  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.8k Views 15 Watching
    msebbe
    Anybody made some Nice enclosure for this?
    • F Fred LaR
      Hi all - Another capacitive version with an "out of the bottle" keypad - 4 buttons. Like AWI's version, also toggles between 'Scene ON' and 'Scene OFF', but states are kept in a variable (keyState) - LEDs added for better toogle visibility. Capacitive routine found at http://www.arduino.cc/playground/Code/CapacitiveSensor
      Great post from @petewill and nice version from AWI. Thanks!
      #define SN "Scene Controller"
      #define SV "1.2"
      #define NODE_ID 20 // or set to AUTO if you want gw to assign a NODE_ID for you.
      const byte KEYPAD_CHILD_ID = 1 ;
      MyMessage scene_on(KEYPAD_CHILD_ID, V_SCENE_ON);
      MyMessage scene_off(KEYPAD_CHILD_ID, V_SCENE_OFF);
      long time = 0;
      long debounce = 800;
      const byte keyLeds[] = {14, 15, 16, 17}; //LEDs to turn on/off
      const byte keyPins[] = {2, 3, 4, 5}; //capacitive keys
      byte keyState = B1111; //save LEDs states
      Serial.begin(9600);
      for (byte i = 0 ; i < sizeof(keyLeds) ; i++)
      { pinMode(keyLeds[i], OUTPUT);
      gw.begin(NULL, NODE_ID);
      gw.sendSketchInfo(SN, SV);
      gw.present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
      uint8_t pinRead;
      for (byte i = 0 ; i < sizeof(keyPins) ; i++){
      pinRead = readCapacitivePin(keyPins[i]);
      if (pinRead > 2 && millis() - time > debounce) {
      digitalWrite(keyLeds[i], bitRead(keyState,i));
      if (bitRead(keyState,i) == 1){
      gw.send(scene_on.set(keyPins[i]));
      bitWrite(keyState, i, 0);} else
      {gw.send(scene_off.set(keyPins[i]));
      bitWrite(keyState, i, 1);}
      time = millis();
      // — readCapPin found at http://www.arduino.cc/playground/Code/CapacitiveSensor
      uint8_t readCapacitivePin(int pinToMeasure) {
      // Variables used to translate from Arduino to AVR pin naming
      volatile uint8_t* port;
      volatile uint8_t* ddr;
      volatile uint8_t* pin;
      // Here we translate the input pin number from
      // Arduino pin number to the AVR PORT, PIN, DDR,
      // and which bit of those registers we care about.
      byte bitmask;
      port = portOutputRegister(digitalPinToPort(pinToMeasure));
      ddr = portModeRegister(digitalPinToPort(pinToMeasure));
      bitmask = digitalPinToBitMask(pinToMeasure);
      pin = portInputRegister(digitalPinToPort(pinToMeasure));
      // Discharge the pin first by setting it low and output
      *port &= ~(bitmask);
      *ddr |= bitmask;
      delay(1);
      // Make the pin an input with the internal pull-up on
      *ddr &= ~(bitmask);
      *port |= bitmask;
      // Now see how long the pin to get pulled up. This manual unrolling of the loop
      // decreases the number of hardware cycles between each read of the pin,
      // thus increasing sensitivity.
      uint8_t cycles = 17;
      if (*pin & bitmask) { cycles = 0;}
      else if (*pin & bitmask) { cycles = 1;}
      else if (*pin & bitmask) { cycles = 2;}
      else if (*pin & bitmask) { cycles = 3;}
      else if (*pin & bitmask) { cycles = 4;}
      else if (*pin & bitmask) { cycles = 5;}
      else if (*pin & bitmask) { cycles = 6;}
      else if (*pin & bitmask) { cycles = 7;}
      else if (*pin & bitmask) { cycles = 8;}
      else if (*pin & bitmask) { cycles = 9;}
      else if (*pin & bitmask) { cycles = 10;}
      else if (*pin & bitmask) { cycles = 11;}
      else if (*pin & bitmask) { cycles = 12;}
      else if (*pin & bitmask) { cycles = 13;}
      else if (*pin & bitmask) { cycles = 14;}
      else if (*pin & bitmask) { cycles = 15;}
      else if (*pin & bitmask) { cycles = 16;}
      // Discharge the pin again by setting it low and output
      // It’s important to leave the pins low if you want to
      // be able to touch more than 1 sensor at a time – if
      // the sensor is left pulled high, when you touch
      // two sensors, your body will transfer the charge between
      // sensors.
