  3. Wall mounted 'mood light'
23 Posts 10 Posters 20.6k Views 15 Watching
  • Tore André RosanderT Tore André Rosander
    Im building the same light, but i use 12v LED strips controlled with mosfets. Is it possible to use the same scetch?
    AWIA
    AWIA
    AWI
    @Tore-André-Rosander If you use standard 12v strips it won't work as such. The ws2812/11 chips in the strip used make it possible to address the individual led's.
    Tore André RosanderT 1 Reply Last reply
    • AWIA AWI
      Tore André Rosander
      wrote on last edited by Tore André Rosander
      #22
      @AWI Is this code for version 1.5?
      Im trying to compile it for the dev (v2) but i get a lot of errors.
      Mostly alot of code that "was not declared in this scope".
      EDIT: Just found your link to the "Conversion guide", will have look at it!
        A version for MySensors 2 is available at https://forum.mysensors.org/topic/4934/wall-mounted-mood-light-v2
