  3. Battery Sensor v 1.0 PCB
56 Posts 9 Posters 44.4k Views 3 Watching
  • BSoftB BSoft
    @clippermiami
    You can still use the step-up, connect the capacitor in parallel between VCCout (regulator) and ground.
    Or better, connect the capacitor between VCC-GND on the NRF24 (the closest you get to nRF24 is better).
    If you still get transmission problems and if possible, bypass the step-up and keep the capacitor on and check again.
    clippermiamiC
    clippermiamiC
    clippermiami
    @BSoft re: Capacitor Bypass. I assume you are talking about the 4.7uFd cap between the Vcc and Gnd on the radio? If so its been installed from the get-go, its part of the design and is within millimeters of the NRF connector.
    BSoftB 1 Reply Last reply
    • BSoftB
      BSoftB
      BSoft
      Ok, since sma antenna is more power demanding and works ok, maybe capacitor isn't solution.
      But i get better than 30 feet on zigzag antenna, maybe you have a not so perfect pcb unit (nRF). It is nice and residue clean?
      clippermiamiC 1 Reply Last reply
      • BSoftB BSoft
        clippermiamiC
        clippermiamiC
        clippermiami
        @BSoft I've tried several different ones, theyt all look clean, no "gunk" or anything. I even tried taking it off the board and putting it on a extension cable, same results.Yeah, 30 feet seems a bit of a drag :)
        john
        • clippermiamiC clippermiami
          BSoftB
          BSoftB
          BSoft
          Yes it is!
          Sorry i wasn't aware of 4.7uF presence.
          You could add more since it as been reported as better (220µF), check here: link text
          • BSoftB BSoft
            Yes it is!
            clippermiamiC
            clippermiamiC
            clippermiami
            @BSoft Interesting discussion. Bottom line seem to be that 4.7 uF doesn't do much, the more the merrier then.
            • Z
              Z
              Zeph
              It's not just about capacity, it's about using a capacitor with low ESR.
              • Z
                Z
                Zeph
                Are you trying different orientations of the antenna? While I've not seen any spec's for the cheap module antenna ("7" shape or zigzag), I think I recall seeing reference to a pattern with two peak lobes and two nulls for another nRF24L01+ or nRF51822 based module. It's unlikely that the antenna is omnidirectional. (I don't know if the antenna also has polarization issues, another possibility).
                • Z Zeph
                  clippermiamiC
                  clippermiamiC
                  clippermiami
                  @Zeph I changed orientation buy door of "incidentally" , I held the unit up over my head to see if I got updates and I did, more often than just sitting on the counter but still not all the time. In this case the antennas would have been vertical rather than horizontal. Puzzling to be sure.
                  • axillentA
                    axillentA
                    axillent
                    about capacitor for radio. Attached you can see picture from one of my successful project
                    capacitor is tantalum 22uF soldered directly to pins of the module, from the side of module PCB
                    you can see capacitor as a small yellow box on top of the 8 pin radio connector
                    sense and drive
                    • axillentA axillent
                      clippermiamiC
                      clippermiamiC
                      clippermiami
                      @axillent Do you have a feel for the range of this rig? If this is the answer I'll get the capacitor and mod every radio :)
                      My Gateway has the SMA antenna on it and is less than 30 feet, and one interior wall, from the sensor and it doesn't work. When I bring the sensor to within about 10-12 feet it works every time but out at 20+ feet it fails almost every time. Its hard to believe that there is so little range
                      I've tried a number of things:
                      (a) several different radios - no change
                      (b) remove the radio and place it on a 8 inch cable to get away from the ground plane - no change;
                      (c) jumpered around the up-regulator (i.e. everything direct connected to battery) - no change;
                      (d) radio with SMA antenna - works every time but the battery consumption goes through the roof. In 12 hours with the SMA antenna the battery dropped 0.12 V versus 0.04 V in 24 hours with the regular radio. The AMP on the antenna version consumes a lot of juice.
