  3. Office plant monitoring
223 Posts 39 Posters 223.7k Views 42 Watching
  • J Jan Gatzke
    Just built this sensor and it is working great. However I am seeing different results with every run. It seems as if the value is always higher with one polarity than with the other one. Is this normal?
    @Jan-Gatzke I have updated my skech on codebender to report rolling average. I have not tested it yet though.
    The change is available at https://github.com/mfalkvidd/arduino-plantmoisture/commit/5e98c5e625075d62ae27956ab8dc3ea9dec4a29e
    J 1 Reply Last reply
      One more change https://github.com/mfalkvidd/arduino-plantmoisture/commit/299a4b273aee49b27a4cb3363574afec83ac2cd5
        J
        J
        Jan Gatzke
        @mfalkvidd At the moment I am testing a modified version of the sketch which always does two readings. I don't think this will have a big impact on the battery life because most power is consumend by the nrf and not by the sensor. Or am I wrong? The pullups are rated at 10k Ohm. The sensors resistance will be about the same in average. So we talk about 20k at 3V which is 0.15 mA. The nrf uses abot 15 mA when sending.
          Yes, but the nrf needs to be active approximately 1ms while the moisture reading needs about a second to be stable. So the consumption while reading is much larger than the consumption while sending.
          • mrc-coreM
            mrc-coreM
            mrc-core
            Hi.
            I have been trying to connect two sensors to the same arduino nano using this code and i have add sensor 1 pin to A0 and GND, and sensor 2 pin A1 and GND.
            But i only get the reads from sensor 1 sensor 2 doesn't appear...
            Can anyone help me with this on how to get more than one moisture sensor working.
            Thanks.
            • mrc-coreM mrc-core
              Hi.
              Thanks.
              @mrc-core there have been quite a few revisions of the sketch. The latest version (which can be found at github) only support one sensor, which is connected to A0 and A1 in the default configuration. Both pins are required to enable alternating the direction of the current when measuring, to try to minimize corrosion.
              Adding support for up to three sensors is technically possible (using A0-A5), but would make the code harder to read and since I have no use for multiple sensor I haven't spent the time required to program and test a sketch with multiple sensors.
              mrc-coreM 1 Reply Last reply
                #67
                An update on battery life: The sensor in my bonsai tree has been reporting every 11,5 minutes since 2015-11-07, so over the last ~four months it has done 24,504 measurements. The battery level has gone from 3.187V to 3.142V, which means a drop of 0.01125V per month. Assuming I let it go down to 2.34V (limit for 8MHz according to the datasheet) and that the voltage drop is linear, I should get (3.187-2.34)/0.01125 = 75 months = ~6 years. There are several error sources in this calculation, but it looks like battery life will be quite good, even though the sensor reports much more often than necessary.
                iotcrazyI 1 Reply Last reply
                  mrc-coreM
                  mrc-coreM
                  mrc-core
                  @mfalkvidd Thanks for the replay.
                  Will use only one sensor per arduino.
                  Once again thanks
                    iotcrazyI
                    iotcrazyI
                    iotcrazy
                    @mfalkvidd since you are using 2 AA battery(3V max) with a sensor , how are you powering the sensors ? What sensors are you using ?.Most of the sensors need 5V right ? how are you providing the required voltage for sensor ?. If possible can you share a circuit diagram or close up picture for your sensor node with connection to NRF , Sensor and battery ?
                    Appreciate it .
                    • iotcrazyI iotcrazy
                      Appreciate it .
                      @iotcrazy the fork is entirely passive so no requirements on voltage. See earlier posts in this thread for wiring information.
                        iotcrazyI
                        iotcrazyI
                        iotcrazy
                        wrote on last edited by iotcrazy
                        #71
                        @mfalkvidd sorry if questions seems like a dump . What do you mean by passive ? every sensors needs some voltage to perform a task right ?
                        I tried connecting a DHt11 Temp and humidity sensor using a arduino pro min(with led and voltage divider removed). It is connected to 2 AA battery. Unfortunate the node sends out value(proper value) only when I power on the Mini. It never sends the data again. However if I disconnect power supply and re attach it , it again sends the data. any idea what I am doing wrong ?
