  3. relay actuator fails to presenting itself
12 Posts 2 Posters 4.3k Views 1 Watching
    You seem to have had-coded parent to 5. Is that really correct?
    • Y
      Y
      yury
      Yes. I use switch as parent with ID ==5
      like this :
      #define CHILD_ID 55
      #define BUTTON_PIN  5  // Arduino Digital I/O pin for button/reed switch
      Bounce debouncer = Bounce();
      int oldValue=-1;
        #define NodeID 5
        gw.begin(NULL, NodeID, false);
      //  gw.begin();
       // Setup the button
        pinMode(BUTTON_PIN,INPUT);
        // Activate internal pull-up
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
        gw.present(CHILD_ID, S_LIGHT);
        wrote on last edited by hek
        And what does the repeater (5) log look like?
        As you can see (ack fail) the node is having problem communicating with repeater.
        Also.. are you calling gw.process() in the loop-function on your repeater?
        • Y
          Y
          yury
          wrote on last edited by yury
          re:
          I do not use repeater. 5 is sample code for switch with hard coded ID == 5
          switch monitor log
          send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
          send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          sensor started, id=5, parent=0, distance=1
          send: 5-5-0-0 s=55,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          send: 5-5-0-0 s=55,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
          send: 5-5-0-0 s=55,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
          re:
          do I need to switch off somewhere repeater mode? I do not need repeater.
          I use
          gw.begin(incomingMessage, NodeID, false,5); in actuator code
          gw.begin(NULL, NodeID, false); in switch code.
          re:
          I added now...
            debouncer.update();
            // Get the update value
            int value = debouncer.read();
            if (value != oldValue) {
               // Send in the new value
               oldValue = value;
          After I added gw.process(); log looks good but still no traeces of actuator in serial gateway.
          Actuator log:
          send: 55-55-5-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
          send: 55-55-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:5
          sensor started, id=55, parent=5, distance=1
          send: 55-55-5-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
          send: 55-55-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
          send: 55-55-5-0 s=55,c=0,t=3,pt=0,l=0,sg=0,st=ok:
            @yury said:
            gw.begin(NULL, NodeID, false); <--
            You must enable repeater mode (3:rd argument) of your repeater, otherwise it won't relay message from your node 55 to your gateway.
            gw(0) <-- Repeater(5) <---- Node (55)
            • Y
              Y
              yury
              added as repeater node 5, but still no traces of the actuator 55 in the gateway.
              send: 5-5-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
              repeater started, id=5, parent=0, distance=1
                Ok, What does the Node(55) log look like now then?
                • Y
                  Y
                  yury
                  55 log looks llike this:
                    Ok. Are you sure the repeater log above is correct? We can we that node 55 successfully sends its messages to it.
                    • Y
                      Y
                      yury
                      Hek, you are the best!
                      I plug all three things into my laptop to be able to see all logs and actuator (55) appeared in the serial gateway log
                      0;0;3;0;9;read: 5-5-0 s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
                      5;255;0;0;18;1.5
                      0;0;3;0;9;read: 5-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      5;255;3;0;6;0
                      0;0;3;0;9;read: 55-5-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                      55;255;0;0;17;1.5
                      0;0;3;0;9;read: 55-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0:5
                      55;255;3;0;6;5
                      0;0;3;0;9;read: 5-5-0 s=55,c=0,t=3,pt=0,l=0,sg=0:
                      5;55;0;0;3;
                      0;0;3;0;9;read: 5-5-0 s=55,c=1,t=2,pt=2,l=2,sg=0:1
                      5;55;1;0;2;1
                      0;0;3;0;9;read: 55-5-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                      55;255;3;0;11;Relay
                      0;0;3;0;9;read: 55-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                      55;255;3;0;12;1.0
                      0;0;3;0;9;read: 55-5-0 s=55,c=0,t=3,pt=0,l=0,sg=0:
                      55;55;0;0;3;
                      repeater (5) log also showing it
                      read: 55-55-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                      send: 55-5-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                      read: 55-55-0 s=255,c=3,t=6,pt=1,l=1,sg=0:5
                      send: 55-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:5
                      read: 55-55-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                      send: 55-5-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                      read: 55-55-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                      send: 55-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                      read: 55-55-0 s=55,c=0,t=3,pt=0,l=0,sg=0:
                      send: 55-5-0-0 s=55,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      understand something wrong was with external power supply.
                      the only thing left, actuator(55) not receiving from repeater(5) which is the switch sensor, messages. These two entries
                      not getting to actuator...
                        There was a bug fix a couple of days ago fixing problem when routing from repeater to a node. Please make sure that you run the latest library code.
