  3. My own board (50mm x 30mm)
133 Posts 22 Posters 122.9k Views 21 Watching
  • scalzS
    scalzS
    hi.
    nice boards guys!
    yep, so lot meditation for tiny things :laughing: I am still asking myself on some points..
    in my case I choosed solderpads. not difficult to change and it is small. but not as easy to use as jumpers. I think jumpers are useful for proto stage but then in real you won't need it and it will take place.
    I was thinking about having pinout for breakout too. but what if sellers change or stop boards. I don't think so, but it could happen...and it increase overall size too.
    but I understand your vision of your board (mine is full smd). I like your ideas too!
    See you soon and good luck for meditation :smile:
    • NeverDieN NeverDie
      @ahhk said:
      This is my Case-Prototype - very flexible and easy to manufacture:
      Why do you say it's "easy" to manufacture?
      A
      A
      ahhk
      wrote on last edited by ahhk
      #22
      I put a wooden 8mm-plate on my cnc and mill the parts :D Very cheap and fast made....
      @GERT: I have a cnc at home. i built it several years ago ;) Take a look if u want: http://www.rc-network.de/forum/showthread.php/304809-CNC-FRÄSMASCHINE-OPEN-SOURCE-PROJEKT/page11
      Power
      I have only 2 possible variants in mind:
      • Battery with or without step up (plugin boost converter)
      • USB-Powered
      For the last one i wanted to use these pcbs - glued into the case or plugged instead of the step-up module:
      http://www.ebay.de/itm/301652467812?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      Or i install a small connector into the case and solder 2 wires to the board. Something like this http://www.ebay.de/itm/2-Pair-DC-Power-Female-Male-Connector-Cable-Pigtail-Plug-Wire-CCTV-camera-White-/252099946337?hash=item3ab253e761
      Everything should stay "easy&simple" and i think, once installed, the sensor will "hang around" for a year or longer....
      Sensors
      I checked 3 properties to find the correct sensor:
      • minimum allowed voltage
      • time for a measurement
      • price
      So, the htu21d was the winner for me - works great and fast after a little optimization of the arduino-library for this (replaced delay with gw.sleep)...
      • A
        A
        ahhk
        #23
        Next variant. Less flexible, but flexible enough. Boardsize now 50x30mm
        It's only one pcb now and you can connect
        • 5x sensors (digital or analog)
        • 1x I2C and 3x sensors (digital or analog)
        Step-up can be soldered to the bottom.
        What do you think?
        • GertSandersG
          GertSandersG
          GertSanders
          hi Andreas,
          What is the intention of TEMP4 and TEMP5 connectors ? I see that you pull up SCL and SDA, but all these connectors can do now is give VCC and GND on pin 1.
          For TEMP1->3, it depends on how the sensor actually works. With Light Dependant resistor there is no issue. For other sensors (TMP36), a resistor pulling up to VCC would be a problem. A switch would be OK between pin 1 and 3 (GND) of those connectors. What is the usecase ?
          I have a atmega1284 based design, which is not yet shared on OSHPark. The version I made has the NRF24 connector in the wrong direction (but this is still useful). However, I can not close the case with the NRF24 in place. It was made for a Hammond 1593N case (the transparent blue type, very cool):
          I used the case for the Arduino Due (bought this from Mouser).
          I now corrected the orientation of the NRF24 connector but this not put this on OSHPark, because I can live with the mistake I made. Many ports on this one. But only works on 6-24V input. The power converters are from TRACO (1 for 5V, 1 for 3V3). It has 64KB EEPROM and RTC. Level converters for 5v->3V3 on I2C (so 2 I2C ports actually) and most pins are brought out together with 5V and GND.
          The point here is that adding resistors to the three pin connectors is not really necessary. But it is nice to have signal-VCC-GND on three wires each time.
          I think I will order the 1593K case next (to see what can be done with that), nice little box.
          • GertSandersG
            GertSandersG
            GertSanders
            @Andreas: Very impressive CNC machine !!!
            • A
              A
              ahhk
              #26
              Hi Gert,
              thx for the cnc-flowers :D
              Sensors
              I thougt about the different nodes i will have later. The biggest node will have 5x DS18B20 - so i really dont need more than 5 "ports" to connect sensors. I changed them to the analog-pins of the arduino, because i can use them as digital and analog ports too...
