  3. Gateway and Sensors are not connecting
3 Posts 2 Posters 1.6k Views 1 Watching
  • J Offline
    J Offline
    jhns
    i found this project about a year ago and bought some sensors etc.
    This week I got some time and motivation, so I started playing around.
    So I loaded the "SerialGateway" Example from the mysensors library on my arduino UNO and the "DimmableLight" Example on a fake Nano (first on a fake Mega, but the Mega threw the error message "failed init radio" or something like that).
    My Problem:
    I think they see each other, but the sensor node isn't registered by the gateway.
    I use MYSController for testing. The Debug tab shows the following:
    05.10.2015 19:21:59	STARTUP	Initialize message logging
    05.10.2015 19:21:59	STARTUP	MYSController 0.1.2.282
    05.10.2015 19:21:59	STARTUP	FPC 2.6.4 / Lazarus 1.4.2
    05.10.2015 19:21:59	STARTUP	still under development :) tekka 2015
    05.10.2015 19:21:59	STARTUP	Load INI file...
    05.10.2015 19:21:59	STARTUP	INI version 0.1.2.282
    05.10.2015 19:21:59	INFO	*** Logging START ***
    05.10.2015 19:21:59	VERSION	MYSController 0.1.2.282
    05.10.2015 19:21:59	STARTUP	INI file loaded
    05.10.2015 19:21:59	STARTUP	Loading FW repository...
    05.10.2015 19:21:59	REPO	FW "Blink" loaded. t=10, v=1, blocks=72, crc=0xD098
    05.10.2015 19:21:59	REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
    05.10.2015 19:21:59	REPO	FW "Sensebender Micro" loaded. t=100, v=1, blocks=1344, crc=0x3482
    05.10.2015 19:21:59	REPO	FW "Sensebender Blink" loaded. t=110, v=1, blocks=768, crc=0x1314
    05.10.2015 19:21:59	REPO	FW repository loaded. Items=4
    05.10.2015 19:21:59	STARTUP	Initialize message types
    05.10.2015 19:21:59	NODE	New node discovered, node id=0
    05.10.2015 19:21:59	NODE	New node discovered, node id=255
    05.10.2015 19:22:08	UPDATE	4295098650
    05.10.2015 19:22:16	INFO	Flushing FIFO
    05.10.2015 19:22:16	INFO	Connected to COM3
    05.10.2015 19:22:18	CHILD	New child discovered, node id=0, child id=0
    05.10.2015 19:22:18	RX	0;0;3;0;9;gateway started, id=0, parent=0, distance=0
    05.10.2015 19:22:18	RX	0;0;3;0;14;Gateway startup complete.
    # HERE IS THE SENSOR NODE POWERED ON
    05.10.2015 19:22:29	RX	0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    05.10.2015 19:22:30	RX	0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    05.10.2015 19:22:31	RX	0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    05.10.2015 19:22:32	RX	0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    05.10.2015 19:22:33	RX	0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    05.10.2015 19:22:34	RX	0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    05.10.2015 19:22:35	RX	0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    05.10.2015 19:22:36	RX	0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    05.10.2015 19:22:37	RX	0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    05.10.2015 19:22:38	RX	0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    And the sensor node Serial output prints the following:
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    sensor started, id=255, parent=255, distance=255
    find parent
    find parent
    find parent
    Light state: OFF
    find parent
    Node ready to receive messages...
    I also tried this with the SerialGateway and Dimmer example from the mysensors website, but same failure.
    I downloaded the library a few days ago so it should be everything the current version. Arduino IDE Version is: 1.6.5
    I already tried different radios (also one with external antenna), all chips are marked with the + version, but RF24 library GettingStarted example doesn't show the +. I haven't added capacitors to the radios, but I think this problem is software sided because it looks to me like they find each other.
    Any help appreciated :smiley:
    Greetings from Germany,
    Johannes
    PS: this project looks very cool and would be great if I get it to work.
    • hekH Offline
      hekH Offline
      Gateway answers the FIND_PARENT request from node... But node does not seem to get the response.
      Could very well be a powering issue. Caps usually resolves this type of behaviour.
      • J Offline
        J Offline
        jhns
        Ok thank you very much!
        You were right. Today my Caps came and now it's working perfect! :heart_eyes:
