  3. Domoticz
  4. Domoticz - Temp+Humidity issue
7 Posts 5 Posters 6.5k Views 2 Watching
  • S
    stokni
    I just installed Domoticz on a PI2, connected Arduino nano with NRF24L01+ as gateway via USB and created a sensor of seperate Arduino Nano (with NRF24L01+) and Temp+Humi sensor (AM2303 /DHT22).
    Got everything to work, but have the following chart:
    Temp and Humidity sometimes drop to 0, in Serial monitor of Arduino correct values are shown.
    Had to add the device twice, but both give 0 values now and then.
    Like i said, just started with Domoticz and MySensors, And tips on how i can troubleshoot this?
    Any help is appriciated!
    Thanks.
    AWIA 1 Reply Last reply
    • alexsh1A
      alexsh1A
      alexsh1
      I have the same issue with DHT22/ds18b20 - you will have to eliminate it in your code or JSON file. I have a slightly different setup though - I use Particle Photon and JSON for temp / humidity. Have a look at my discussion of this issue on a different forum:
      https://community.particle.io/t/ds18b20-is-throwing-127c-from-time-to-time/16401/2
      I hope it helps.
      • S stokni
        Thanks.
        AWIA
        AWIA
        AWI
        @stokni can you share your sketch? It is possible that you send a null value if your sensor has a bad reading. This happened to me also. Domoticz does not create zero readings by itself.
        • N
          N
          NotYetRated
          Weird, my sensors all report just fine to Domoticz....
          • sundberg84S
            I also have DHT22 working fine with domoticz (not using ds18b20). Could it be some error in the reading and the node sends that error as 0 ? Maybe you could eliminate that in the code? Just guessing...
            • S
              stokni
              Thanks all for the reply's, i will investigate further.
              @AWI i have used the standard sketches from mysensor, without any modifications.
              • S
                stokni
                Problem seems to be solved after adding a 4.7uF capacitor to both NRF24L01 modules..