      *ddr |= bitmask;
      return cycles;
      petewillP
      petewillP
      petewill
      @Fred-LaR That's a great idea. Nice!
      • Michal MormonM
        Michal MormonM
        Michal Mormon
        My domoticz found S_SCENE_CONTROLLER sensor but there is not any devices for such a hardware. Do you know how can I control scene with it?
        mfalkviddM M 2 Replies Last reply
        • Michal MormonM Michal Mormon
          @Michal-Mormon which version of Domoticz are you using?
          • Michal MormonM
            Michal MormonM
            Michal Mormon
            Domoticz v.2.4633
            • Michel - ItM
              Michel - ItM
              Michel - It
              lua script?
              petewillP 1 Reply Last reply
              • Michel - ItM Michel - It
                lua script?
                petewillP
                petewillP
                petewill
                @Michel---It said:
                lua script?
                Sorry, not sure what you're asking.
                  Maciej Kulawik
                  @Michal-Mormon
                  S_SCENE_CONTROLLER can send messages V_SCENE_ON and V_SCENE_OFF. If you send those messages for the first time, domoticz will create new switch with the name 'scene'.
                  Michal MormonM 1 Reply Last reply
                  • M Maciej Kulawik
                    @Michal-Mormon
                    Michal MormonM
                    Michal MormonM
                    Michal Mormon
                    @Maciej-Kulawik
                    I found it as 'Scene' switch but this example send only V_SCENE_ON the first time (the switch is still ON later)
                      @Maciej-Kulawik
                      Maciej Kulawik
                      @Michal-Mormon
                      Yes, exactly! It looks like without scene_off sent from scene controller in domoticz it will be one-time action (since if this scene switch is switched on you cannot switch it on again). You can try to setup automatic switching it off in domoticz.
                      • Michal MormonM
                        Michal MormonM
                        Michal Mormon
                        I added 2 lines and works perfect with Domoticz:
                        MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON);
                        MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //added line
                        gw.send(scene.set(keyInt));
                        gw.send(scene2.set(keyInt)); //added line
                        Michel - ItM 1 Reply Last reply
                          Michel - ItM
                          Michel - ItM
                          Michel - It
                          @Michal-Mormon awesome!
                          • DrJeffD
                            DrJeffD
                            DrJeff
                            @petewill Have you updated this code to 2.0 yet? What is different?
                            hekH petewillP 2 Replies Last reply
                            • DrJeffD DrJeff
                              @DrJeff
                              https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                              DrJeffD 1 Reply Last reply
                                @DrJeff
                                DrJeffD
                                DrJeffD
                                DrJeff
                                @hek
                                Yes I read but was soooo lazy! I just wanted it already done :grimacing:
                                I just update one of my old sensors it was a simple single relay. My others are way more complicated! I will give this a try.
                                • DrJeffD DrJeff
                                  petewillP
                                  petewillP
                                  petewill
                                  Not yet, but I'm slowly working on it. :) The link hek gave is very helpful if you want to try it yourself. It's a good way to learn about the new features in 2.0.
                                  • dvr123D
                                    dvr123D
                                    dvr123
                                    @petewill Any news about the 2.0 code? I am in the process of making scene controllers in the different rooms but can't get it to work.
                                    • dvr123D dvr123
                                      petewillP
                                      petewillP
                                      petewill
                                      @dvr123 No, not yet :grimacing:
                                      My thermostat project has taken priority over everything because I need one in my house. I have a prototype working but I need to finish it. It is taking much longer than expected and I also haven't had much time lately. Sorry.
                                      • Matt PittsM
                                        Matt PittsM
                                        Matt Pitts
                                        Hi Guys,
                                        I've been trying to compile this sketch without any success. I keep getting the following error when compiling
                                        #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                                        Can anyone help? thanks
                                        • Matt PittsM Matt Pitts
                                          Hi Guys,
                                          petewillP
                                          petewillP
                                          petewill
                                          @Matt-Pitts I still haven't had time to convert/test the sketch for version 2.0. If you want to take a shot at it there is info here: https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                                          I will get to it eventually I just have other projects that are consuming my time right now. Sorry.
