  3. Compiling MYSBootloader errors [solved]
9 Posts 3 Posters 4.7k Views 2 Watching
  • Y
    Y
    yugoos
    wrote on last edited by yugoos
    Hi all,
    in my setup i changed the channel of my sketches in myconfig.h to 120 and set the speed to 1Mbps, i set the speed higher to lower the signal even further on a problematic spot in the garden and forcing that node to use a repeater without hardcoding a parent.
    while trying to get FOTA to work (without succes) i realized that maybe the provided MYSbootloader is listining on the default channel/speed and not reaching my gateway.
    am i right do i need a fresh compiled bootloader using these new settings?
    if yes, can anyone please guide me how to compile the bootloader, iḿ getting nothing but errors.
    "avr-gcc" -x c -mno-interrupts -funsigned-char -funsigned-bitfields -DF_CPU=16000000L-Os -fno-inline-small-functions -fno-split-wide-types -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  -I../libraries/MySensors/ MYSBootloader.c -o MYSBootloader.o
    In file included from MYSBootloader.h:8:0,
                     from MYSBootloader.c:44:
    /usr/lib/avr/include/util/delay.h:95:3: warning: #warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed" [-Wcpp]
     # warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
    /usr/lib/avr/include/util/delay.h: In function ‘_delay_ms’:
    <command-line>:0:17: error: ‘Os’ undeclared (first use in this function)
    <command-line>:0:17: note: each undeclared identifier is reported only once for each function it appears in
    /usr/lib/avr/include/util/delay.h: In function ‘_delay_us’:
    In file included from ../libraries/MySensors/MySensor.h:26:0,
                     from MYSBootloader.h:11,
    ../libraries/MySensors/MyHw.h: At top level:
    ../libraries/MySensors/MyHw.h:31:1: error: unknown type name ‘class’
     class MyHw
    ../libraries/MySensors/MyHw.h:32:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
    In file included from ../libraries/MySensors/MySensor.h:27:0,
    ../libraries/MySensors/MyTransport.h:32:1: error: unknown type name ‘class’
     class MyTransport
    ../libraries/MySensors/MyTransport.h:33:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
    In file included from ../libraries/MySensors/utility/RF24.h:18:0,
                     from ../libraries/MySensors/MyTransportNRF24.h:26,
                     from ../libraries/MySensors/MySensor.h:28,
    ../libraries/MySensors/utility/RF24_config.h:17:23: fatal error: WProgram.h: No such file or directory
      #include <WProgram.h>
    compilation terminated.
    make: *** [MYSBootloader.o] Error 1
    Lot's of syntax errors suggesting the compiler does not understand C++, changing the compiler to avr-cpp or avr-g++ is not helping...
    what am i doing wrong??
    thanx,
    yuri
    • Y
      Y
      yugoos
      Some additional info i forgot to mention:
      OS: Linux Mint
      Arduino-IDE: 1.6.5
      tried to compile both MySensors-master and development, errors as shown in compile log.
      tried to use provided avr-gcc in github clone and binaries from IDE, more includes needed but still errors like above
      • Y
        Y
        yugoos
        did i post in the wrong board?
        getting a bit desperate here after day's of searching google, feeding options to get compiler happy...no joy so far :(
        has anyone ever successfully compiled the MYSBootloader and how did you do it?
        i'm sure i'm missing something in the compiler environment (shell variables and/or libraries), i just cannot find what..
        thanx,
        yuri
        tekkaT 1 Reply Last reply
          @tekka might have a clue.
          • Y yugoos
            thanx,
            yuri
            tekkaT
            tekkaT
            tekka
            thanx,
            yuri
            I suggest installing Atmel Studio and make sure all dependencies are correct.
            • Y
              Y
              yugoos
              Hi Tekka,
              thanx for replying, i'l give it a go.
              downloading 560MB in 3..2..1..
              what depedencies are you referring to, mysensors libraries or avr/arduino compilers?
              it could take a while to test this as my everyday laptop is linux based and the old windoze box is not that fast...
              thanx,
              yuri
              • Y
                Y
                yugoos
                wow, this is some large complex piece of software...
                way over my head i'm afraid.
                being unable to create a bootloader using my channel/bandwith setting, am i now forced to use the defaults if i want FOTA?
                • Y
                  Y
                  yugoos
                  YAY...I fixed it myself...hopefully
                  at some point in troubleshooting all the warnings and errors i thought...could the bootloader source may have been broken when implementing 1.5??
                  easy enough to try, so after downloading and linking the 1.4 libs in bootloader subfolder, running make and voila! a new hex-file!!! :grin:
                  now i have to wait for my new arduino's to test....
                  cheers,
                  yuri
                  • Y
                    Y
                    yugoos
                    I'm happy to report that my fresh compliled bootloader is working on my network settings.
                    I have used Mysensors 1.4 library and included 1.4 mysensors and mysensors/utilities folders in the default makefile as aditional CFLAGS -I parameters
                    tested tonight using a nano i found in one of the quadcopters ;)
                    working like a charm
                    cheers,
                    yuri
                    P.S. changed the subject to [solved]
