  2. Bug Reports
  3. Heater varTypes declaration in L_Arduino.lua
4 Posts 3 Posters 2.6k Views 1 Watching
  • L
    L
    luiscampiz
    First I want to thank everyone for this excellent project. Especially @hek.
    I succeeded in making work an electric heater thermostat. But changes were necessary on lines 97 and 98 L_Arduino.lua. (Development Branch)
    Original code:
    HEATER = {21, "urn:upnp-org:serviceId:HVAC_UserOperatingMode1", "ModeStatus", "" },
    HEATER_SW = {22, "urn:upnp-org:serviceId:SwitchPower1", "Status", "" },
    Modified code:
    HEATER = {21, "urn:upnp-org:serviceId:TemperatureSetpoint1_Heat", "CurrentSetpoint", "" },
    HEATER_SW = {22, "urn:upnp-org:serviceId:HVAC_UserOperatingMode1", "ModeStatus", "" },
    Can someone verify and upload these changes?
    I can confirm it works fine with my Vera Lite(UI6).
    Thank you.
      You are probably the first using these device definitions. Thanks for reporting.
      I've updated the repository now.
      • greglG
        greglG
        gregl
        @Hek - actually i use them, but not yet with 1.4
        • i do have a minor problem with this device for which this may be the answer ( again on 1.3)
          Ill try this on 1.3 tonight to see if this fixes it.
        @luiscampiz - this is my submission for the device:
        https://github.com/mysensors/Vera/commit/5aa2c862e8d728e3dda18135649d5bb271e7e52c
        • does it work/used with your fix?
        • greglG
          greglG
          gregl
          Ok yes ive now tested and this works better. I have to fix another bug in my sketch related to this but this did fix the weirdness i was seeing..
          So thanks @luiscampiz
