  3. Setting up mysensor and mysensor gateway
4 Posts 3 Posters 1.8k Views 1 Watching
  • A
    A
    arnoldg
    I have 2 arduino mini pro boards, both are hooked with an nrf24l01 and level shifter in between.
    when i startup the gateway board.
    i get this output on the serial port.
    next i powerup the sensor board, a simpel push button sketch is loaded i get the following data on the gateway.
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    255;255;3;0;3;
    sometimes when i connect digital pin 3 to gnd it send's something and somtimes not.
    but there is no differens in the sended data, so it looks to mee that there is somthing wrong, but i don't know what.
    below are some lines that where sended after connecting and disconecting pin 3 to ground.
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
      Your node requests an id.. hook gateway to a controller or set static id on the node.
      • dakkyD
        dakkyD
        dakky
        extending this question:
        I have this setup:
        node1 => gateway with mqtt Client => mosquitto as mqtt broker => openhab
        The result in the gateway is:
        0;0;3;0;9;MQTT connected
        0;0;3;0;9;Sending message on topic: gateway1-out/255/255/3/0/3
        does this mean, that autoassigning a node ID fails?
        Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
        Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
        Software: MySensors 2.0development
          Yep,
          Either you create a rule in openhab to answer these requests or set a static id in your node.
          (someone else have to answer how to create rules in OH)
