  3. Domoticz as controller **and** a gateway for MySensor nodes running on a Raspberry Pi 2
47 Posts 14 Posters 32.6k Views 16 Watching
    MikeF
    All now working OK - many thanks!
    • GertSandersG
      GertSandersG
      GertSanders
      I will need to document this. In the original post I followed to compile the gateway for rpi, this was also mentioned.
      I would prefer that the code is corrected in the right place, because I feel the RPI2 should be recognised properly.
      Anyway, happy to know there is a +1 user with a raspberry 2 and direct connected NRF24.
        MikeF
        That's the code change I made (makes the 'if' redundant).
        I've also changed the tty name (to /dev/ttyUSB40 - which is what I've declared to Domoticz) in this file and in Makefile.
        BTW: Very impressed with OSH Park - got the PCBs here in UK (from US) 13 days after ordering!
        • GertSandersG
          GertSandersG
          GertSanders
          wrote on last edited by GertSanders
          #24
          This was the fourth board I ordered from OSHPark. For boards with ENIG finish, they are cheap. And the quality is indeed excellent. I have ordered a fifth design from them (should be ready end next week) and at the same time I sent my files to DirtyPCB. We will see what that gives quality wise. On this forum someone mentioned Shenzen2u and they are eaven cheaper then DirtyPCB. So my next design will also be ordered from those guys.
          Now it's time to enjoy a local brew :-)
          • TD22057T
            TD22057T
            TD22057
            @GertSanders Check out http://pcbshopper.com/, there are places slightly cheaper than DirtyPCB and places that will do runs of 5 boards instead of 10 for the same price per board. http://www.elecrow.com/ looks really good (5 boards for $15 delivered) but I haven't ordered from them yet so I can't comment on quality (other reviews of them say it's fine though).
            • GertSandersG
              GertSandersG
              GertSanders
              I would rather pay 8.90 USD for 10 boards, then 15 USD for 5 boards delivered. http://www.shenzhen2u.com does the thing for me.
              • Sander StolkS
                Sander StolkS
                Sander Stolk
                @GertSanders Did you have a shopping part list available? I've ordered your board at OSHPark and I've got the Caps in stock but not the blue thingy and the dupont blocks.
                Could you put me in the right directorion where to shop those two parts?
                • Sander StolkS
                  Sander StolkS
                  Sander Stolk
                  Nevermind the dupont blocks. I've found those!
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    @Sander-Stolk The blue thingy is a ceramic 100nF capacitor, the two others are electrolytic capacitors of 100uF and 10uF respectively.
                    • Sander StolkS
                      Sander StolkS
                      Sander Stolk
                      Thanks alot!
                      • rmtuckerR
                        rmtuckerR
                        rmtucker
                        wrote on last edited by rmtucker
                        #31
                        Anyone got a spare pcb i can purchase in the UK ?
                        Seems a waste ordering a batch.
                        An SD image would be good too??
                        C 1 Reply Last reply
                        • Fat FlyF
                          Fat FlyF
                          Fat Fly
                          What i select from drop down menu? Mysensors gateway USB ?
                          • Fat FlyF Fat Fly
                            GertSandersG
                            GertSandersG
                            GertSanders
                            yes, follow these instructions:
                            http://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway
                            • Tore André RosanderT
                              Tore André Rosander
                              Is there any pros/cons for using the nrf directly on the RPi instead of a NodeMCU?
                              Right now i use NodeMCU (esp) with nrf radio as gateway, but i want to reduce the nuber of units around my house so connecting directly to the RPi would be better as long as there is no negative sides to it.
                              • Tore André RosanderT Tore André Rosander
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @Tore-André-Rosander
                                For me there are no downsides. I use the raspberry as both gateway (with the NRF mounted) and as Domoticz controller. It is part of my home network and I can reach my Domoticz from the internet. So far I have 13 sensor nodes running and communicating with the raspberry.
                                • rmtuckerR rmtucker
                                  C
                                  C
                                  chickey
                                  @rmtucker I was thinking the same, don't need a whole batch. Anyone got a spare board, happy to pop some cash your way via a paypal gift.
                                  • GertSandersG
                                    GertSandersG
                                    GertSanders
                                    I distributed my two other boards to friends locally. If you make the boards at OSH Park you get three boards (for a cost of 2.20 USD - shipping included).
                                    https://oshpark.com/shared_projects/aXLXBO3f
                                    • DwaltD
                                      DwaltD
                                      Dwalt
                                      wrote on last edited by Dwalt
                                      #38
                                      I have the two spares from my order. If anyone wants one, send me a private chat message with your postal address. I am in the US, so it could take a few extra days to arrive if you are unfortunate enough to live on the wrong side of the pond.
                                      • GertSandersG GertSanders
                                        C
                                        C
                                        chickey
                                        @GertSanders Thanks for the heads up. I'd incorrectly assumed that it was going to be something like $10 plus shipping. At $2.20 it's nothing so ordered a few just for testing. Got carried away though and ordered a few 8266 breakout boards too :-)
                                        Col
                                        • SeanMarshS
                                          SeanMarshS
                                          SeanMarsh
                                          I"m troubled. I know this will make me sound like a total newbie, but that's ok. From someone that is new to the form, it seems like you magically made the NRF work while it is physically attached to the RPi. I'm not finding any directions on how you made it work. I did find an old link that said that the directions on there will only work with 1.5X or below. Please show me the light.
