  3. What's the best PIR sensor?
45 Posts 13 Posters 34.2k Views 9 Watching
  • NeverDieN NeverDie
    At the time I thought the am612 was in a good sweet spot (low price, low power, and "good enough" sensitivity), but technology is constantly improving, and so I'm always interested if anyone knows of something better.
    Also, these days wireless cameras are so cheap that I think the trend is toward combining them with PIR's, so that the cause of the trigger is always documented (well, to the degree it can be).
    L
    L
    lood29
    @NeverDie
    Excelitas PYD1588/1598 are the best I've used, running now for years without a single false alert.
    Fully integrated, 1.8V and only 3uA
    nagelcN NeverDieN 2 Replies Last reply
    • L lood29
      @NeverDie
      nagelcN
      nagelcN
      nagelc
      @lood29
      I recently got a PYD1598 sensor up an running. I made a lot of guesses at the settings and would like to hear what you are using. I wound up with:
      Pulse Detection Mode 0 = signal has to exceed the threshold and change of sign
      High Pass Filter Freq. 1 = 0.2 Hz
      Filter Source 0 = PIR (BPF)
      Window Time 0 = 2 seconds
      Pulse Counter 0 = 1 pulse
      Blind Time 2 seconds
      Threshold = 128
      I played around with the threshold a little, but didn't get a very good sense of the tradeoff of sensitivity vs false alarms (working in a relatively small room). The 128 seems to work, but wondering if there are better settings.
      L 1 Reply Last reply
      • L lood29
        @NeverDie
        NeverDieN
        NeverDieN
        @lood29 said in What's the best PIR sensor?:
        What kind of range?
        • nagelcN nagelc
          @lood29
          Threshold = 128
          L
          L
          lood29
          wrote on last edited by lood29
          #44
          @nagelc
          I kept all setting to default except the maintain window =8s
          So the SERIN reg is: 0x0031ED10
          @NeverDie
          With the fresnel and the wide angle 1598 it's ~ 7m
          nagelcN 1 Reply Last reply
          • L lood29
            @nagelc
            @NeverDie
            nagelcN
            nagelcN
            nagelc
            @lood29 Interesting. Looks like I can cut the threshold way down. I'll give that a try.
