  3. Vera
  4. VERA 2 Device Install
64 Posts 11 Posters 43.4k Views 1 Watching
  • clippermiamiC
    clippermiamiC
    clippermiami
    wrote on last edited by hek
    I've just installed the VERA files for the Ethernet Gateway and noticed something ... the device shows
    Plugin Version 1.3
    Lib Version {blank}
    Is this correct or do I have an error somewhere?
      Plugin version = Version of the vera plugin files
      Lib Version = Version of the MySensors library in the attached arduino
      So, the blank value will update the first time your vera-plugin gets in touch with the Arduino.
      • clippermiamiC
        clippermiamiC
        clippermiami
        Ok, thanks.
        • clippermiamiC
          clippermiamiC
          clippermiami
          One thing I've noticed, the VERA interface installs fine but if the gateway is not available the interface appears to tie up VERA until it either becomes available or times out --- the VERA interface becomes unresponsive to the keyboard/mouse until this happens. Would be good if it released the interface while it waits for the gateway or timeout.
            I haven't seen this behavior. Just out of curiosity... Why is the gateway not available?
            I'm afraid we cannot do much about how Vera handles serial communication failures.
            • DeltaNu1142D
              DeltaNu1142D
              DeltaNu1142
              wrote on last edited by DeltaNu1142
              I'm still having issues getting my Gateway to appear in Vera. I have a Nano with a NRF24L01 radio module. The SerialGateway sketch uploaded fine, and I received a "0;0;4;11;Arduino startup complete" message via Serial Monitor in the IDE.
              What should I be looking for in the \dev folder in Vera to see if the Arduino is plugged in? Here's a screen shot of WinSCP: http://i.imgur.com/n6UD0cV.png
              Here's what I'm seeing in the UI: http://i.imgur.com/l5Z5eG7.png
              I've posted this in the Vera forum, but I realize you're probably trying to drive Arduino-specific questions to this forum...
              EDIT: I just noticed that this "1" appears under \dev\usb\tts when the Arduino is plugged in. I just need to get the device to appear: http://i.imgur.com/Pln0mGb.png
              • DeltaNu1142D
                DeltaNu1142D
                DeltaNu1142
                Troubleshooting...
                I added I_Arduino1.xml to the impl_file field for the device, to see if that would do... anything. Nope. I've also configured the baud rate in Vera for the new "blank" device, and I'm getting nothing.
                Is it possible that this is attributable to the fact that I'm using a Vera 2 and not a Vera 3?!?
                  It might. I haven't heard anyone that confirmed that it is working on Vera2.
                  Does Vera2 have the same firmware version as VeraLite/Vera3?
                  DeltaNu1142D 1 Reply Last reply
                    DeltaNu1142D
                    DeltaNu1142D
                    DeltaNu1142
                    @hek I'm on v1.5.622. I'll be disappointed, because I've gone & invested probably $150 in Nanos, radios, and other stuff.
                      That is the same firmware as I have.
                      When I plug in the gateway this pops up in /dev
                      crw-rw-rw- 1 root root 188, 0 Apr 14 22:06 ttyUSB0
                      • DeltaNu1142D
                        DeltaNu1142D
                        DeltaNu1142
                        When I plug in, I definitely see a new USB device in dev\usb\tts\ (from memory, I think that's correct). I responded to a question over at the micasaverde forum about my logs... I get no reference to Arduino in my logs upon restart, so something is not right.
                        hekH 1 Reply Last reply
                        • DeltaNu1142D DeltaNu1142
                          @DeltaNu1142
                          It is quite hard to get a grip on what is going wrong on your Vera unit. Are you aware of any other plugins not working on Vera2?
                          Unfortunately I have no unit to test this on and the micasa-forum does not give much info on general Vera2 incompatibilities when I search.
                            @DeltaNu1142
                            DeltaNu1142D
                            DeltaNu1142D
                            DeltaNu1142
                            @hek
                            Everything else I use works... PLEG, Day or Night, Garage Door, AD2USB... I'm also successfully logging to a USB flash drive in the same USB hub as the Arduino is plugged into.