                      Puzzlement :)
                      axillentA 1 Reply Last reply
                        Puzzlement :)
                        axillentA
                        axillentA
                        axillent
                        @clippermiami My distances are not too long, Just measured - this particular device is ranged 5m with one wall on the way to gateway
                        you have to distinguish radio with SMA **without **PA&LNA and radio **with **SMA and with PA&LNA
                        last one have an additional chip to amplify radio signal both way
                        radio without PA & LNA with SMA can sometimes be worse comparing to radio with PCB antenna
                        it depends on how well external antenna is aligned by frequency and impedance
                        List of your actions have radio channel tuning missed
                        sense and drive
                          clippermiamiC
                          clippermiamiC
                          clippermiami
                          wrote on last edited by clippermiami
                          #32
                          @axillent This SMA unit has the PA on it. The radio channel is the default for everything.
                          You distance is similar to mine, about 4.5-5 meters with one wall and it works. Beyond that NADA :)
                            axillentA
                            axillentA
                            axillent
                            wrote on last edited by axillent
                            #33
                            @clippermiami
                            works and works the best way are different things, If you live far from big cities probably it make no sense.
                            Otherwise it is recommended to run network scan from RF24 examples to find less busy channel at your location.
                            sense and drive
                              @clippermiami
                              clippermiamiC
                              clippermiamiC
                              clippermiami
                              @axillent The wireless channel is the one thing I hadn't investigated as yet so i will. I suppose it could be congested around here.
                              • clippermiamiC
                                clippermiamiC
                                clippermiami
                                I ran the scanner but got page after page of:
                                     RF24/examples/scanner/
                                     Scanning all available frequencies...Scan completed.
                                My radio is configured exactly as described although I will admit i just loaded the sketch to the sensor board and ran it on there rather than set up a special build just for that.
                                  axillentA
                                  axillentA
                                  axillent
                                  wrote on last edited by hek
                                  #36
                                  @clippermiami do not knew why but there are a few versions of this example
                                  try this one
                                  sorry, do not knew how to insert a code here
                                   Copyright (C) 2011 James Coliz, Jr. <maniacbug@ymail.com>
                                   Copyright (c) 2012 Greg Copeland
                                   This program is free software; you can redistribute it and/or
                                   modify it under the terms of the GNU General Public License
                                   version 2 as published by the Free Software Foundation.
                                   * Channel scanner
                                   * Example to detect interference on the various channels available.
                                   * This is a good diagnostic tool to check whether you're picking a
                                   * good channel for your application.
                                   * Inspired by cpixip.
                                   * See http://arduino.cc/forum/index.php/topic,54795.0.html
                                  #include "RF24.h"
                                  #include "printf.h"
                                  // Only display active frequencies
                                  static const bool activeOnly = true ;
                                  // Hardware configuration
                                  // Set up nRF24L01 radio on SPI bus plus pins 8 & 9
                                  RF24 radio(9,10);
                                  // Channel info
                                  const short num_channels = 128;
                                  short values[num_channels];
                                  uint8_t signalMeter[55] ;
                                  // Setup
                                  void setup(void)
                                    // Print preamble
                                    Serial.begin(115200);
                                    printf_begin();
                                    printf("\n\rRF24/examples/scanner/\n\r");
                                    // Setup and configure rf radio
                                    radio.begin();
                                    radio.powerUp() ;
                                    radio.setAutoAck(false);
                                    // Get into standby mode
                                    radio.openReadingPipe( 0, 0xFFFFFFFFFFULL ) ;
                                    //  radio.setDataRate( RF24_250KBPS ) ; // may fallback to 1Mbps
