  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.8k Views 15 Watching
  • Łukasz KostrzewaŁ
    Łukasz KostrzewaŁ
    Łukasz Kostrzewa
    This post is deleted!
    • dvr123D
      dvr123D
      dvr123
      Why is Lukas' post deleted? I have got it in the mail and it seems to compile correctly.
      The only thing is that Domoticz only recognizes the button on the first click, after that Domoticz isn't receiving anything.
        Not sure why @Łukasz-Kostrzewa deleted it. As an administrator, I can still see the post.
        • Łukasz KostrzewaŁ
          Łukasz KostrzewaŁ
          Łukasz Kostrzewa
          Hi
          I delated my post because it pasted wrong. I try to paste it correctly but don't know how:( (hek - maybe You as an administrator can paste it corectly?)
          dvr123 have right that this code recognize the buton only on the first click:(
          Mayby someone knows how to modify the code to work like normal buton (not the scene controller)?
          Best regards
          • dvr123D
            dvr123D
            dvr123
            I am okey with the scene button, but it has to work more than one time :smile:
              @Łukasz-Kostrzewa, paste code within 3 backtick characters, like this:
              Insert Code Here
              • Łukasz KostrzewaŁ
                Łukasz KostrzewaŁ
                Łukasz Kostrzewa
                You could do that but it is not a great solution.
                Add to Domoticz all 8 switches (4 when pressed and 4 when hold).
                In first switch (pressed switch) add Slave device (first hold switch). Do it for all 4 switches.
                To 5,6,7,8 switches add Slave Device (1,2,3,4 switch).
                It works like that:
                When You press First number on keyboard it change state to ON and 5 to OFF
                When You Hold first number on keybord it change state of 5 switch to ON and first to OFF.
                Next You have to make some events to trigger some scenes or lights
                I have hope I managed to explain what I mean :)
                Best regards
                • Łukasz KostrzewaŁ
                  Łukasz KostrzewaŁ
                  Łukasz Kostrzewa
                  wrote on last edited by Łukasz Kostrzewa
                  #48
                  The 2.0 version code:
                  #include <Keypad.h>
                  #define NODE_ID 14 // or set to AUTO if you want gw to assign a NODE_ID for you.
                  #define SN "Scene Controller"
                  #define SV "1.0"
                  #define KEYPAD_CHILD_ID 95
                  MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON);
                  MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF);
                  const byte ROWS = 4; //four rows
                  const byte COLS = 1; //three columns
                  char keys[ROWS][COLS] = {
                    {'1'},
                    {'2'},
                    {'3'},
                    {'4'}
                  byte rowPins[ROWS] = {6, 7, 4, 5}; //connect to the row pinouts of the keypad
                  byte colPins[COLS] = {8}; //connect to the column pinouts of the keypad
                  Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
                  byte lastState;
                    sendSketchInfo(SN, SV);
                    present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
                    keypad.addEventListener(keypadEvent);
                    char key = keypad.getKey();
                  void keypadEvent(KeypadEvent key) {
                    switch (keypad.getState()) {
                      case PRESSED:
                        lastState = 1;
                        break;
                      case HOLD:
                        lastState = 2;
                        break;
                      case RELEASED:
                        int keyInt = key - '0'; //Quick way to convert Char to Int so it can be sent to controller
                        if (lastState == 2) {
                          keyInt = keyInt + 4; //If button is held, add 4.  If using more than 4 buttons this number will need to be changed
                        send(scene.set(keyInt));
                        break;
                  • dvr123D
                    dvr123D
                    dvr123
                    That's actually much easier! But how do we manage to get it working more than one time? Because I can add the button but after that I can't control it. I can't see the button presses in the Domoticz log either.
                    • Łukasz KostrzewaŁ
                      Łukasz KostrzewaŁ
                      Łukasz Kostrzewa
                      #50
                      Hi
                      After
                      Add
                      send(scene2.set(keyInt));
                      Write this code to arduino (now You can OFF all the switches) Next delete code You added and write it to Arduino once again but now in Domoticz make modifications I writed couple post higher. When You do that You will be able to control 4 scenes and another 4 will bo halpefull to OFF the first4 (when You hold the buttons)
                      • rechin304R
                        rechin304R
                        rechin304
                        Complete code version 2 with short press ON long press OFF.
                        #include <Keypad.h>
                        #define NODE_ID AUTO // or set to AUTO if you want gw to assign a NODE_ID for you.
