  3. MyController.org
  4. MyController.org
MyController.org
Scheduled Pinned Locked Moved MyController.org
100 Posts 22 Posters 79.3k Views 14 Watching
  • TD22057T TD22057
    +1 vote for MQTT. I need a controller that can send out events via MQTT messages as they occur so other software can respond to them. REST is great for some things but I don't want to poll the controller to check it's state.
    epierreE
    epierreE
    epierre
    then websockets would be best !
    z-wave - Vera -> Domoticz
    TD22057T 1 Reply Last reply
    • epierreE epierre
      TD22057T
      TD22057T
      TD22057
      I'm afraid I have to disagree. MQTT gives you decoupling which is huge advantage. You can write lots of simple systems that broadcast information without worrying about where it's going or what's being done with it. And those systems can start up and shut down as they need to or as you try out new things. It allows you to add to and modify your system without touching most of the components. The more I think about it, the more strongly I feel that the best MySensors system is really a gateway/mini-controller that convert the radio messages into MQTT messages and that's it. Then you can have as many "big" controllers as you want to get web interfaces (MyController), programming ability (OpenHab), that can all listen and publish messages. I'm not sure I'm really describing how powerful this is but once you have a system set up this way, it's absolutely fantastic.
      I have a bunch of small scripts that read hardware data in my house. Each is custom for it's application which include reading the electric meter, solar panel output, wireless weather station, etc. They each just publish MQTT messages. I wrote them once and have never really touched them since. But I keep playing around with consumers of those messages. I'm experimenting with different databases for persistence, web GUI's for plotting, alerts sent to my phone, etc. Using MQTT means I never need to touch the hardware specific bits when I want to try out something new.
      A MySensors gateway is basically the same kind of system to me - define a message format, convert radio messages and publish them, subscribe to "commands" and convert them back to radio messages. Once you have that, you can run as many different "controllers" as you want since each is just sending and receiving messages. Granted all of this is possible now but there are multiple MQTT gateways (one is a client, one is a pseudo-broker), a few scripts that use the serial connection to do the same thing, and they aren't part of the official release. They also can publish numerical messages or put sensor text into them so there isn't an official message API.
      Let's say I have a controller that's working well for me. Along comes MyController (which looks fantastic) and I want to try it out. If it used MQTT, I could just start it up and see how it works with my systems and if I want to use it. Controllers that require the serial gateway basically are all or nothing - either they get the serial line or nothing. So I have to install that controller somewhere near my gateway (not always practical), shut down my existing system, try them out, and then make a choice if I want to keep it or not. If all the controllers used MQTT, then I can run as many as I like and use the best parts of each one. Or, each one can be a much smaller collection of loosely coupled parts that each do a single thing really well (plotting, logging, scripting, etc).
      Getting off the soap box now... Feel free to ignore my early morning, haven't had my coffee yet, pseudo-ranting... :smile:
      epierreE 1 Reply Last reply
      • E
        E
        ericvdb
        Also, running a controller in a virtual environment makes it difficult to connect to a serial gateway ;)
        • J
          J
          jkandasa
          Created new feature request to support MQTT gateway - https://github.com/mycontroller-org/mycontroller/issues/3
          • TD22057T TD22057
            epierreE
            epierreE
            epierre
            Well I disagree also on this for you would send all around your home network informations on devices and any device plugged on it youdon't have enough control on or which is hijacked will gain control of all you home automation... so if using MQTT do it with a PKI or something similar, this has an overhead but it will preserve your future
            same for me :smile:
            • J
              J
              jkandasa
              Released: 0.0.2-alpha2 with addition of Ethernet-Gateway and MQTT-Gateway support.
              Visit https://github.com/mycontroller-org/mycontroller for installation instructions.
              • D
                D
                diggs
                Looks very cool and straight forward. Nice work!
                Wondering if there is a way to extract the logged sensor data for import into other packages/spreadsheets etc for further analysis?
                • J
                  J
                  jkandasa
                  @diggs Right now there is no way to extract to spread sheet other than extracting from database directly. Kindly propose your requirements in https://github.com/mycontroller-org/mycontroller/issues
                  • D
                    D
                    diggs
                    @jkandasa thanks for the reply. Will add in the issues section
                    Cheers
                    • J
                      J
                      jkandasa
                      Anyone tried MyController.org to setup locally? If yes kindly share your experiences ;)
                      • J
                        J
                        jkandasa
                        Wiki Link: http://www.mycontroller.org/
                        • D
                          D
                          d-smes
                          @jkandasa very nice work! As for my experience, I had a bit of trouble getting it started. Somehow, I was under the impression that double-clicking start.bat would automatically start the Java app. It was later that I realized I then need to point my browser to localhost:8443 and log in. Your WIKI is well written, but I somehow missed that step. BTW, I'm using the Ethernet gateway and editing settings was a breeze.