                                    radio.setDataRate( RF24_1MBPS ) ; // may fallback to 1Mbps
                                    radio.startListening() ;
                                    radio.stopListening() ;
                                  // Loop
                                  void loop(void)
                                    // Clear measurement values
                                    memset( values, 0x00, num_channels ) ;
                                    printf( "Scanning all available frequencies..." ) ;
                                    // Repeatedly scan multiple channels
                                    for( int channel=0 ; channel < num_channels; channel++ ) {
                                      radio.setChannel( channel ) ;
                                      // Amplify the signal based on carrier bandwidth
                                      int ampFactor ;
                                      for( int amp=0; amp <= 300; amp++ ) {
                                        // Alternate data rates
                                        ampFactor = amp%3 ;
                                        switch( ampFactor ) {
                                        case 0:
                                  	break ;
                                        case 1:
                                  	break ;
                                        default:
                                  	radio.setDataRate( RF24_2MBPS ) ;
                                  	break ;
                                        // Listen for carrier
                                        ampFactor++ ;
                                        delayMicroseconds( 6 - ampFactor ) ;
                                        // Was carrier detected? If so, signal level based on bandwidth
                                        if( radio.testRPD() ) {
                                  	values[channel] += ampFactor ;
                                    // Now display our results
                                    printf( "Scan completed.\r\n" ) ;
                                      if( !activeOnly || (activeOnly && values[channel] > 0) ) {
                                        memset( signalMeter, '*', min( values[channel], 54 ) ) ;
                                        signalMeter[min(values[channel], 54)] = 0x00 ;
                                        printf( "%03d (%4dMhz): %02d - %s\r\n",
                                  	      channel,
                                  	      2400+channel,
                                  	      values[channel],
                                  	      signalMeter ) ;
                                        // Reset the scanned value since its already beend displayed
                                        values[channel] = 0 ;
                                  // vim:ai:cin:sts=2 sw=2 ft=cpp
                                  sense and drive
                                    try this one
                                     * Channel scanner
                                    #include "RF24.h"
                                    #include "printf.h"
                                    RF24 radio(9,10);
                                    // Channel info
                                    // Setup
                                    void setup(void)
                                      // Print preamble
                                      printf_begin();
                                      radio.begin();
                                      radio.powerUp() ;
                                    // Loop
                                    void loop(void)
                                        int ampFactor ;
                                          ampFactor = amp%3 ;
                                          case 0:
                                    	break ;
                                          case 1:
                                    	break ;
                                          default:
                                    	break ;
                                          ampFactor++ ;
                                    	      channel,
                                    	      2400+channel,
                                    	      values[channel],
                                    	      signalMeter ) ;
                                    clippermiamiC
                                    clippermiamiC
                                    clippermiami
                                    @axillent First thing I see is that this version has the radio on pins 8,9 whereas the version I used has it on pins 9,10 which is where it is in my hardware.
                                      axillentA
                                      axillentA
                                      axillent
                                      @clippermiami That is a good point. But something tells me that you do need an assistance to adjust this code to your hardware :)
                                      sense and drive
                                        clippermiamiC
                                        clippermiamiC
                                        clippermiami
                                        @axillent I won't deny that, but it seems simple enough. :)
                                        • clippermiamiC
                                          clippermiamiC
                                          clippermiami
                                          #40
                                          So i breadboarded a Nano and a NRFL2401 with a PA and antenna, uploaded the scanner sketch and this is what I got: I'm using the default radio channel from the distribution library.