                            The only other problem I have associated with using a Vera 2 is that the Synology configuration for logging to my NAS won't work as it does for Vera 3.
                            I'd like to get this working, but I have nothing else to go on.
                              @DeltaNu1142
                              Did you see any errors in the Vera log when you added the Arduino plugin? I wonder why the device is blank in your picture.. Did you open and save the device files in any editor after download zip-file from github (introducting some encoding problem)?
                              If this somehow is related to USB problems you should be able to rebuild you gateway and use the Ethernet-mode of the plugin.
                              • DeltaNu1142D
                                DeltaNu1142D
                                DeltaNu1142
                                I'll log again and add the device later today. If the device doesn't add correctly, though, I don't know how using an Ethernet gateway would fix my issue.
                                Re:device files, no, I just downloaded & then uploaded to Vera.
                                  When I looking at the screenshot you posted on micasa I would suspect you have corrupted the plugin files when you downloaded them.
                                  Use this:
                                  https://github.com/mysensors/Vera/archive/master.zip
                                  Unzip and upload all device files again.
                                    Use this:
                                    DeltaNu1142D
                                    DeltaNu1142D
                                    DeltaNu1142
                                    I've reloaded the plugin files and will try again later.
                                    • DeltaNu1142D
                                      DeltaNu1142D
                                      DeltaNu1142
                                      OK, when I got home, I downloaded the ZIP from this site, dropped the files on my desktop, and loaded them to Vera. I checked the box to reboot Luup, and shortly after I hit "Go," I received an "upload successful" message. I refreshed the browser and created the device, ID # 142. The log from the moment I created the device looks like this:
                                      08 04/15/14 18:40:11.223 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: CreateDevice <0x641a>
                                      08 04/15/14 18:40:11.224 JobHandler_LuaUPnP::HandleActionRequest argument UpnpDevFilename=D_Arduino1.xml <0x641a>
                                      08 04/15/14 18:40:11.224 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNumParent=0 <0x641a>
                                      08 04/15/14 18:40:11.225 JobHandler_LuaUPnP::HandleActionRequest argument RoomNum=0 <0x641a>
                                      02 04/15/14 18:40:15.075 JobHandler::Run job#97 :getnodedetails_ri 51 dev:139 (0xe42ad8) P:110 S:0 node 51 is 60.50265000 seconds old <0xc04>
                                      06 04/15/14 18:40:17.364 Device_Variable::m_szValue_set device: 139 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: LastRouteUpdate was: 1397601391 now: 1397601617 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0xc04>
                                      06 04/15/14 18:40:17.365 Device_Variable::m_szValue_set device: 139 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: Neighbors was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0xc04>
                                      04 04/15/14 18:40:17.368 <0xc04>
                                      50 04/15/14 18:40:19.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:40:19.113 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:40:19.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:40:29.176 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:40:29.178 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:40:29.264 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      02 04/15/14 18:40:35.015 ZZZ-POLLING H1,C1,H2,C2,/1/1 <0xc04>
                                      02 04/15/14 18:40:35.018 ZW_Send_Data node 2 USING ROUTE 4.0.0.0 <0xc04>
                                      02 04/15/14 18:40:37.362 ZW_Send_Data node 2 USING ROUTE 4.0.0.0 <0xc04>
                                      06 04/15/14 18:40:37.612 Device_Variable::m_szValue_set device: 69 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 74 now: 74 #hooks: 0 upnp: 0 v:0x9f6b10/NONE duplicate:1 <0x803>
                                      50 04/15/14 18:40:39.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:40:39.112 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:40:39.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      02 04/15/14 18:40:39.623 ZW_Send_Data node 2 USING ROUTE 4.0.0.0 <0xc04>
                                      02 04/15/14 18:40:41.782 ZW_Send_Data node 2 USING ROUTE 4.0.0.0 <0xc04>
                                      02 04/15/14 18:40:43.922 ZW_Send_Data node 2 USING ROUTE 4.0.0.0 <0xc04>
                                      06 04/15/14 18:40:44.071 Device_Variable::m_szValue_set device: 69 service: urn:upnp-org:serviceId:HVAC_FanOperatingMode1 variable: Mode was: Auto now: Auto #hooks: 0 upnp: 0 v:0x9c5ae0/NONE duplicate:1 <0x803>
                                      02 04/15/14 18:40:46.082 ZW_Send_Data node 2 USING ROUTE 4.0.0.0 <0xc04>
                                      02 04/15/14 18:40:48.252 ZW_Send_Data node 2 USING ROUTE 4.0.0.0 <0xc04>
                                      04 04/15/14 18:40:48.404 <0x803>
                                      50 04/15/14 18:40:49.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:40:49.112 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:40:49.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      ...much of the end of that isn't pertinent, but after creating the device, it's still completely blank.
