  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.8k Views 15 Watching
  • ZwaZoZ
    ZwaZoZ
    ZwaZo
    Here an update of the original sketch with a small modif to add a buzzer for validating the keypress.
    It will beep once for short key press and twice for the long one.
    The buzzer is connected on D3 and the beep length can be adjusted in the function.
    Your feedback and improvement ideas are welcome.
    Best regards,
    Jef
    /* - RF24_PA_MIN = -18dBm
     * - RF24_PA_LOW = -12dBm
     * - RF24_PA_HIGH = -6dBm
     * - RF24_PA_MAX = 0dBm
    // Enabled repeater feature for this node
    #define MY_REPEATER_FEATURE
    // activate signal report
    // #define MY_SIGNAL_REPORT_ENABLED
    #include <Keypad.h>
    #define NODE_ID AUTO // or set to AUTO if you want gw to assign a node id for you.
    #define SN "Keypad Scene Controller"
    #define SV "2.1"
    #define KEYPAD_CHILD_ID 95
    MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON); //scene ON
    MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //scene OFF
    int buzzer = 3; // buzzer pin
    const byte ROWS = 4; //four rows
    const byte COLS = 1; //one column
    char keys[ROWS][COLS] = {
      {'1'},
      {'2'},
      {'3'},
      {'4'}
    byte rowPins[ROWS] = {6, 7, 4, 5}; //connect to the row pinouts of the keypad
    byte colPins[COLS] = {8}; //connect to the column pinouts of the keypad
    Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    byte lastState;
      sendSketchInfo(SN, SV);
      present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
      keypad.addEventListener(keypadEvent);
      pinMode(buzzer, OUTPUT);
     * Declare the buzzer function.
     * Adjust the delay to fit your preferences
    void beep()
      digitalWrite(buzzer, HIGH);
      delay(50);
      digitalWrite(buzzer, LOW);
      char key = keypad.getKey();
    void keypadEvent(KeypadEvent key) {
      switch (keypad.getState()) {
        case PRESSED:
          lastState = 1;
          beep();
          break;
        case HOLD:
          lastState = 2;
          beep();
          break;
        case RELEASED:
          int keyInt = key - '0'; //Quick way to convert Char to Int so it can be sent to controller
          if (lastState == 2) {
            //keyInt = keyInt + 4; //If button is held, add 4.  If using more than 4 buttons this number will need to be changed
            send(scene2.set(keyInt));
          } else {
          send(scene.set(keyInt));
          //break;
    • S
      Sanderunizuki
      I want to use this mysensors touch sensor to adjust a selector switch in domoticz, so if I select scene 1 the selector switch in Domoticz goes to 10%, and scene 2 to 20% and so on. Is that possible and how do I do that?
