  3. What's the best PIR sensor?
45 Posts 13 Posters 34.2k Views 9 Watching
  • pyrodetectorP
    pyrodetectorP
    pyrodetector
    I have published the brochure in which I tested the eleven pyroelectric detectors from different manufacturers, pyroelectric materials, and electrical connections - both parallel and serial. I tested them under the same conditions. I hope this helps. Feel free to ask the questions:)
    • pyrodetectorP pyrodetector
      @pyrodetector said in What's the best PIR sensor?:
      For the TL;DR, which one did you like the best?
      pyrodetectorP 1 Reply Last reply
        pyrodetectorP
        pyrodetectorP
        pyrodetector
        @NeverDie said in What's the best PIR sensor?:
        Dear NeverDie!
        What is "TL;DR", please?
        Every sensor is good for its application. Among a set of sensors the best two sensors or more are those having similar characteristics.
          Dear NeverDie!
          #36
          @pyrodetector "TL;DR" = "too long; didn't read." Nothing personal. Just a common internet acronym. It means, in effect, "What's the bottom line?"
          • C
            C
            chrisjn52
            @NeverDie - Just in case you haven't seen them there are a number of TI Reference Designs and Application Notes that you may find useful.
              pyrodetectorP
              pyrodetectorP
              pyrodetector
              Dear @NeverDie Thanks a lot! I am not an experienced user on the internet forums and you help me be getting better.
              In order to say which sensor is the best, one has to determine the criteria. I research the dynamic behavior of pyroelectric detectors. One common rule is true for all pyroelectric detectors: the higher the AC responsivity, the higher the noise, the higher the current consumption, the shorter the transient response. And vice versa. If you want to gain more knowledge on pyroelectric detectors, you can build an experimental setup/bench similar to mine for testing your pyroelectric detectors. I wish anyone had such a bench and we could share the results with one another. Probably, closer to spring, I will test the sensor you mentioned above and publish its transient response here.
                #39
                At the time I thought the am612 was in a good sweet spot (low price, low power, and "good enough" sensitivity), but technology is constantly improving, and so I'm always interested if anyone knows of something better.
                Also, these days wireless cameras are so cheap that I think the trend is toward combining them with PIR's, so that the cause of the trigger is always documented (well, to the degree it can be).
                Nca78N L 2 Replies Last reply
                  @NeverDie AM612 has been improved with BS612: down to 2.2V instead of 2.7V, and max 11uA working current compared to 14.
                  There's also a HM612 which is supposed to be "long range" and has a higher sensibility, other specs seem to be the same. I've not tested them, not using any pir sensors here it's too hot to be usable :)
                    L
                    L
                    lood29
                    Excelitas PYD1588/1598 are the best I've used, running now for years without a single false alert.
                    Fully integrated, 1.8V and only 3uA
                    nagelcN NeverDieN 2 Replies Last reply
                    • L lood29
                      nagelcN
                      nagelcN
                      nagelc
                      @lood29
                      I recently got a PYD1598 sensor up an running. I made a lot of guesses at the settings and would like to hear what you are using. I wound up with:
                      Pulse Detection Mode 0 = signal has to exceed the threshold and change of sign
                      High Pass Filter Freq. 1 = 0.2 Hz
                      Filter Source 0 = PIR (BPF)
                      Window Time 0 = 2 seconds
                      Pulse Counter 0 = 1 pulse
                      Blind Time 2 seconds
                      Threshold = 128
                      I played around with the threshold a little, but didn't get a very good sense of the tradeoff of sensitivity vs false alarms (working in a relatively small room). The 128 seems to work, but wondering if there are better settings.
                      L 1 Reply Last reply
                      • L lood29
                        @lood29 said in What's the best PIR sensor?:
                        What kind of range?
                        • nagelcN nagelc
                          @lood29
                          Threshold = 128
                          L
                          L
                          lood29
                          wrote on last edited by lood29
                          #44
                          @nagelc
                          I kept all setting to default except the maintain window =8s
                          So the SERIN reg is: 0x0031ED10
                          With the fresnel and the wide angle 1598 it's ~ 7m
                          nagelcN 1 Reply Last reply
                          • L lood29
                            @nagelc
                            nagelcN
                            nagelcN
                            nagelc
                            @lood29 Interesting. Looks like I can cut the threshold way down. I'll give that a try.
