  3. Domoticz
  4. Multi sensor how to change basic script
3 Posts 3 Posters 2.0k Views 2 Watching
  • BigDogB
    BigDogB
    BigDog
    Hi there :)
    can i make a multi arduno with 2 sensors? To monitor my power and water usage
    the example @ the website is for 1 if i put the other sensor on other pin and copy script and change the pin number and put the 2 script after ichother wil that work?
    Greetz
    BigDog
    1x Raspberry With Domoticz V2.3011 [Linux version 4.1.6+]
    PiRack With
    -1X PiFace Digital
    -1X RaZberry - OpenZWave
    1X RFXtrx433 USB Firmware: 183
    5X Arduino: mysensors V1.5(including)
    • First DoorBel Project -> WORKS! :)
      6x ESP8266: easy firmware(Testing)
    • rvendrameR
      rvendrameR
      rvendrame
      It is possible, but you have to 'merge' the code from two scripts. Only one 'void setup()' , only one 'void loop()' , etc.
      Use multiple gw.present( x , y ) where x = sensor number and Y = sensor type.
      You are only limited by the memory available in arduino, and number if IO pins ;-)
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • J
        J
        jkandasa
        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/HumiditySensor/HumiditySensor.ino