              Temp4 and Temp5 can be used as I2C ("horizontal") OR as Temp4 and Temp5 for DS18B20 ("vertical"). See top left corner of the board. I think it is very flexbile to not solder the resistors (disconnect VCC) or to solder a wire instead of the resistor (vcc to pad). In this way i can connect PIRs, DS18B20, Analog-sensors and so on....i just solder the parts i need for the sensors...
              Only thing: I cannot use I2C AND Temp4 / Temp5 at the same time, because A4 and A5 are SCL and SDA too....
              I hope you understand what i mean and try to reach...
              Btw: Jumper-pins are not a must, if i want, i connect the sensors via wire to the pads, or solder them onto the pads directly....
              Greetings
              Andreas
              • GertSandersG
                GertSandersG
                GertSanders
                wrote on last edited by GertSanders
                #27
                A 3D view of my lastest board :+1:
                upload-075a0c14-d55f-4c52-946c-8962127de3fb
                upload-9c879fc0-e05c-4eb7-91f7-5a2d307244fb
                upload-c4bb585c-691d-4211-87d7-ac5b78906a26
                upload-6505f209-0883-45ac-999b-0ae1b85be314
                Tool used: http://mayhewlabs.com/3dpcb
                So cool to see a 3D render, very fluid when moving around :-)
                • A
                  A
                  ahhk
                  3d-view is really nice. I dont know why, but my gerber files dont work. Board is BIIIIIIIGGG and without holes :(
                  I asked in the hardware-forum, if there are any errors in my design. (http://forum.mysensors.org/topic/2042/errors-in-pcb-design)
                  I must finish this and order my boards now ;) Otherwise i will never find an end....
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    Getting close to final layout myself ....
                    • A ahhk
                      i thougt a long time about placing such a booster on the pcb. Its quite difficult to find a good(!) booster. Lots of the cheaper booster draw a lot of current (quiescent current) - like the one behind your link. I tested only 2 until today.
                      This one: http://www.exp-tech.de/pololu-3-3v-step-up-spannungsregler-u1v10f3?gclid=CPmll6rH0ccCFRI6Gwod884Lxg
                      and this one: http://www.exp-tech.de/sparkfun-ncp1402-3-3v-step-up-breakout-prt-10967?gclid=CPCv55_H0ccCFUu6GwodKDUHwA
                      Current consumption differs approx 30uA between those 2 (red 70uA, green 100uA in sleepmode with sensors etc)...
                      Did you check current-consumption of your booster?
                      Actually i am changing the board size to 50mmx24mm - its a lot cheaper to order from fusionpcb (seeedstudio)...
                      Thats a lot.
                      Greetings
                      [▲QUICK EDIT]
                      Something like this? Booster soldered vertical....In this way you must select with the solder jumper how to power the board (battery direct or via booster)...schema.png board.png
                      maciejka
                      Thats a lot.
                      Greetings
                      [▲QUICK EDIT]
                      Hi ahhk,
                      Can You share brd files for this version? Thanks.
                      Maciej
                      • A
                        A
                        ahhk
                        sure i will share the brd-file and schemativ. No problem. But let me first build one working sensor. I think i will order the pcbs this weekend, because this looks good too =>
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          #32
                          Done, this will be sent to the PCB makers:
                          Top:
                          Bottom:
                          • scalzS
                            scalzS
                            each boards are nice, good work :wink:
                            • A
                              A
                              ahhk
                              PCBs are ordered (shenzen2u)....i am very curious about it :)
                              • A
                                A
                                ahhk
                                Update: PCBs are shipped via express... :dancers:
                                • GertSandersG
                                  GertSandersG
                                  GertSanders
                                  #36
                                  Update: this arrived in my mail today:
                                  I also ordered a set from DirtyPcbs, which were ready lastweek monday, but are still on their way to me.
                                  Assembly starts tomorrow :-)
                                  • A
                                    A
                                    ahhk
                                    ok, great :) Lets how they look ready....
                                    • GertSandersG
                                      GertSandersG
                                      GertSanders
                                      Here is version 2 of my sensor:
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        This post is deleted!
                                        • A
                                          A
                                          ahhk
                                          Maybe its better to open a new thread for this question? ;)
