  3. [SOLVED (but can somebody explain why)]Not getting any incoming messages...
9 Posts 3 Posters 3.1k Views 2 Watching
  • Steve CasterS
    Steve CasterS
    Steve Caster
    wrote on last edited by Steve Caster
    Hi all
    I am trying to make a controller for my blinds using a 2 channel relay. I am using MySensors 1.5 and arduino 1.6.5b as dev env.
    I am using the following sketch
    #define UP_PIN  3
    #define DOWN_PIN  4
    #define CHILD_ID 250
      gw.begin(incomingMessage, AUTO, false);
      gw.sendSketchInfo("Blinds", "1.0");
      gw.present(CHILD_ID, S_COVER,"Blinds",true);
      pinMode(UP_PIN, OUTPUT);
      pinMode(DOWN_PIN, OUTPUT);
      digitalWrite(UP_PIN, 0);
      digitalWrite(DOWN_PIN, 0);
      Serial.println( "Node ready to receive messages..." );
      gw.process();
      Serial.println(message.data);
      if (message.type==V_UP) {
         digitalWrite(UP_PIN,1);
         gw.sleep(15000);
         digitalWrite(UP_PIN,0);
         Serial.println("opening up covers");
       else if (message.type==V_DOWN) {
         digitalWrite(DOWN_PIN,1);
         gw.sleep(15000);
         digitalWrite(DOWN_PIN,0);
         Serial.println("closing up covers");
       else if (message.type==V_STOP) {
         Serial.println("stopping covers");
    In the gateway I get
    0;0;3;0;9;read: 250-250-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
    250;255;0;0;17;1.5
    0;0;3;0;9;read: 250-250-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    250;255;3;0;6;0
    0;0;3;0;9;read: 250-250-0 s=255,c=3,t=11,pt=0,l=6,sg=0:Blinds
    250;255;3;0;11;Blinds
    0;0;3;0;9;read: 250-250-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    250;255;3;0;12;1.0
    0;0;3;0;9;read: 250-250-0 s=250,c=0,t=5,pt=0,l=6,sg=0:Blinds
    0;0;3;0;9;send: 0-0-250-250 s=250,c=0,t=5,pt=0,l=6,sg=0,st=ok:Blinds
    250;250;0;0;5;Blinds
    I can see the blinds coming up in Domoticz and I can even send data to it (vtype 30,29 and 31) yet nothing is receiving the incoming message (The controller is still connected to my laptop so I can monitor them)
    Any clues why this goes wrong?
    Kind regards
    Steve
      How does the node log look like?
      • Steve CasterS
        Steve CasterS
        Steve Caster
        Hek I just updated the first post a bit (had some issues there I noticed)
        this is the node log
        send: 250-250-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
        send: 250-250-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        sensor started, id=250, parent=0, distance=1
        send: 250-250-0-0 s=255,c=3,t=11,pt=0,l=6,sg=0,st=ok:Blinds
        send: 250-250-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
        send: 250-250-0-0 s=250,c=0,t=5,pt=0,l=6,sg=0,st=ok:Blinds
        read: 0-0-250 s=250,c=0,t=5,pt=0,l=6,sg=0:Blinds
        Blinds
        UPDATE: I am a bit further. I can now send one command to the sensor, yet after that it fails. The relay will be enable, but another command fails.
        0;0;3;0;9;send: 0-0-250-250 s=10,c=1,t=30,pt=0,l=0,sg=0,st=ok:
        0;0;3;0;9;read: 1-3-0 s=0,c=1,t=0.0
        0;0;3;0;9;send: 0-0-250-250 s=10,c=1,t=29,pt=0,l=0,sg=0,st=fail:
        As you can see the V_CLOSE works, but the next command fails when I use gw.sleep. When I reset the sensor or use gw.wait they work again.
        I copied the latest sketch below
        #define UP_PIN  3
        #define DOWN_PIN  4
          gw.process();
             gw.wait(15000);
             gw.wait(15000);
          You are taking out too much power from the Arduino. Power relays separately.
          • Steve CasterS
            Steve CasterS
            Steve Caster
            Hey Hek,
            there is currently nothing connected to them. How come the wait works but the sleep doesn't? Does it mean it does no longer wake up?
            Kind regards
            fetsF 1 Reply Last reply
            • Steve CasterS Steve Caster
              Hey Hek,
              Kind regards
              fetsF
              fetsF
              fets
              @Steve-Caster how many time do you have between the V_DOWN and V_UP. Is it lower than 15s ?
              • Steve CasterS
                Steve CasterS
                Steve Caster
                Hi, I am waiting for the relay to stop and next try to use V_UP or V_DOWN. When I use gw.wait, it works fine and I can interrupt the motion by using V_STOP.
                  fetsF
                  fetsF
                  fets
                  @Steve-Caster so is everything good or do you have another question/issue ?
                  • Steve CasterS
                    Steve CasterS
                    Steve Caster
                    @fets I am good :) Thank for the support :)
