  3. Office plant monitoring
223 Posts 39 Posters 223.7k Views 42 Watching
  • L
    L
    Lars65
    Normaly when you use eletricity and water, you need to sacrify something. For an example, when you cool a boat engine with water, you normaly use zinkanodes. I guess this is also the same when we want to messure humidity for an plant.
    So, if you should use copper anodes for messuring, you could paint them with a zink color.
    What it effects the resistance, I don't know.
    • Fat FlyF
      Fat FlyF
      Fat Fly
      Maybe in scketch needed change measure time? Maybe need use function round ?
      • L
        L
        LastSamurai
        @mfalkvidd Short question concerning battery life: I am using a custom board with an atmega328 and an nrf powered directly by a coin cell. When measuring temp/hum with something like an SHT21 the voltage drops are minimal (less than 100mV in more than a month). Using your sketch from post 25 here and connecting the fork to pins A1 and 2 (changed that in the sketch) I get a much higher power consumption. Any ideas why?
        I guess the measuring takes too long or something? It also reports lots of 1% changes to my domoticz server... which is kind of strange. Shouldn't the threshold take care of that? Perhaps I have to use a higher value here...
        • L LastSamurai
          @LastSamurai are you using the same sketch on both nodes?
          The sketch in post 25 sends the moisture value every 10 minutes. There are no thresholds and no comparison to previous value.
          Do the 1% changes look like a square wave? If so, the reason is probably that the pullup resistors differ from pin to min, even on the same atmega. A newer version of the sketch takes care of that, but I am still using the old version in my oldest node.
          As we discussed around post 79, my node is dropping very slowly. It is currently at 3.117 V after approximately 9 months on the same 2xAA. The node started at 3.187V so that is a drop of 70mV, less than 10mV per month.
          • Fat FlyF
            Fat FlyF
            Fat Fly
            Good morning people.
            Can somebody help add to this moisture sensing sketch relay ?
            • cattooC
              cattooC
              cattoo
              So does this work with 2.0?
              • cattooC cattoo
                @cattoo yes if it is converted.
                • cattooC
                  cattooC
                  cattoo
                  What needs to be added/edited so its converted?
                  • cattooC cattoo
                    @cattoo that is described in the instructions I linked to :)
                    • cattooC
                      cattooC
                      cattoo
                      Its driving me crazy! Could you not convert this mfalkvidd! Its better to have your sketch on the front instead of that one there is there now.
                      • cattooC cattoo
                        #151
                        @cattoo I won't convert it in the near future. I have too many projects that are more fun and more useful. My current setup works great, upgrading everything to 2.0 would mean a lot of work and no gain.
                        • Martin TellblomM
                          Martin TellblomM
                          Martin Tellblom
                          After my other failed attempt I needed to try this.
                          I have a 5V Mini using A4 and A5 and a fork YL-69 and I get these result:
                          Direction: 1
                          Moist: 171
                          Direction: 0
                          Moist: 23
                          Direction: 1
                          Moist: 172
                          Direction: 0
                          Moist: 0
                          Direction: 1
                          Moist: 164
                          Direction: 0
                          Moist: 0
                          Direction: 1
                          Moist: 156
                          Direction: 0
                          Moist: 0
                          Direction: 1
                          Moist: 144
                          Direction: 0
                          Moist: 0
                          This is not the percentage value , its this value I print: moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
                          Any Ideas?
                          MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
                          • Martin TellblomM Martin Tellblom
                            Direction: 1
                            Moist: 171
                            Direction: 0
                            Moist: 23
                            Direction: 1
                            Moist: 172
                            Direction: 0
                            Moist: 0
                            Direction: 1
                            Moist: 164
                            Direction: 0
                            Moist: 0
                            Direction: 1
                            Moist: 156
                            Direction: 0
                            Moist: 0
                            Direction: 1
                            Moist: 144
                            Direction: 0
                            Moist: 0
                            Any Ideas?
                            @Martin-Tellblom could you describe what an YL-69 is?
                            How much time do you let the measurement settle after switching directions?
                            Which of the code versions are you using? There have been many revisions in this thread and they all work slightly different.
                            Martin TellblomM 1 Reply Last reply
                              Martin TellblomM
                              Martin TellblomM
                              Martin Tellblom
                              wrote on last edited by Martin Tellblom
                              #154
                              @mfalkvidd said:
                              me do you le
                              My "Fork" is stamped with YL-69. Looks exacly like the XD-28
                              It's your code from post 25 so I suppose 1000 (#define STABILIZATION_TIME 1000 )
                                @mfalkvidd said:
                                me do you le
                                @Martin-Tellblom Thanks. You did throw away the middle chip and only use the fork, right? (as described in post 41)
                                  Martin TellblomM
                                  Martin TellblomM
                                  Martin Tellblom
                                  #156
                                  @mfalkvidd : Yes I did, and I have tried using A2&A3 and its the same
                                    @Martin-Tellblom can you try another Arduino?
                                    • Martin TellblomM
                                      Martin TellblomM
                                      Martin Tellblom
                                      @mfalkvidd
                                      Have tried both a 3.3V and a 5V both behave the same.
                                      I check every 30 seconds now and after about 10 minutes the result is 0 on both directions.
                                      I restart the arduino and then one direction shows a value and the other 0.
                                      There is proberbly something with my forks :)
                                      Did I mention that I upgraded the sketch to 2.0? Could that be a problem?
                                        @mfalkvidd
                                        They are (or at least should be) completely passive, so there is nothing that should be able to go wrong.
                                        Could you post a photo of your connections?
                                        If you disconnect the fork from the Arduino and measure the resistance between the two connectors using a multimeter (in both directions), what resistance do you get?
                                        Not if you did it right :) I have no experience with 2.0 unfortunately.
                                        Martin TellblomM 2 Replies Last reply
                                          Martin TellblomM
                                          Martin TellblomM
                                          Martin Tellblom
                                          @mfalkvidd
                                          I at the office right now, measure them when I home
