  3. Wall mounted 'mood light'
23 Posts 10 Posters 20.6k Views 15 Watching
  • A
    Adam McCartney
    @mickaelr30 , did you ever get this working with 1.5?
    i've got the upgrade instructions, but struggling to reverse it so it works with my current setup. Don't think i'm quite ready to upgrade all my nodes to dev quite yet.
    AWIA 1 Reply Last reply
    • A Adam McCartney
      AWIA
      AWIA
      AWI
      @Adam-McCartney add these lines in the header and you will have it working with the production version...
      // V_TEXT & V_INFO when not using the DEVELOPMENT version
      const byte V_TEXT = 47 ;					// values taken from development edition MyMessage.h
      const byte S_INFO = 36 ;
      • A
        Adam McCartney
        awesome, thanks!
        I'm more of a butcher than a surgeon. I can quite happily take things apart, but fixing things usually goes right over my head!!
          Mehdi HAMIDA
          I really love this project.
          May I can include it in all of my sensors (doorbell, thermostat, alarm,...).
          Really sounds great, thanks
            Mehdi HAMIDA
            Is there a way to get your wiring schema ?
            • M Mehdi HAMIDA
              AWIA
              AWIA
              AWI
              @Mehdi-HAMIDA There is nothing to it. A standard MySensors node (5v) with the strip connected to D5 and a button between ground and D4.
              const int stripPin = 5 ;                                    // pin where 2812 LED strip is connected
              const int buttonPin = 4 ;                                   // push button
              • AWIA AWI
                Mehdi HAMIDA
                @AWI OK, just ordered the PCB
                thx
                • mfalkviddM
                  @AWI: Won't this part of your sketch create sort of an endless loop?
                          case RGB_TextColorChild:                            // Text color from controller
                              if (message.type == V_TEXT) {                   // if get color from text child
                                  gw.request(RGB_TextColorChild, V_TEXT);
                    AWIA
                    AWIA
                    AWI
                    @mfalkvidd Good observation. Probably the the result of an 'efficient' copy/paste :flushed:
                    The line
                    I there with no reason, can be deleted...
                    • Tore André RosanderT
                      Tore André Rosander
                      Im building the same light, but i use 12v LED strips controlled with mosfets. Is it possible to use the same scetch?
                      • Tore André RosanderT Tore André Rosander
                        AWIA
                        AWIA
                        AWI
                        @Tore-André-Rosander If you use standard 12v strips it won't work as such. The ws2812/11 chips in the strip used make it possible to address the individual led's.
                        Tore André RosanderT 1 Reply Last reply
                        • AWIA AWI
                          Tore André Rosander
                          wrote on last edited by Tore André Rosander
                          #22
                          @AWI Is this code for version 1.5?
                          Im trying to compile it for the dev (v2) but i get a lot of errors.
                          Mostly alot of code that "was not declared in this scope".
                          EDIT: Just found your link to the "Conversion guide", will have look at it!
                          • mfalkviddM
                            A version for MySensors 2 is available at https://forum.mysensors.org/topic/4934/wall-mounted-mood-light-v2
                            12.5k