                                      Here's the log from when I plug the Arduino into the USB port:
                                      02 04/15/14 18:45:35.017 ZW_Send_Data node 30 NO ROUTE (nil) <0xc04>
                                      04 04/15/14 18:45:35.314 <0x803>
                                      50 04/15/14 18:45:39.162 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:45:39.163 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:45:39.215 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:45:49.149 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:45:49.150 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:45:49.224 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:45:59.112 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:45:59.114 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:45:59.165 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      02 04/15/14 18:46:05.017 ZW_Send_Data node 31 NO ROUTE (nil) <0xc04>
                                      04 04/15/14 18:46:05.644 <0x803>
                                      50 04/15/14 18:46:09.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:46:09.112 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:46:09.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:46:19.197 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:46:19.199 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:46:19.334 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:46:29.163 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:46:29.165 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:46:29.215 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      02 04/15/14 18:46:35.017 ZW_Send_Data node 32 NO ROUTE (nil) <0xc04>
                                      04 04/15/14 18:46:35.333 <0x803>
                                      50 04/15/14 18:46:39.218 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:46:39.219 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:46:39.292 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:46:49.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:46:49.113 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:46:49.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:46:59.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:46:59.112 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:46:59.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      02 04/15/14 18:47:05.017 ZW_Send_Data node 33 USING ROUTE 255.114.101.100 <0xc04>
                                      04 04/15/14 18:47:05.154 <0x803>
                                      50 04/15/14 18:47:09.144 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:47:09.146 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:47:09.205 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:47:19.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:47:19.112 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:47:19.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:47:29.110 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:47:29.112 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:47:29.163 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      02 04/15/14 18:47:35.018 ZW_Send_Data node 34 NO ROUTE (nil) <0xc04>
                                      04 04/15/14 18:47:35.663 <0x803>
                                      50 04/15/14 18:47:39.112 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:47:39.114 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:47:39.166 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:47:49.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:47:49.113 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:47:49.173 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      06 04/15/14 18:47:58.869 Device_Variable::m_szValue_set device: 100 service: urn:micasaverde-com:serviceId:AlarmPartition2 variable: DetailedArmMode was: Ready now: NotReady #hooks: 2 upnp: 0 v:0xa881d8/NONE duplicate:0 <0x7c1c>
                                      07 04/15/14 18:47:58.976 Event::Evaluate 25 Alarm Armed AWAY scene All Lights Off (away) is false repeat 0/-1 <0x7c1c>