                          Possible bug to report- Sensors with an ID of 0 (zero) are not auto-detected. I have four nodes with sensor ID's of 0 that I know are sending data but they do not show up on Sensors page or on Action Board.
                          • J
                            J
                            jkandasa
                            @d-smes thank you to gave a try with MyController.org. Could you please see your log file is there any error? logs/mycontroller.log
                            • J
                              J
                              jkandasa
                              @d-smes can you see other sensors in MyController page? other than sensor id 0
                              • D
                                D
                                d-smes
                                @jkandasa Yep, error log full of the same sets of errors. Example of one error pair:
                                2015-09-16 11:41:55,150 WARN [Thread-3] [org.mycontroller.standalone.db.dao.SensorDaoImpl:52] Sensor:[org.mycontroller.standalone.db.tables.Sensor@e7f65f[id=<null>,sensorId=0,type=<null>,messageType=38,name=<null>,updateTime=<null>,status=<null>,lastValue=<null>,unit=<null>,node=org.mycontroller.standalone.db.tables.Node@18dbb32[id=4,name=<null>,version=<null>,updateTime=<null>,type=<null>,mySensorsVersion=<null>,batteryLevel=<null>,eraseEEPROM=<null>,firmware=<null>]]], Sensser Id should be in the range of 1~254
                                2015-09-16 11:41:55,150 ERROR [Thread-3] [org.mycontroller.standalone.mysensors.MessageMonitorThread:68] RawMessage[NodeId:4,ChildSensorId:0,MessageType:1,Ack:0,SubType:38,PayLoad:4.825] throws exception while processing!,
                                java.lang.NullPointerException: null
                                	at org.mycontroller.standalone.mysensors.ProcessRawMessage.recordData(ProcessRawMessage.java:480) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                                	at org.mycontroller.standalone.mysensors.ProcessRawMessage.setSubMessageTypeSelector(ProcessRawMessage.java:449) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                                	at org.mycontroller.standalone.mysensors.ProcessRawMessage.messageTypeSelector(ProcessRawMessage.java:91) ~[mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                                	at org.mycontroller.standalone.mysensors.MessageMonitorThread.processRawMessage(MessageMonitorThread.java:60) [mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                                	at org.mycontroller.standalone.mysensors.MessageMonitorThread.run(MessageMonitorThread.java:82) [mycontroller-standalone-0.0.2-alpha2-single.jar:na]
                                	at java.lang.Thread.run(Unknown Source) [na:1.8.0_60]
                                The clue appears to be "Sensser Id should be in the range of 1~254"
                                Nodes with multiple sensors show e.g. sensors 1- 11 but not sensor 0.
                                • J
                                  J
                                  jkandasa
                                  wrote on last edited by jkandasa
                                  #36
                                  @d-smes My bad it was a mistake, I understand wrongly like, we will not have sensor id 0, should have only from 1~254, now corrected and will allowed 0~254 id,
                                  you have to stop your mycontroller server and replace lib/mycontroller-standalone-0.0.2-alpha2-single.jar with the fix http://www.filedropper.com/mycontroller-standalone-002-alpha2-single
                                  • J
                                    J
                                    jkandasa
                                    MyController.org Released 0.0.2-alpha3 :thumbsup:
                                    For user documents visit MyController.org
                                    • D
                                      D
                                      diggs
                                      Just wondering if it is possible to run two controllers side by side both looking at the same serial port?
                                      i.e. can I run Domoticz and MyController at the same time in serial mode with the one gateway or would it cause issues?
                                      • J
                                        J
                                        jkandasa
                                        @diggs for my knowledge we could not share same port directly for two applications. We may need to use some adapters for this operation. I do not know how much it is possible.
                                        • E
                                          E
                                          etrombly
                                          @diggs I was looking into doing the same thing. There are ways to duplicate a serial port using utilities like socat that should work. I was having issues with one side of the redirect disconnecting when there was no data to read. I was thinking of just writing up a quick python utility that would have the features I wanted. ser2net would work well, but it only redirects the port to the network, it doesn't do local redirection.