                                           000 (2400Mhz): 96 - ******************************************************
                                           001 (2401Mhz): 100 - ******************************************************
                                           002 (2402Mhz): 95 - ******************************************************
                                           003 (2403Mhz): 99 - ******************************************************
                                           004 (2404Mhz): 98 - ******************************************************
                                           005 (2405Mhz): 104 - ******************************************************
                                           006 (2406Mhz): 91 - ******************************************************
                                           007 (2407Mhz): 95 - ******************************************************
                                           008 (2408Mhz): 98 - ******************************************************
                                           009 (2409Mhz): 96 - ******************************************************
                                           010 (2410Mhz): 96 - ******************************************************
                                           011 (2411Mhz): 86 - ******************************************************
                                           012 (2412Mhz): 89 - ******************************************************
                                           013 (2413Mhz): 94 - ******************************************************
                                           014 (2414Mhz): 95 - ******************************************************
                                           015 (2415Mhz): 92 - ******************************************************
                                           016 (2416Mhz): 93 - ******************************************************
                                           017 (2417Mhz): 92 - ******************************************************
                                           018 (2418Mhz): 99 - ******************************************************
                                           019 (2419Mhz): 85 - ******************************************************
                                           020 (2420Mhz): 99 - ******************************************************
                                           021 (2421Mhz): 96 - ******************************************************
                                           022 (2422Mhz): 90 - ******************************************************
                                           023 (2423Mhz): 98 - ******************************************************
                                           024 (2424Mhz): 85 - ******************************************************
                                           025 (2425Mhz): 99 - ******************************************************
                                           026 (2426Mhz): 100 - ******************************************************
                                           027 (2427Mhz): 95 - ******************************************************
                                           028 (2428Mhz): 95 - ******************************************************
                                           029 (2429Mhz): 90 - ******************************************************
                                           030 (2430Mhz): 95 - ******************************************************
                                           031 (2431Mhz): 96 - ******************************************************
                                           032 (2432Mhz): 95 - ******************************************************
                                           033 (2433Mhz): 91 - ******************************************************
                                           034 (2434Mhz): 93 - ******************************************************
                                           035 (2435Mhz): 97 - ******************************************************
                                           036 (2436Mhz): 104 - ******************************************************
                                           037 (2437Mhz): 99 - ******************************************************
                                           038 (2438Mhz): 92 - ******************************************************
                                           039 (2439Mhz): 96 - ******************************************************
                                           040 (2440Mhz): 94 - ******************************************************
                                           041 (2441Mhz): 100 - ******************************************************
                                           042 (2442Mhz): 92 - ******************************************************
                                           043 (2443Mhz): 100 - ******************************************************
                                           044 (2444Mhz): 110 - ******************************************************
                                           045 (2445Mhz): 92 - ******************************************************
                                           046 (2446Mhz): 111 - ******************************************************
                                           047 (2447Mhz): 99 - ******************************************************
                                           048 (2448Mhz): 98 - ******************************************************
                                           049 (2449Mhz): 93 - ******************************************************
                                           050 (2450Mhz): 97 - ******************************************************
                                           051 (2451Mhz): 99 - ******************************************************
                                           052 (2452Mhz): 93 - ******************************************************
                                           053 (2453Mhz): 96 - ******************************************************
                                           054 (2454Mhz): 93 - ******************************************************
                                           055 (2455Mhz): 94 - ******************************************************
                                           056 (2456Mhz): 106 - ******************************************************
                                           057 (2457Mhz): 101 - ******************************************************
                                           058 (2458Mhz): 94 - ******************************************************
                                           059 (2459Mhz): 106 - ******************************************************
                                           060 (2460Mhz): 91 - ******************************************************
                                           061 (2461Mhz): 96 - ******************************************************
                                           062 (2462Mhz): 98 - ******************************************************
                                           063 (2463Mhz): 100 - ******************************************************
                                           064 (2464Mhz): 107 - ******************************************************
                                           065 (2465Mhz): 101 - ******************************************************
                                           066 (2466Mhz): 93 - ******************************************************
                                           067 (2467Mhz): 90 - ******************************************************
                                           068 (2468Mhz): 102 - ******************************************************
                                           069 (2469Mhz): 103 - ******************************************************