                                      06 04/15/14 18:47:59.309 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicC variable: ObjectStatusMap was: {{name = 'At_Work_s1', state = false, seq = 1.39756e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Alarm_Disarmed_t6', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_t9', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39657e+09},{name = 'First_Floor_Motion_Not_Tripped_t11', state = true, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39757e+09, oseq = 1.39757e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39759e+09, oseq = 1.39758e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_c2', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Home_c3', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_c4', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},} now: {{name = 'At_Work_s1', state = false, seq = 1.39756e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Alarm_Disarmed_t6', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_t9', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39657e+09},{name = 'First_Floor_Motion_Not_Tripped_t11', state = true, seq = 1.3976
                                      e+09, oseq = 1.3976e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39757e+09, oseq = 1.39757e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39759e+09, oseq = 1.39758e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_c2', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Home_c3', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_c4', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},{name = 'NOW', state = true, seq = 1.3976e+09, oseq = 0},} #hooks: 0 upnp: 0 v:0xa715b8/NONE duplicate:0 <0x7c1c>
                                      50 04/15/14 18:47:59.388 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:47:59.389 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:47:59.459 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastTrip was: 1397600784 now: 1397602079 #hooks: 0 upnp: 0 v:0xa539c8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:47:59.501 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      06 04/15/14 18:47:59.641 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 0 now: 1 #hooks: 1 upnp: 0 v:0xa522f8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:47:59.790 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicC variable: ObjectStatusMap was: {{name = 'At_Work_s1', state = false, seq = 1.39756e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Alarm_Disarmed_t6', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_t9', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39657e+09},{name = 'First_Floor_Motion_Not_Tripped_t11', state = true, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39757e+09, oseq = 1.39757e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39759e+09, oseq = 1.39758e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_c2', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Home_c3', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_c4', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},{name = 'NOW', state = true, seq = 1.3976e+09, oseq = 0},} now: {{name = 'At_Work_s1', state = false, seq = 1.39756e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Alarm_Disarmed_t6', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_t9', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39657e+09},{name = 'First_
                                      Floor_Motion_Not_Tripped_t11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39757e+09, oseq = 1.39757e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39759e+09, oseq = 1.39758e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = true, seq = 1.39756e+09, oseq = 1.39752e+09},{name = 'Night_c2', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Home_c3', state = true, seq = 1.3976e+09, oseq = 1.39759e+09},{name = 'Away_c4', state = false, seq = 1.39759e+09, oseq = 1.3976e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = false, seq = 1.39752e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},{name = 'NOW', state = true, seq = 1.3976e+09, oseq = 0},} #hooks: 0 upnp: 0 v:0xa715b8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:48:02.725 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastTrip was: 1397602079 now: 1397602082 #hooks: 0 upnp: 0 v:0xa539c8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:48:02.771 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 1 now: 1 #hooks: 1 upnp: 0 v:0xa522f8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:48:03.780 Device_Variable::m_szValue_set device: 100 service: urn:micasaverde-com:serviceId:AlarmPartition2 variable: DetailedArmMode was: NotReady now: Ready #hooks: 2 upnp: 0 v:0xa881d8/NONE duplicate:0 <0x7c1c>
