  3. Office plant monitoring
223 Posts 39 Posters 223.7k Views 42 Watching
  • clivecC
    clivecC
    clivec
    Thought I would throw this in the pot
    Why not change the sensor Probe ?? no credit to me , just was googleing as you do,
    Home made sensors I think less prone to corrosion
    here's the link
    http://www.cheapvegetablegardener.com/how-to-make-cheap-soil-moisture-sensor-2/
    Had some seeds from very tasty tomatoes last year ,have planted and this year growing like tiffids !!
    Getting quite big so have move from kitchen to Greenhouse ASP really
    Will try with this type of sensor
    • clivecC clivec
      here's the link
      @mutantx nice idea, thanks for sharing!
      • Fat FlyF
        Fat FlyF
        Fat Fly
        wrote on last edited by Fat Fly
        #123
        I build moisture sensors from stainless wire. If this in pot at a depth of 1 inch domoticz reported 83% of moistre level.Real plant was dry and needed watering. I put moisture level on the soil
        and sensor reported moisture level 43%. I test and put moisture sensor to the soil at depth 1 inch
        Sensor reported moisture level 96%.
        • carlierdC
          carlierdC
          carlierd
          After several weeks I finally succeed to create a dedicated PCB ! It was started yesterday evening and works fine.
          Some pictures:
          Measure is reported each two hours. So I expect more than two years on a CR2032 (using @GertSanders firmware).
          I can off course provide any information as PCB.
          Thanks @mfalkvidd for the idea and the code. The project is now WAF ;)
          David.
          • Fat FlyF
            Fat FlyF
            Fat Fly
            Great. Nothing to say. But i need build this. 10 pcs first time. :) I live in farm or how to right say in english. With rubber boots from the land ?
            • Lukács AttilaL
              Lukács AttilaL
              Lukács Attila
              Is it possible to purchase it somewhere? :)
              • Fat FlyF
                Fat FlyF
                Fat Fly
                Why not mastered it self ?
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  Yesterday my sensor reported moisture 80% but soil was very wet. Thoughts.
                  mfalkviddM F 2 Replies Last reply
                  • Fat FlyF Fat Fly
                    @Fat-Fly that is normal. Did you expect something else? If so, what did you expect?
                    • Fat FlyF Fat Fly
                      F
                      F
                      flopp
                      @Fat-Fly
                      I have sensors that report 25-35% and they are still not dry.
                      I water for 10-20 min and they report 40%, sometimes 45%. But I know that when they report 25% it starts to be time to water.
                      • F flopp
                        @Fat-Fly
                        @flopp the level reported will depend on the following things (maybe more):
                        • the pullup resistor - varies between different arduinos
                        • the soil composition - varies between different pots
                        • the temperature - varies throughout the day
                        That means it is impossible to compare readings from two different Arduinos in the same pot and it is impossible to compare readings from different pots using the same Arduino.
                        F 1 Reply Last reply
                          F
                          F
                          flopp
                          @mfalkvidd
                          • Fat FlyF
                            Fat FlyF
                            Fat Fly
                            From temp varies moisture level and from fertilizer too. At the bottom of the bucket was more. Yesterday i install moisture sensor to the greenhouse. Level was 60-70%. This is normal if i check with finger. :). Today i try drive relays and water pump.
                            • NetRapN
                              NetRapN
                              NetRap
                              This sort of sensor is not good, because the electrolyticeffect.
                              You always should use soil sensors, which are based on the capacitive effect.
                              Like this one:
                              https://forum.mysensors.org/topic/4474/capacitive-soilsensor-for-measurement-the-humidity-of-flowers
                              Best regards,
                              NetRap
                              • Fat FlyF
                                Fat FlyF
                                Fat Fly
                                My sensors is not good yes. I do not understand what is soil moisture % really. :( My pepper was overwatering. Very wet and moisture was 80% only.
                                • NetRapN NetRap
                                  Like this one:
                                  Best regards,
                                  NetRap
                                  @NetRap there are downsides but "no good" is incorrect. I have used these sensors successfully for almost a year.
                                  • NetRapN
                                    NetRapN
                                    NetRap
                                    The problem is, that your design is based on conductivity.
                                    This means, that the electrodes will be destroyed over time
                                    and the produced metal salts are in your flower,garden,...
                                    I don't will have metal salts in my tomatoes !!! ;-)
                                    • NetRapN NetRap
                                      #138
                                      @NetRap I doubt that one second of 3V electric power every hour (0.03% duty cycle) will produce measurable amount of salt but yes, for food production capacitive measurements are probably better. The topic of this thread is "office plant monitoring" though and I hope you don't have to live off your office plants :)
                                      • m26872M
                                        m26872M
                                        m26872
                                        #139
                                        "Metal salts" doesn't sound very dangerous unless you're more specific. I prefer some NaCl on my tomatoes.
                                        How about some gold- or silver plated electrodes if you're of the worrying kind?
                                        • Fat FlyF
                                          Fat FlyF
                                          Fat Fly
                                          I want to try electrodes from stainless steel.