                        Also , whats the best way to create a Node which needs to monitor a sensor which uses 5 V . Arduino Mini is 3.3 V which.
                        • carlierdC
                          carlierdC
                          carlierd
                          Thanks for this useful and simple project !
                          My first node is running perfectly since 10 days.
                          Next step is to create a PCB and try running on a CR2032 to minimize the size (WAF request ;))
                          One question on the uses : when do you set a warning on the result ? When I need to water the flower ?
                          My first node is close to 50%, is it time ? Off course it depends on the nature of the flower but I was not able to found the information on Google ...
                          David.
                            I do just like I did before I had the sensors: stick a finger into the pot to feel if it needs water. If it does, I set the warning level to whatever level the sensor reports (or slightly higher).
                              Great idea @carlierd!
                              One that has everything mounted and you just stick into the plant soil would be really useful.
                              F 1 Reply Last reply
                              • scalzS
                                scalzS
                                wrote on last edited by scalz
                                #75
                                yep, I think that would be a nice module!
                                @mfalkvidd @hek I hope to not OT :flushed: I just want to show you few old school pics, a small jump back of 20years! My dad's stuff, a real maker ;)
                                This one was, I guess, the smallest soil moisture, in "virtual bulb", meaning there was no external electrodes, so no corrosion :
                                2nd: still in virtual bulb, humidity, salinity, roots temperature, temperature compensated, pH tendancy
                                Multi level soil moisture:
                                And these old Aurel 433mhz emitter/receiver !
                                I have lot of others old pics like this lol! He was selling his devices.
                                Few months ago, I have started to mix some of his old project with our new techno, but not finished! I would like to have sort of flo** pow** but more professional..still open. what!!
                                • carlierdC
                                  carlierdC
                                  carlierd
                                  @scalz : very interesting ! Will you plan to make one ? I am pretty sure that your design could be very very very small ;)
                                  • scalzS
                                    scalzS
                                    #77
                                    @carlierd yes this is planned, but don't know yet when ..I have already started something few months ago, but I need to think about few points mostly about the overall assembly, and to be sure of the power supply/battery I prefer..I will tell you when I will have something nice :)
                                    • carlierdC
                                      carlierdC
                                      carlierd
                                      wrote on last edited by carlierd
                                      #78
                                      I finally spent some hours on Eagles.
                                      See the result in this post !
                                      Do not hesitate to give me advice.
                                      David.
                                        Another update on battery life:
                                        The sensor in my bonsai tree has been reporting every 11,5 minutes since 2015-11-07, so over the last ~seven months it has done 48,965 measurements. It sends data over the radio every time, regardless if the value has changed. The battery level has gone from 3.187V to 3.134V, which means a drop of 0.0076V per month. Assuming I let it go down to 2.34V (limit for 8MHz according to the datasheet) and that the voltage drop is linear, I should get (3.187-2.34)/0.0076 = 111 months = ~9 years. There are several error sources in this calculation, but it looks like battery life will be quite good, even though the sensor reports much more often than necessary.
                                        • L
                                          L
                                          LastSamurai
                                          @mfalkvidd That sounds great! Are you using a pro mini too?
                                          I am using a 3V pro mini with power led and regulator removed and the nrf + sensor (on A0 and A1) connected and in about 1 day it dropped from 2945mV to 2907mV. Its running of of 2aa batteries and its on a breadboard for now (for testing).
                                          I am using your (slightly modified) code from above. Any idea why my power usage is so much higher?
                                          Here is my code:
                                          Based on https://github.com/mfalkvidd/arduino-plantmoisture
                                          This sketch uses the soilmoisture "forks" only that are found on ebay. They are connected between 2 analog pins where one gets pulled low and the other one measures.
                                          The pins are switched every time to avoid corrosion. Between readings the sensos sleeps to preserve batterylife.
                                          21.06.2016 V1.0 Base sketch
                                          #define round(x) ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
                                          #define CHILD_ID_MOISTURE 0
                                          #define CHILD_ID_BATTERY 1
                                          #define SLEEP_TIME 1800000 // Sleep time between reads (in milliseconds) - 30 minutes
                                          #define THRESHOLD 1.1 // Only make a new reading with reverse polarity if the change is larger than 10%.