                                      07 04/15/14 18:48:03.782 Event::Evaluate 25 Alarm Armed AWAY scene All Lights Off (away) is false repeat 0/-1 <0x7c1c>
                                      02 04/15/14 18:48:05.016 ZW_Send_Data node 36 NO ROUTE (nil) <0xc04>
                                      04 04/15/14 18:48:05.314 <0x803>
                                      50 04/15/14 18:48:09.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:48:09.112 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:48:09.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      50 04/15/14 18:48:19.111 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:48:19.113 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      06 04/15/14 18:48:19.164 Device_Variable::m_szValue_set device: 125 service: urn:upnp-org:serviceId:VGhost1 variable: State was: 0 now: 0 #hooks: 0 upnp: 0 v:0xabb398/NONE duplicate:1 <0x4412>
                                      06 04/15/14 18:48:22.957 Device_Variable::m_szValue_set device: 100 service: urn:micasaverde-com:serviceId:AlarmPartition2 variable: DetailedArmMode was: Ready now: NotReady #hooks: 2 upnp: 0 v:0xa881d8/NONE duplicate:0 <0x7c1c>
                                      07 04/15/14 18:48:23.021 Event::Evaluate 25 Alarm Armed AWAY scene All Lights Off (away) is false repeat 0/-1 <0x7c1c>
                                      06 04/15/14 18:48:23.104 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastTrip was: 1397602082 now: 1397602103 #hooks: 0 upnp: 0 v:0xa539c8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:48:23.106 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 1 now: 1 #hooks: 1 upnp: 0 v:0xa522f8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:48:26.839 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastTrip was: 1397602103 now: 1397602106 #hooks: 0 upnp: 0 v:0xa539c8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:48:26.891 Device_Variable::m_szValue_set device: 105 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 1 now: 1 #hooks: 1 upnp: 0 v:0xa522f8/NONE duplicate:0 <0x7c1c>
                                      06 04/15/14 18:48:27.828 Device_Variable::m_szValue_set device: 100 service: urn:micasaverde-com:serviceId:AlarmPartition2 variable: DetailedArmMode was: NotReady now: Ready #hooks: 2 upnp: 0 v:0xa881d8/NONE duplicate:0 <0x7c1c>
                                      07 04/15/14 18:48:27.830 Event::Evaluate 25 Alarm Armed AWAY scene All Lights Off (away) is false repeat 0/-1 <0x7c1c>
                                      50 04/15/14 18:48:29.112 luup_log:125: VGinfo: Calling main loop with lul_device: 125 <0x4412>
                                      50 04/15/14 18:48:29.114 luup_log:125: VGinitPhase: VacationGhost is disabled, sleep and start over <0x4412>
                                      Same result... it still doesn't work.
                                        @DeltaNu1142 said:
                                        I don't see the log from where you created device (#142).
                                          DeltaNu1142D
                                          DeltaNu1142D
                                          DeltaNu1142
                                          @hek
                                          That's the first log.
                                          Last night, I removed all Arduino files from Vera via SSH and then restarted. This morning, I re-uploaded all files, restarted, and then created the device. Here's the log, started before I clicked "Create Device" and received a confirmation that device # 143 was created:
                                          50 04/16/14 7:03:57.030 luup_log:60: New Status is: 1 <0x400>
                                          06 04/16/14 7:03:57.031 Device_Variable::m_szValue_set device: 60 service: urn:rts-services-com:serviceId:DayTime variable: Target was: 0 now: 1 #hooks: 0 upnp: 0 v:0x9b5f98/NONE duplicate:0 <0x400>
                                          06 04/16/14 7:03:57.032 Device_Variable::m_szValue_set device: 60 service: urn:rts-services-com:serviceId:DayTime variable: Status was: 0 now: 1 #hooks: 2 upnp: 0 v:0x9b6f60/NONE duplicate:0 <0x400>
