  3. MyController.org
  4. MyController.org
MyController.org
Scheduled Pinned Locked Moved MyController.org
100 Posts 22 Posters 79.3k Views 14 Watching
  • J
    J
    jkandasa
    wrote on last edited by jkandasa
    MyController.org - The Open Source Controller for MySensors.org
    I would like to introduce MyController.org to the Open Source World :)
    Still incomplete documents. I'm working on it. We will have complete documents soon.
    Document ready: Document Page
    Source: https://github.com/mycontroller-org/mycontroller
    Demo Link: http://demo.mycontroller.org (Authentication: admin/admin)
    To know about new releases visit/watch: http://forum.mysensors.org/topic/2058/releases
    tekkaT barduinoB 2 Replies Last reply
    • J jkandasa
      tekkaT
      tekkaT
      tekka
      @jkandasa wow! nice work
        @jkandasa
        You've been busy. Great job!
        • J jkandasa
          barduinoB
          barduinoB
          barduino
          @jkandasa
          We want pictures!!!!
          • greglG
            greglG
            gregl
            Great work...but yes pls some pics!!! ( as they tell 1000 words! )
            • J
              J
              jkandasa
              Screenshots of MyController.org server.
                @jkandasa
                Looks great,
                Let me know when you want to add it to the main site controller list. Just send me an email.
                • J
                  J
                  jkandasa
                  @hek Thank you! I will create some level of documents then we will add it in main site.
                  • J
                    J
                    jkandasa
                    • K
                      K
                      Kurt
                      Sweet!
                      Maybe exactly what I was looking for at the '?' mark in my post.
                      Does your controller also include a MQTT server to connect / export events to another home automation system? (like for instance OpenHAB?)
                      Kurt
                      • J
                        J
                        jkandasa
                        @Kurt Yes, it will fill your '?' mark with serial gateway. Right now MyController.org supports only serial gateway.
                        It will log all the events, you can schedule a timer, alarm and you can upload firmware of your nodes, many other features.
                        I never own Edison, But I guess you can run MyController.org server in Edison, if it supports Java 1.8, ~30 MB disk space and 40 MB RAM.
                        • TD22057T
                          TD22057T
                          TD22057
                          Great work - That looks fantastic! I'm curious what you envision as the longer term goals for the project? Do you see there being custom programming features (plugins via java, python, etc)? Feature wise, how does it compare with existing automation systems like openhab?
                          • J
                            J
                            jkandasa
                            @TD22057 Thank you! As you know already MySensors.org is a fantastic project for Open Source world. I would like to thank you MySensors.org the way of giving my contribution back to MyController.org, hence MyController.org born.
                            Longer term vision: Align with MySensors.org (primary Open Source Controller)
                            Features: https://github.com/mycontroller-org/mycontroller#available-features
                            There is no plugin concept available. But it has excellent REST API, You can use your own client.
                              mvader
                              will you be supporting eithernet gateways in the near future or are you only going to support serial gw's?
                              • J
                                J
                                jkandasa
                                Definitely I will support for Ethernet gateway. I'm learning Ethernet gateway.
                                • NeverDieN
                                  NeverDieN
                                  I like how it does graphical reports on all the sensors, straight up on Day 1! Nice!
                                  • K
                                    K
                                    Kurt
                                    Just gave it a quick test ... Nice! Worked +/- straight our of the box on my Mac. Next up is indeed to test on my Edison as it's very low power which is nice for 24/7 use.
                                    Are you planning MQTT support?
                                    I like your intend to align with MySensors which I interpret as 'focus on supporting MySensor functionality perfectly' rather than trying to also become a controller for other (home automation - zwave, x10, ... ) protocols as well? If your controller focusses on MySensor it could perfectly sync up with another automation controller using something like MQTT (or perhaps REST like you say is already supported)
                                    Kurt
                                    TD22057T 1 Reply Last reply
                                    • K Kurt
                                      Kurt
                                      TD22057T
                                      TD22057T
                                      TD22057
                                      +1 vote for MQTT. I need a controller that can send out events via MQTT messages as they occur so other software can respond to them. REST is great for some things but I don't want to poll the controller to check it's state.
                                      epierreE 1 Reply Last reply
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        Interesting stuff! Good work @jkandasa !
                                        • J
                                          J
                                          jkandasa
                                          @kurt Thank you! Kindly post us status of Edison test.
                                          Right now I do not have any road map to support for other home automatons (like zwave,x10,etc.,). I guess we can do everything with MySensors.org.
                                          @Kurt, @TD22057 I will think about MQTT support for events.. Can you please open new enhancement under https://github.com/mycontroller-org/mycontroller/issues We can discuss further about this feature.
