  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.8k Views 15 Watching
  • Łukasz KostrzewaŁ Łukasz Kostrzewa
    Hi rechin304
    Thank You for Your code...It's working great!!!
    Best regards
    rechin304R
    rechin304R
    rechin304
    @Łukasz-Kostrzewa you are welcome, all thanks goes to @petewill for initial code.
    • Matt PittsM
      Matt PittsM
      Matt Pitts
      Hi Guys,
      I'm so glad that have updated the sketch which i have now been able to compile and get running :-)
      But this is the message I get in the serial monitor and I only get these messages when I press button 3?? I am using a single row of four buttons as in the original sketch.
      Am I missing something here? I was assuming the message with either be a 1 for a short press and 0 for a long press? I would be really grateful if someone who knows more about this than me is able to help me figure out what's going on?
      TSP:MSG:SEND 11-11-0-0 s=95,c=1,t=19,pt=2,l=2,sg=0,ft=0,st=ok:3
      TSP:MSG:SEND 11-11-0-0 s=95,c=1,t=19,pt=2,l=2,sg=0,ft=0,st=ok:7
      rechin304R 1 Reply Last reply
      • Matt PittsM Matt Pitts
        Hi Guys,
        rechin304R
        rechin304R
        rechin304
        @Matt-Pitts on 3 is short press and in code is scene on and on long press is 7 scene off
        MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON); //scene ON
        MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //scene OFF
                send(scene2.set(keyInt));
              send(scene.set(keyInt));```
        • Matt PittsM
          Matt PittsM
          Matt Pitts
          Hi Not sure if that helps me, I'm struggling to understand how this actually works? as I said the only button doing anything is 3, do I need to modify the sketch to get the other buttons working?
            rechin304R
            rechin304R
            rechin304
            @Matt-Pitts then you need to check your conenction to all wires and if are correctly. Check first post as there is a picture.
            • rechin304R rechin304
              Complete code version 2 with short press ON long press OFF.
              #include <Keypad.h>
              #define NODE_ID AUTO // or set to AUTO if you want gw to assign a NODE_ID for you.
              #define SN "Scene Controller"
              #define SV "2.0"
              #define KEYPAD_CHILD_ID 95
              const byte ROWS = 4; //four rows
              const byte COLS = 1; //one column
              char keys[ROWS][COLS] = {
                {'1'},
                {'2'},
                {'3'},
                {'4'}
              byte rowPins[ROWS] = {6, 7, 4, 5}; //connect to the row pinouts of the keypad
              byte colPins[COLS] = {8}; //connect to the column pinouts of the keypad
              Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
              byte lastState;
                sendSketchInfo(SN, SV);
                present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
                keypad.addEventListener(keypadEvent);
                char key = keypad.getKey();
              void keypadEvent(KeypadEvent key) {
                switch (keypad.getState()) {
                  case PRESSED:
                    lastState = 1;
                  case HOLD:
                    lastState = 2;
                  case RELEASED:
                    int keyInt = key - '0'; //Quick way to convert Char to Int so it can be sent to controller
                    if (lastState == 2) {
                      //keyInt = keyInt + 4; //If button is held, add 4.  If using more than 4 buttons this number will need to be changed
                    //break;
              DrJeffD
              DrJeffD
              DrJeff
              @rechin304
              Not getting the Hold on buttons working, everything else works. Any ideas why the long press doesn't work?
              • DrJeffD
                DrJeffD
                DrJeff
                Never mind part of the code was commented out. I wasn't sure because I just started to use OTA. But it's all good now its working fine. Here it is:
                #define MY_OTA_FIRMWARE_FEATURE
                #include <Keypad.h>
                #define SV "2.0"
                  {'1'},
                  {'2'},
                  {'3'},
                  {'4'}
                byte lastState;
                    case PRESSED:
                      lastState = 1;
                    case HOLD:
                      lastState = 2;
                    case RELEASED:
                • DrJeffD DrJeff
                  #include <Keypad.h>
                  #define SV "2.0"
                    {'1'},
                    {'2'},
                    {'3'},
                    {'4'}
                  byte lastState;
                      case PRESSED:
                        lastState = 1;
                      case HOLD:
                        lastState = 2;
                      case RELEASED:
                  rechin304R
                  rechin304R
                  rechin304
                  @DrJeff ok, glad to hear you solved.
                  • ZwaZoZ
                    ZwaZoZ
                    ZwaZo
                    Here an update of the original sketch with a small modif to add a buzzer for validating the keypress.
                    It will beep once for short key press and twice for the long one.
                    The buzzer is connected on D3 and the beep length can be adjusted in the function.
                    Your feedback and improvement ideas are welcome.
                    Best regards,
                    Jef
                    /* - RF24_PA_MIN = -18dBm
                     * - RF24_PA_LOW = -12dBm
                     * - RF24_PA_HIGH = -6dBm
                     * - RF24_PA_MAX = 0dBm
                    #define MY_REPEATER_FEATURE
                    // activate signal report
                    // #define MY_SIGNAL_REPORT_ENABLED
                    #include <Keypad.h>
                    #define NODE_ID AUTO // or set to AUTO if you want gw to assign a node id for you.
                    #define SN "Keypad Scene Controller"
                    #define SV "2.1"
                    int buzzer = 3; // buzzer pin
                      {'1'},
                      {'2'},
                      {'3'},
                      {'4'}
                    byte lastState;
                      pinMode(buzzer, OUTPUT);
                     * Declare the buzzer function.
                     * Adjust the delay to fit your preferences
                    void beep()
                      digitalWrite(buzzer, HIGH);
                      delay(50);
                      digitalWrite(buzzer, LOW);
                        case PRESSED:
                          lastState = 1;
                          beep();
                        case HOLD:
                          lastState = 2;
                          beep();
                        case RELEASED:
                          //break;
                      Sanderunizuki
                      I want to use this mysensors touch sensor to adjust a selector switch in domoticz, so if I select scene 1 the selector switch in Domoticz goes to 10%, and scene 2 to 20% and so on. Is that possible and how do I do that?