                                          07 04/16/14 7:03:57.033 Event::Evaluate 28 Daytime scene Daytime is true users:(null) allow:1 <0x400>
                                          08 04/16/14 7:03:57.034 Scene::RunScene running 74 Daytime <0x400>
                                          08 04/16/14 7:03:57.035 JobHandler_LuaUPnP::HandleActionRequest device: 124 service: urn:dcineco-com:serviceId:MSwitch1 action: SetStatus7 <0x400>
                                          08 04/16/14 7:03:57.035 JobHandler_LuaUPnP::HandleActionRequest argument newStatus7=1 <0x400>
                                          07 04/16/14 7:03:57.038 Event::Evaluate 29 Nighttime scene Nighttime is false repeat 0/-1 <0x400>
                                          04 04/16/14 7:03:57.040 <0x400>
                                          06 04/16/14 7:03:57.043 Device_Variable::m_szValue_set device: 124 service: urn:dcineco-com:serviceId:MSwitch1 variable: Status7 was: 0 now: 1 #hooks: 1 upnp: 0 v:0xa8f700/NONE duplicate:0 <0x400>
                                          06 04/16/14 7:03:57.050 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: ConditionSatisfied was: None now: Day_c1 #hooks: 2 upnp: 0 v:0xa58258/NONE duplicate:0 <0x400>
                                          07 04/16/14 7:03:57.052 Event::Evaluate 20 Garage Door #2 Left Open scene Prowl Notifications is false repeat 0/-1 <0x400>
                                          07 04/16/14 7:03:57.053 Event::Evaluate 21 Garage Door #1 Left Open scene Prowl Notifications is false repeat 0/-1 <0x400>
                                          06 04/16/14 7:03:57.054 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: LastConditionChange was: 1397646126 now: 1397646237 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
                                          08 04/16/14 7:03:57.055 JobHandler_LuaUPnP::HandleActionRequest device: 98 service: urn:rts-services-com:serviceId:ProgramLogicC action: RunAction <0x400>
                                          08 04/16/14 7:03:57.056 JobHandler_LuaUPnP::HandleActionRequest argument conditionName=Day_c1 <0x400>
                                          06 04/16/14 7:03:57.164 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicC variable: ObjectStatusMap was: {{name = 'At_Work_s1', state = true, seq = 1.39765e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = false, seq = 1.3976e+09, oseq = 1.39761e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Alarm_Disarmed_t6', state = false, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.39763e+09, oseq = 1.39765e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = false, seq = 1.39756e+09, oseq = 1.39761e+09},{name = 'Night_t9', state = true, seq = 1.39761e+09, oseq = 1.39756e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39762e+09},{name = 'First_Floor_Motion_Not_Tripped_t11', state = true, seq = 1.39765e+09, oseq = 1.39762e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = false, seq = 1.39756e+09, oseq = 1.39761e+09},{name = 'Night_c2', state = true, seq = 1.39761e+09, oseq = 1.39756e+09},{name = 'Home_c3', state = false, seq = 1.3976e+09, oseq = 1.39762e+09},{name = 'Away_c4', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},} now: {{name = 'At_Work_s1', state = true, seq = 1.39765e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = false, seq = 1.3976e+09, oseq = 1.39761e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Alarm_Disarmed_t6', state = false, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.39763e+09, oseq = 1.39765e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = true, seq = 1.39765e+09, oseq = 1.39761e+09},{name = 'Night_t9', state = true, seq = 1.39761e+09, oseq = 1.39756e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39762e+09},{name = 'First_Floor_Motion_Not_Tripped_t11', state = true, s
                                          eq = 1.39765e+09, oseq = 1.39762e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = true, seq = 1.39765e+09, oseq = 1.39761e+09},{name = 'Night_c2', state = true, seq = 1.39761e+09, oseq = 1.39756e+09},{name = 'Home_c3', state = false, seq = 1.3976e+09, oseq = 1.39762e+09},{name = 'Away_c4', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},{name = 'NOW', state = true, seq = 1.39765e+09, oseq = 0},} #hooks: 0 upnp: 0 v:0xa68270/NONE duplicate:0 <0x400>