                                           070 (2470Mhz): 95 - ******************************************************
                                           071 (2471Mhz): 102 - ******************************************************
                                           072 (2472Mhz): 99 - ******************************************************
                                           073 (2473Mhz): 94 - ******************************************************
                                           074 (2474Mhz): 97 - ******************************************************
                                           075 (2475Mhz): 105 - ******************************************************
                                           076 (2476Mhz): 97 - ******************************************************
                                           077 (2477Mhz): 92 - ******************************************************
                                           078 (2478Mhz): 103 - ******************************************************
                                           079 (2479Mhz): 94 - ******************************************************
                                           080 (2480Mhz): 98 - ******************************************************
                                           081 (2481Mhz): 99 - ******************************************************
                                           082 (2482Mhz): 103 - ******************************************************
                                           083 (2483Mhz): 98 - ******************************************************
                                           084 (2484Mhz): 89 - ******************************************************
                                           085 (2485Mhz): 97 - ******************************************************
                                           086 (2486Mhz): 94 - ******************************************************
                                           087 (2487Mhz): 97 - ******************************************************
                                           088 (2488Mhz): 92 - ******************************************************
                                           089 (2489Mhz): 101 - ******************************************************
                                           090 (2490Mhz): 98 - ******************************************************
                                           091 (2491Mhz): 99 - ******************************************************
                                           092 (2492Mhz): 92 - ******************************************************
                                           093 (2493Mhz): 88 - ******************************************************
                                           094 (2494Mhz): 95 - ******************************************************
                                           095 (2495Mhz): 92 - ******************************************************
                                           096 (2496Mhz): 95 - ******************************************************
                                           097 (2497Mhz): 95 - ******************************************************
                                           098 (2498Mhz): 90 - ******************************************************
                                           099 (2499Mhz): 100 - ******************************************************
                                           100 (2500Mhz): 94 - ******************************************************
                                           101 (2501Mhz): 107 - ******************************************************
                                           102 (2502Mhz): 90 - ******************************************************
                                           103 (2503Mhz): 95 - ******************************************************
                                           104 (2504Mhz): 105 - ******************************************************
                                           105 (2505Mhz): 99 - ******************************************************
                                           106 (2506Mhz): 101 - ******************************************************
                                           107 (2507Mhz): 100 - ******************************************************
                                           108 (2508Mhz): 103 - ******************************************************
                                           109 (2509Mhz): 99 - ******************************************************
                                           110 (2510Mhz): 99 - ******************************************************
                                           111 (2511Mhz): 92 - ******************************************************
                                           112 (2512Mhz): 90 - ******************************************************
                                           113 (2513Mhz): 96 - ******************************************************
                                           114 (2514Mhz): 102 - ******************************************************
                                           115 (2515Mhz): 96 - ******************************************************
                                           116 (2516Mhz): 91 - ******************************************************
                                           117 (2517Mhz): 98 - ******************************************************
                                           118 (2518Mhz): 95 - ******************************************************
                                           119 (2519Mhz): 101 - ******************************************************
                                           120 (2520Mhz): 104 - ******************************************************
                                           121 (2521Mhz): 93 - ******************************************************
                                           122 (2522Mhz): 98 - ******************************************************
                                           123 (2523Mhz): 98 - ******************************************************
                                           124 (2524Mhz): 96 - ******************************************************
                                           125 (2525Mhz): 95 - ******************************************************
                                           126 (2526Mhz): 94 - ******************************************************
                                           127 (2527Mhz): 96 - ******************************************************
                                          Which does not look much like the display at the reference: http://arduino.cc/forum/index.php/topic,54795.0.html
                                          and i'm not sure what its telling me other than some relative signal level data. Perhaps someone could help me interpret this :)
                                          Updagte:
                                          As it continues to run it shows significantly different values over time, some reaching as high as
                                           063 (2463Mhz): 84 - ******************************************************
                                           064 (2464Mhz): 89 - ******************************************************
                                           065 (2465Mhz): 97 - ******************************************************
                                           066 (2466Mhz): 201 - ******************************************************
                                           067 (2467Mhz): 252 - ******************************************************
                                           068 (2468Mhz): 300 - ******************************************************
                                           069 (2469Mhz): 284 - ******************************************************
