  3. MyController.org
  4. MyController.org
MyController.org
Scheduled Pinned Locked Moved MyController.org
100 Posts 22 Posters 79.3k Views 14 Watching
  • E
    E
    ericvdb
    @jkandasa Would it be possible to add a graph for the battery percentage?
    • J
      J
      jkandasa
      @ericvdb Thank you for your interest with MyController.org. I have created a request for battery percentage. Kindly update your thoughts on this https://github.com/mycontroller-org/mycontroller/issues/14
      How often node sends battery percentage?
      • F
        F
        fleinze
        That depends on your sketch. I update battery every hour, but only if there are changes.
        • S
          shattered
          wrote on last edited by shattered
          #44
          Thank you - This is what I have been looking for. I was getting ready to write my own which I did not have time for. It is simple displays the data that is needed and easy to debug. The other controllers I tried I spent more time debugging because of the bloat. I can not focus on my sensor development.
          • D
            D
            davidbd
            Nice ! Very clean GUI !
            I installed this controller on RPI with serial gateway and it works like a charm with two TEMP sensors.
            It will be good if you can use the RPI GPIO to connect directly to NRF24 RF module instead on adding the serial gateway ( see http://iot-playground.com ..)
            I wish you good luck with this project.
            J 1 Reply Last reply
            • GertSandersG
              GertSandersG
              GertSanders
              Actually, you can add the NRF24 directly to the Raspberry and use it as a gateway at the same time:
              http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
              • D davidbd
                J
                J
                jkandasa
                wrote on last edited by jkandasa
                #47
                Yes, I have plan to implement NRF24l01 directly. I have to learn more about how mysensors gateway is working. Also planing to implement RPI GPIO port access from MyController.org directly
                Thank you! @davidbd
                • GertSandersG GertSanders
                  J
                  J
                  jkandasa
                  #48
                  Thank you @GertSanders let me have a look. As MyController.org is designed with pure Java language I have to implement with some wrapper or with the help of pi4j module
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    @jkandasa
                    I used the Raspberry version of Mysensors gateway for software to set up a serial gateway. Then Inadded a symlink link with shorter name so domoticz could see it. If your software can detect the normal ttyMySensorGateway then no need for a symlink.
                    Hardware toconnect radio and raspberry is simple interconnect with GPIO. Same connections as with wire. I made a little board for it. Link to that is also somewhere on the forum.
                      @jkandasa
                      J
                      J
                      jkandasa
                      @GertSanders said:
                      @jkandasa
                      @GertSanders This is nice, I guess no need to change anything in MyController software. Let me check this and update you. Thank you.
                      • J
                        J
                        jkandasa
                        @GertSanders @davidbd Just now I tested https://github.com/mysensors/Raspberry with MyController.org server it is working perfectly. Thank you very much! you guys saved hardware cost and added direct NRF24 support to MyController.org :smiley:
                        I did all the steps as root user (running MyController.org server also as a root user). Kindly let me know if you face any issues.
                        Install https://github.com/mysensors/Raspberry and connect NRF24L01+ as mentioned on the page.
                        Now we have to point-out ttyMySensorsGateway port to MyController.org server via it is configuration file
                        Stop your MyController server change a line,
                        File Name: mycontroller/conf/mycontroller.properties
                        mcc.serialport.name=/dev/ttyMySensorsGateway
                        Start your MyController server. That is it :)
                        D 2 Replies Last reply
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          link to my board:
                          https://oshpark.com/shared_projects/aXLXBO3f
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                            My setup described here
                              J
                              J
                              jkandasa
                              • J jkandasa
                                D
                                D
                                davidbd
                                @jkandasa Well Done ! Thanks ! you are doing great Job here.
                                • J jkandasa
                                  D
                                  D
                                  davidbd
                                  @jkandasa
                                  I just install the PiGatewaySerial in RPI and run as a daemon but found CPU is almost 100% !
                                  2173 root 20 0 3740 1624 1416 R 98.8 0.4 2:17.91 PiGatewaySerial
                                  • D davidbd
                                    @jkandasa
                                    J
                                    J
                                    jkandasa
                                    @davidbd said:
                                    @jkandasa
                                    @davidbd I donot face any issue like you said.
                                    root@raspbx:~# ps -p 11415 -o %cpu,%mem,cmd
                                    %CPU %MEM CMD
                                     0.0  0.0 /usr/local/sbin/PiGatewaySerial -d
                                    I do not have much knowledge on PiGatewaySerial we have a discussion about this topic on http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection/39
                                    Some people already reported 100% cpu usage. Can you please check and post your query there?
                                    My RPI setup.
                                    root@raspbx:~# uname -a
                                    Linux raspbx 3.18.6-v7+ #753 SMP PREEMPT Sun Feb 8 14:53:56 GMT 2015 armv7l GNU/Linux
                                    root@raspbx:~# cat /etc/issue
                                    Raspbian GNU/Linux 8 \n \l
                                    root@raspbx:~# cat /etc/debian_version
                                    8.0
                                    RPI Model: Raspberry pi 2 Model B
                                    I ran everything as a root user.
                                    D 1 Reply Last reply
                                    • E
                                      E
                                      ericvdb
                                      The 100% cpu usage happens only if nothing connects to /dev/ttyMySensorsGateway, at least thats what i experienced.
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        My CPU load hardly ever goes over 1%, and that is including a running Domoticz controller in parallel with the serial gateway.
                                        Gert
                                        • J jkandasa
                                          @davidbd said:
                                          @jkandasa
                                          %CPU %MEM CMD
                                          My RPI setup.
                                          8.0
                                          D
                                          D
                                          davidbd
                                          @jkandasa As reported by users ... the 100% cpu usage happens only if nothing connects to /dev/ttyMySensorsGateway
                                          I am OK now but maybe worth to check why as this is not good behaviour.