                        #define SV "2.0"
                        MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON); //scene ON
                        MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //scene OFF
                        const byte COLS = 1; //one column
                          {'1'},
                          {'2'},
                          {'3'},
                          {'4'}
                        byte lastState;
                            case PRESSED:
                              lastState = 1;
                              break;
                            case HOLD:
                              lastState = 2;
                              break;
                            case RELEASED:
                                //keyInt = keyInt + 4; //If button is held, add 4.  If using more than 4 buttons this number will need to be changed
                              } else {
                              //break;
                        DrJeffD 1 Reply Last reply
                        • Łukasz KostrzewaŁ
                          Łukasz KostrzewaŁ
                          Łukasz Kostrzewa
                          Hi rechin304
                          Thank You for Your code...It's working great!!!
                          Best regards
                          rechin304R 1 Reply Last reply
                          • Łukasz KostrzewaŁ Łukasz Kostrzewa
                            Hi rechin304
                            Best regards
                            rechin304R
                            rechin304R
                            rechin304
                            @Łukasz-Kostrzewa you are welcome, all thanks goes to @petewill for initial code.
                            • Matt PittsM
                              Matt PittsM
                              Matt Pitts
                              Hi Guys,
                              I'm so glad that have updated the sketch which i have now been able to compile and get running :-)
                              But this is the message I get in the serial monitor and I only get these messages when I press button 3?? I am using a single row of four buttons as in the original sketch.
                              Am I missing something here? I was assuming the message with either be a 1 for a short press and 0 for a long press? I would be really grateful if someone who knows more about this than me is able to help me figure out what's going on?
                              TSP:MSG:SEND 11-11-0-0 s=95,c=1,t=19,pt=2,l=2,sg=0,ft=0,st=ok:3
                              TSP:MSG:SEND 11-11-0-0 s=95,c=1,t=19,pt=2,l=2,sg=0,ft=0,st=ok:7
                              • Matt PittsM Matt Pitts
                                Hi Guys,
                                rechin304R
                                rechin304R
                                rechin304
                                @Matt-Pitts on 3 is short press and in code is scene on and on long press is 7 scene off
                                      } else {
                                      send(scene.set(keyInt));```
                                • Matt PittsM
                                  Matt PittsM
                                  Matt Pitts
                                        } else {
                                  Hi Not sure if that helps me, I'm struggling to understand how this actually works? as I said the only button doing anything is 3, do I need to modify the sketch to get the other buttons working?
                                          } else {
                                    rechin304R
                                    rechin304R
                                    rechin304
                                    @Matt-Pitts then you need to check your conenction to all wires and if are correctly. Check first post as there is a picture.
                                    • rechin304R rechin304
                                      #include <Keypad.h>
                                      #define SV "2.0"
                                        {'1'},
                                        {'2'},
                                        {'3'},
                                        {'4'}
                                      byte lastState;
                                          case PRESSED:
                                            lastState = 1;
                                            break;
                                          case HOLD:
                                            lastState = 2;
                                            break;
                                          case RELEASED:
                                            } else {
                                            //break;
                                      DrJeffD
                                      DrJeffD
                                      DrJeff
                                      @rechin304
                                      Not getting the Hold on buttons working, everything else works. Any ideas why the long press doesn't work?
                                      • DrJeffD
                                        DrJeffD
                                        DrJeff
                                        Never mind part of the code was commented out. I wasn't sure because I just started to use OTA. But it's all good now its working fine. Here it is:
                                        #define MY_OTA_FIRMWARE_FEATURE
                                        #include <Keypad.h>
                                        #define SV "2.0"
                                          {'1'},
                                          {'2'},
                                          {'3'},
                                          {'4'}
                                        byte lastState;
                                            case PRESSED:
                                              lastState = 1;
                                              break;
                                            case HOLD:
                                              lastState = 2;
                                              break;
                                            case RELEASED:
                                              } else {
                                              break;
                                        • DrJeffD DrJeff
                                          #include <Keypad.h>
                                          #define SV "2.0"
                                            {'1'},
                                            {'2'},
                                            {'3'},
                                            {'4'}
                                          byte lastState;
                                              case PRESSED:
                                                lastState = 1;
                                                break;
                                              case HOLD:
                                                lastState = 2;
                                                break;
                                              case RELEASED:
                                                } else {
                                                break;
                                          rechin304R
                                          rechin304R
                                          rechin304
                                          @DrJeff ok, glad to hear you solved.
