  3. How to wire for battery level measure?
8 Posts 5 Posters 3.4k Views 2 Watching
    msebbe
    I dont understand how to wire if I want to measure battery level at A0 pin.. I have 1MΩ (R1) and 470KΩ (R2) resistor. But how do I connect this?
    AWIA 1 Reply Last reply
    • M msebbe
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @msebbe put the two resistors in series between Vcc (Vin) and Gnd and connect the middle ( Vout) to the A0 pin. If you connect the 1 MOhm (R2) to ground, the voltage on the A0 pin is then two third (2/3) times Vcc. This is called a voltage divider.
      upload-bd638a77-6e7f-4f89-b083-8e7ce3c24856
      M 1 Reply Last reply
      • AWIA AWI
        msebbe
        wrote on last edited by msebbe
        1M to grund? In example from mysensors picture says 1M to vcc.
        Also, could I wire so both resistors meet at A0 or how do you do it?
        SparkmanS 1 Reply Last reply
        • m26872M
          m26872M
          m26872
          Vin = Vbat
          Vout = A0
          R1= 1M
          R2 = 470k
          • M msebbe
            SparkmanS
            SparkmanS
            Sparkman
            @msebbe said:
            Also, could I wire so both resistors meet at A0?
            Yes, that is fine.
            Cheers
            Al
              msebbe
              Ok, thank you guys, will try this tomorrow when I have a whole day free :D
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Trying to figure out the same thing. Did I understand correctly that I could solder 1M Resistor from VCC to A0 and 470k Resistor from GND to A0 ?
                  AWIA
                  AWIA
                  AWI
                  @Cliff-Karlsson You could do just that. The voltage on the A0 pin will be around 1/3th of Vcc. If you swap the resistors 2/3th of Vcc.
