  3. ESP8266 Gateway can't Press start for inclusion
8 Posts 3 Posters 4.3k Views 2 Watching
  • O
    O
    Opus40
    wrote on last edited by Opus40
    Hi All
    Been a while as my setup had been running flawlessly, then my vera had some issues and long story short I had to start again. I decided to try the Esp8266 Wifi gateway, and all seemed to go well until I can't get inclusion working.
    My vera is running 1.7.388 I have got the sensor up and running and can ping it and connect to it with MYSController, I added it to Vera and it comes up w ith the logo and Connected to:192.168.1.201:5003 but when I go to do an inclusion nothing happens it doesn't register the click on start .
    Any help i can get to get this working again I would really appreciate
    thanks in advance
    • O
      O
      Opus40
      OK I have done some more trouble shooting and have come up with what happens
      If I re-flash the Gateway back to the stable (MySensors Arduino library) then I can get Vera to start inclusion mode and find my nodes. but when it does my light sensors report the wrong data from another thread I learnt that the development MySensors Arduino library gateway build fixes this. I flash back to Developmental build and my light and motion start working on nodes that I have all ready included, only now I can not add any more with out re-flashing back then adding and then re-flashing again so I get the right info reported from my nodes.
      Am I missing some thing?
      at least for the moment I have every thing working :)
        I just fixed a couple of issues with the inclusion mode/button feature.
        https://github.com/mysensors/Arduino/pull/239/files
        Might be worth to give it another try.
        • O
          O
          Opus40
          Thanks Hek I will give it a go tonight and let you know the out come.
          Cheers
          • O
            O
            Opus40
            I gave it ago but still no luck with the inclusion mode
              wrote on last edited by hek
              You have enabled
              right?
              Which esp pin are you using for the inclusion button (if you have one)?
              I see that pin 3 seem to be used for flash.. not sure if that is such a good choice.
              • O
                O
                Opus40
                I haven't got a Inclusion button (physical) setup just using the software start button from Vera. I will try using a physical button see if that helps.
                I'm using the NodeMCU board
                • I
                  I
                  Ironbar
                  @Opus40
                  Try changing browsers. I've had that happen in other browsers but it seems to work fine with Chrome.