                                          06 04/16/14 7:03:57.183 Device_Variable::m_szValue_set device: 124 service: urn:dcineco-com:serviceId:MSwitch1 variable: Status8 was: 1 now: 0 #hooks: 1 upnp: 0 v:0xa8fb78/NONE duplicate:0 <0x400>
                                          06 04/16/14 7:03:57.238 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: ConditionSatisfied was: Day_c1 now: None #hooks: 2 upnp: 0 v:0xa58258/NONE duplicate:0 <0x400>
                                          07 04/16/14 7:03:57.239 Event::Evaluate 20 Garage Door #2 Left Open scene Prowl Notifications is false repeat 0/-1 <0x400>
                                          07 04/16/14 7:03:57.239 Event::Evaluate 21 Garage Door #1 Left Open scene Prowl Notifications is false repeat 0/-1 <0x400>
                                          06 04/16/14 7:03:57.240 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: LastConditionChange was: 1397646237 now: 1397646237 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x400>
                                          06 04/16/14 7:03:57.255 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicC variable: ObjectStatusMap was: {{name = 'At_Work_s1', state = true, seq = 1.39765e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = false, seq = 1.3976e+09, oseq = 1.39761e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Alarm_Disarmed_t6', state = false, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.39763e+09, oseq = 1.39765e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = true, seq = 1.39765e+09, oseq = 1.39761e+09},{name = 'Night_t9', state = true, seq = 1.39761e+09, oseq = 1.39756e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39762e+09},{name = 'First_Floor_Motion_Not_Tripped_t11', state = true, seq = 1.39765e+09, oseq = 1.39762e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = true, seq = 1.39765e+09, oseq = 1.39761e+09},{name = 'Night_c2', state = true, seq = 1.39761e+09, oseq = 1.39756e+09},{name = 'Home_c3', state = false, seq = 1.3976e+09, oseq = 1.39762e+09},{name = 'Away_c4', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},{name = 'NOW', state = true, seq = 1.39765e+09, oseq = 0},} now: {{name = 'At_Work_s1', state = true, seq = 1.39765e+09, oseq = 1.3976e+09},{name = 'Guest_Mode_On_t3', state = false, seq = 1.38616e+09, oseq = 0},{name = 'Weekend_s2', state = false, seq = 1.3973e+09, oseq = 1.39744e+09},{name = 'Sleep_Mode_On_t4', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_Mode_On_t5', state = false, seq = 0, oseq = 0},{name = 'Home_Mode_On_t1', state = false, seq = 1.3976e+09, oseq = 1.39761e+09},{name = 'Away_Mode_On_t2', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Alarm_Disarmed_t6', state = false, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Alarm_Armed_AWAY_t7', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Garage_Door_Open_c8', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Front_Door_Entry_c9', state = false, seq = 0, oseq = 0},{name = 'First_Floor_Motion_Timeout_c10', state = false, seq = 1.39763e+09, oseq = 1.39765e+09},{name = 'Garage_Door_Entry_c11', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Garage_Door_Entry_At_Night_c12', state = false, seq = 1.39726e+09, oseq = 1.39726e+09},{name = 'Day_t8', state = true, seq = 1.39765e+09, oseq = 1.39761e+09},{name = 'Night_t9', state = false, seq = 1.39761e+09, oseq = 1.39765e+09},{name = 'Front_Door_PIN_Code_Entered_t10', state = false, seq = 0, oseq = 1.39762e+09},{nam
                                          e = 'First_Floor_Motion_Not_Tripped_t11', state = true, seq = 1.39765e+09, oseq = 1.39762e+09},{name = 'Front_Door_Locked_t12', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Opened_t13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Opened_t14', state = false, seq = 1.3976e+09, oseq = 1.3976e+09},{name = 'Kitchen_Lights_Off_t15', state = true, seq = 1.39762e+09, oseq = 1.39762e+09},{name = 'Garage_Door_1_Left_Open_c13', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_2_Left_Open_c14', state = false, seq = 1.39758e+09, oseq = 1.39759e+09},{name = 'Day_c1', state = true, seq = 1.39765e+09, oseq = 1.39761e+09},{name = 'Night_c2', state = false, seq = 1.39761e+09, oseq = 1.39765e+09},{name = 'Home_c3', state = false, seq = 1.3976e+09, oseq = 1.39762e+09},{name = 'Away_c4', state = false, seq = 1.39761e+09, oseq = 1.39762e+09},{name = 'Entertain_c5', state = false, seq = 0, oseq = 0},{name = 'Sleeping_c6', state = true, seq = 1.39762e+09, oseq = 1.39756e+09},{name = 'Vacation_c7', state = false, seq = 0, oseq = 0},{name = 'Garage_Door_Open_While_Sleeping_c15', state = false, seq = 0, oseq = 0},{name = 'NOW', state = true, seq = 1.39765e+09, oseq = 0},} #hooks: 0 upnp: 0 v:0xa68270/NONE duplicate:0 <0x400>