                                          #define STABILIZATION_TIME 1000 // Let the sensor stabilize before reading
                                          #define BATTERY_FULL 3143 // 2xAA usually give 3.143V when full
                                          #define BATTERY_ZERO 1900 // 2.34V limit for 328p at 8MHz. 1.9V, limit for nrf24l01 without step-up. 2.8V limit for Atmega328 with default BOD settings.
                                          const int SENSOR_ANALOG_PINS[] = {A0, A1}; // Sensor is connected to these two pins. Avoid A3 if using ATSHA204. A6 and A7 cannot be used because they don't have pullups.
                                          MyMessage msg(CHILD_ID_MOISTURE, V_HUM);
                                          MyMessage voltage_msg(CHILD_ID_BATTERY, V_VOLTAGE);
                                          long oldvoltage = 0;
                                          byte direction = 0;
                                          int oldMoistureLevel = -1;
                                            gw.begin();
                                            gw.sendSketchInfo("Plant moisture w bat", "1.0 21062016");
                                            gw.present(CHILD_ID_MOISTURE, S_HUM);
                                            delay(250);
                                            gw.present(CHILD_ID_BATTERY, S_CUSTOM);
                                            Serial.println("Setting up pins...");
                                            // init sensor pins
                                            pinMode(SENSOR_ANALOG_PINS[0], OUTPUT);
                                            pinMode(SENSOR_ANALOG_PINS[1], OUTPUT);
                                            digitalWrite(SENSOR_ANALOG_PINS[0], LOW);
                                            digitalWrite(SENSOR_ANALOG_PINS[1], LOW);
                                            int moistureLevel = readMoisture();
                                            // Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
                                            // See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
                                            if (oldMoistureLevel == -1) { // First reading, save current value as old
                                              oldMoistureLevel = moistureLevel;
                                            if (moistureLevel > (oldMoistureLevel * THRESHOLD) || moistureLevel < (oldMoistureLevel / THRESHOLD)) {
                                              // The change was large, so it was probably not caused by the difference in internal pull-ups.
                                              // Measure again, this time with reversed polarity.
                                            // send value and reset level
                                            gw.send(msg.set((moistureLevel + oldMoistureLevel) / 2.0 / 10.23, 1));
                                            long voltage = readVcc();
                                            if (oldvoltage != voltage) { // Only send battery information if voltage has changed, to conserve battery.
                                              gw.send(voltage_msg.set(voltage / 1000.0, 3)); // redVcc returns millivolts. Set wants volts and how many decimals (3 in our case)
                                              gw.sendBatteryLevel(round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO)));
                                              oldvoltage = voltage;
                                            // sleep to conserve energy
                                            gw.sleep(SLEEP_TIME);
                                            Reads the current moisture level from the sensor.
                                            Alternates the polarity to reduce corrosion
                                          int readMoisture() {
                                            pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP); // Power on the sensor by activating the internal pullup
                                            analogRead(SENSOR_ANALOG_PINS[direction]);// Read once to let the ADC capacitor start charging
                                            gw.sleep(STABILIZATION_TIME);
                                            int sensorRead = analogRead(SENSOR_ANALOG_PINS[direction]);
                                            int moistureLevel = (1023 - sensorRead); // take the actual reading
                                            Serial.print("Sensor read: ");
                                            Serial.println(sensorRead);
                                            Serial.print("Moisture level: ");
                                            Serial.println(moistureLevel);
                                            // Turn off the sensor to conserve battery and minimize corrosion
                                            pinMode(SENSOR_ANALOG_PINS[direction], OUTPUT);
                                            digitalWrite(SENSOR_ANALOG_PINS[direction], LOW);
                                            direction = (direction + 1) % 2; // Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
                                            return moistureLevel;
                                          long readVcc() {
                                            // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                                          #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                                            ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
                                          #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                                            ADMUX = _BV(MUX5) | _BV(MUX0);
                                          #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                                            ADMUX = _BV(MUX3) | _BV(MUX2);
                                          #else
                                            while (bit_is_set(ADCSRA, ADSC)); // measuring
                                            long result = (high << 8) | low;
