is having problem communicating with repeater.
          Also.. are you calling gw.process() in the loop-function on your repeater?
          • Y Offline
            Y Offline
            yury
            re:
            I do not use repeater. 5 is sample code for switch with hard coded ID == 5
            switch monitor log
            send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
            send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
            sensor started, id=5, parent=0, distance=1
            send: 5-5-0-0 s=55,c=0,t=3,pt=0,l=0,sg=0,st=ok:
            send: 5-5-0-0 s=55,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
            send: 5-5-0-0 s=55,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
            re:
            do I need to switch off somewhere repeater mode? I do not need repeater.
            I use
            gw.begin(incomingMessage, NodeID, false,5); in actuator code
            gw.begin(NULL, NodeID, false); in switch code.
            re:
            I added now...
              debouncer.update();
              // Get the update value
              int value = debouncer.read();
              if (value != oldValue) {
                 // Send in the new value
                 gw.send(msg.set(value==HIGH ? 1 : 0));
                 oldValue = value;
             gw.process();
            After I added gw.process(); log looks good but still no traeces of actuator in serial gateway.
            Actuator log:
            send: 55-55-5-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
            send: 55-55-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:5
            send: 55-55-5-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
            send: 55-55-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
            send: 55-55-5-0 s=55,c=0,t=3,pt=0,l=0,sg=0,st=ok:
            • hekH Offline
              hekH Offline
              @yury said:
              gw.begin(NULL, NodeID, false); <--
              You must enable repeater mode (3:rd argument) of your repeater, otherwise it won't relay message from your node 55 to your gateway.
              gw(0) <-- Repeater(5) <---- Node (55)
              • Y Offline
                Y Offline
                yury
                added as repeater node 5, but still no traces of the actuator 55 in the gateway.
                send: 5-5-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
                repeater started, id=5, parent=0, distance=1
                • hekH Offline
                  hekH Offline
                  Ok, What does the Node(55) log look like now then?
                  • Y Offline
                    Y Offline
                    yury
                    55 log looks llike this:
                    • hekH Offline
                      hekH Offline
                      Ok. Are you sure the repeater log above is correct? We can we that node 55 successfully sends its messages to it.
                      • Y Offline
                        Y Offline
                        yury
                        Hek, you are the best!
                        I plug all three things into my laptop to be able to see all logs and actuator (55) appeared in the serial gateway log
                        0;0;3;0;9;read: 5-5-0 s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
                        5;255;0;0;18;1.5
                        0;0;3;0;9;read: 5-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                        5;255;3;0;6;0
                        0;0;3;0;9;read: 55-5-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                        55;255;0;0;17;1.5
                        0;0;3;0;9;read: 55-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0:5
                        55;255;3;0;6;5
                        0;0;3;0;9;read: 5-5-0 s=55,c=0,t=3,pt=0,l=0,sg=0:
                        5;55;0;0;3;
                        0;0;3;0;9;read: 5-5-0 s=55,c=1,t=2,pt=2,l=2,sg=0:1
                        5;55;1;0;2;1
                        0;0;3;0;9;read: 55-5-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                        55;255;3;0;11;Relay
                        0;0;3;0;9;read: 55-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                        55;255;3;0;12;1.0
                        0;0;3;0;9;read: 55-5-0 s=55,c=0,t=3,pt=0,l=0,sg=0:
                        55;55;0;0;3;
                        repeater (5) log also showing it
                        read: 55-55-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                        send: 55-5-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                        read: 55-55-0 s=255,c=3,t=6,pt=1,l=1,sg=0:5
                        send: 55-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:5
                        read: 55-55-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                        send: 55-5-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                        read: 55-55-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                        send: 55-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                        read: 55-55-0 s=55,c=0,t=3,pt=0,l=0,sg=0:
                        send: 55-5-0-0 s=55,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                        understand something wrong was with external power supply.
                        the only thing left, actuator(55) not receiving from repeater(5) which is the switch sensor, messages. These two entries
                        not getting to actuator...
                        • hekH Offline
                          hekH Offline
                          There was a bug fix a couple of days ago fixing problem when routing from repeater to a node. Please make sure that you run the latest library code.