                                          04 04/16/14 7:03:57.272 <0x400>
                                          06 04/16/14 7:03:57.274 Device_Variable::m_szValue_set device: 98 service: urn:rts-services-com:serviceId:ProgramLogicC variable: ActionsMap was: {} now: {} #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x400>
                                          08 04/16/14 7:03:57.276 JobHandler_LuaUPnP::HandleActionRequest device: 92 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x400>
                                          08 04/16/14 7:03:57.276 JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=0 <0x400>
                                          06 04/16/14 7:03:57.314 Device_Variable::m_szValue_set device: 92 service: urn:upnp-org:serviceId:SwitchPower1 variable: Target was: 1 now: 0 #hooks: 0 upnp: 0 v:0x9f7540/NONE duplicate:0 <0x400>
                                          02 04/16/14 7:03:57.316 ZWJob_SendData UPDATE MANUAL ROUTE 25=0xd30ecf <0x400>
                                          02 04/16/14 7:03:57.320 UPDATE MANUAL ROUTE2 25=0xd30ecf <0xc04>
                                          02 04/16/14 7:03:57.321 ZW_Send_Data node 25 USING ROUTE 255.101.32.50 <0xc04>
                                          08 04/16/14 7:03:57.368 JobHandler_LuaUPnP::HandleActionRequest device: 71 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x400>
                                          08 04/16/14 7:03:57.369 JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=0 <0x400>
                                          06 04/16/14 7:03:57.370 Device_Variable::m_szValue_set device: 71 service: urn:upnp-org:serviceId:SwitchPower1 variable: Target was: 1 now: 0 #hooks: 0 upnp: 0 v:0x9f7540/NONE duplicate:0 <0x400>
                                          02 04/16/14 7:03:57.372 ZWJob_SendData UPDATE MANUAL ROUTE 4=0xd25aff <0x400>
                                          04 04/16/14 7:03:57.376 <0x400>
                                          02 04/16/14 7:03:57.466 UPDATE MANUAL ROUTE2 4=0xd25aff <0xc04>
                                          02 04/16/14 7:03:57.466 ZW_Send_Data node 4 USING ROUTE 41.0.0.0 <0xc04>
                                          02 04/16/14 7:03:57.566 UPDATE MANUAL ROUTE2 25=0xd30ecf <0xc04>
                                          02 04/16/14 7:03:57.567 ZW_Send_Data node 25 USING ROUTE 255.101.32.50 <0xc04>
                                          06 04/16/14 7:03:57.661 Device_Variable::m_szValue_set device: 92 service: urn:upnp-org:serviceId:SwitchPower1 variable: Status was: 1 now: 0 #hooks: 1 upnp: 0 v:0x9f8ab8/NONE duplicate:0 <0x803>
                                          04 04/16/14 7:03:57.665 <0x803>
                                          02 04/16/14 7:03:57.669 UPDATE MANUAL ROUTE2 4=0xd25aff <0xc04>
                                          02 04/16/14 7:03:57.670 ZW_Send_Data node 4 USING ROUTE 41.0.0.0 <0xc04>
                                          06 04/16/14 7:03:57.761 Device_Variable::m_szValue_set device: 71 service: urn:upnp-org:serviceId:SwitchPower1 variable: Status was: 1 now: 0 #hooks: 1 upnp: 0 v:0x9f8ab8/NONE duplicate:0 <0x803>
                                          04 04/16/14 7:03:57.765 <0x803>
                                          02 04/16/14 7:04:13.015 ZW_Send_Data node 8 USING ROUTE 255.0.0.0 <0xc04>
                                          04 04/16/14 7:04:13.183 <0x803>
                                          02 04/16/14 7:04:43.015 ZW_Send_Data node 9 USING ROUTE 255.0.0.0 <0xc04>
                                          I have a feeling you're going to see (or not see) the same information as was in the first log from my previous post. I suspect that is the problem, however, I don't know what to attribute it to. Every other plugin works fine, including AD2USB.
