  3. rboard - Cheap relay/radio/arduino board ~$10
57 Posts 15 Posters 34.0k Views 7 Watching
  • greglG Offline
    greglG Offline
    gregl
    What voltage are you giving the board?
    I think i recall having an issue when i was giving it just 5v... i think at 6/7v the issue went away....
    • D Dean
      lol I ended up with a board that now malfunctions sometimes :-) For some reason the relay began to turn on and off repeatedly, then it stopped working altogether, and now it seems to be working as it should... when my son was running past me the other day which lead to the board falling on the ground, it must have fixed whatever the problem is! In any case, I won't be using that relay for anything too important. I have it in my garage now; it opens and closes the garage door, has a motion sensor and tells me if someone goes into the garage, and it is also sending me the temperature outside. I am happy :-)
      So now I want to use another one of these boards to turn a light on, but I want to also have a separate switch which will operate through the board. So basically I am going to use the Garagedoor sketch mentioned above, which is the same as the "Relay with button actuator". I understand what pins I need to assign, but I am a little confused as to how I need to wire up the switch. Am I just completing a circuit, or am I supplying power as the trigger?
      R Offline
      R Offline
      RJ_Make
      @Dean So let me get this straight,, You are using that board to "opens and closes the garage door, has a motion sensor and tells me if someone goes into the garage, and it is also sending me the temperature outside . I am happy ...." and you don't consider that contrary to "I won't be using that relay for anything too important." ?
      Did I understand you correctly?
      RJ_Make
      • D Offline
        Dean
        @gregl thanks for your suggestion, that thought actually did come to mind when I was trying to troubleshoot what was going on. I had been using 4 AA batteries to power it, and they had been used for quite some time, so I ended up locating an old mobile phone charger and used that to power it. The board has been working reliably every since, but I am reluctant to use the board for anything important.
        @ServiceXp yes you heard me right :-) the board is currently doing all those things, but I'm not depending on it. My wife is home all the time, so if for some reason the relay decides to open the garage, she will hear it and close out back up. It is my first sensor, and even though it hasn't come together as well as all of you, in still proud of myself for building it, and even though it's reliability is debatable, I like the idea of keeping it running at this stage because it gives me a smile every time I open the Vera dashboard :-)
        So can anyone give me a little hand with how the actual switch part is supposed to work? Thanks in advance :-)
        R 1 Reply Last reply
        • D Dean
          R Offline
          R Offline
          RJ_Make
          wrote on last edited by RJ_Make
          #44
          @Dean Does the build make it difficult to swap out the rboard, and demote that temperamental rboard to say controlling a light? For me, I consider the garage door to be one of those more important functions.. :-)
          You will wire one side of the switch to the pin you want to use on the rboard and the other side to GND. When you initialize the pin, you need to use INPUT_PULLUP eg: pinMode(buttonPin, INPUT_PULLUP)
          http://arduino.cc/en/Reference/pinMode
          Hope that helps...
          RJ_Make
          D 1 Reply Last reply
          • R RJ_Make
            Hope that helps...
            Dean
            You will wire one side of the switch to the pin you want to use on the rboard and the other switch to GND. When you initialize the pin, you need to use INPUT_PULLUP eg: pinMode(buttonPin, INPUT_PULLUP)
            Hope that helps...
            Hi @ServiceXp , that is the exact info I was after! Thank you very much :-)
            At present the build is just the board, radio and motion sensor all just wired up and sitting above the lightswitch in the garage. For me it was kind of a test to see if I could do this. Like I said, my wife is home all the time so there is no way the garage door will open without someone knowing. If the board keeps working as it is presently, then I'll feel more confident in using the board again somewhere else. But so far it is working very well, which I am very pleased about :-) But you're right, keeping a garage secure is something that is usually pretty important, the other thing is that there is no internal access into our home, so between that and my wife being home, personally I am ok with the present arrangement.
            Thanks again for your help!
            • G Offline
              G Offline
              gadu
              Cool, this one is also interesting!
              http://imall.iteadstudio.com/im120618001.html
              • G gadu
                Dean
                I agree... I placed an order with them last and it arrived yesterday. I bought a few items including a couple more Mini Rboards, but I also bought what you linked. Not sure what I will do with it, but at that price I couldn't say no. :-)
                • greglG Offline
                  greglG Offline
                  gregl
                  ive had an rboard in production with mysensors for 6 months or so.... it hasnt missed a beat and caused me absolutely no issues!!!
                  • E Offline
                    E Offline
                    epierre
                    wrote on last edited by epierre
                    #49
                    @gregl I wanted to try mine, but it seems it doesn't commute, have you a test script ?
                    When I send the order:
                    echo "9;0;1;1;2;1" >> /dev/ttyUSB0
                    I see on the debug:
                    read: 0-0-9 s=0,c=1,t=2,pt=0,l=1:1
                    send: 9-9-0-0 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                    Incoming change for sensor:0, New status: 1
                    But I don't hear the relay commute nor mesure a conductivity on the relay limits.
                    any hint ?
                    z-wave - Vera -> Domoticz
                    • greglG Offline
                      greglG Offline
                      gregl
                      You may not have enough power to drive the relay...five it at least 6v
                      . ...or the Wong pin in your sketch.
                      • E Offline
                        E Offline
                        epierre
                        @gregl right this was linked to a powering issue.
                        :~$ echo "9;1;1;1;2;1" >> /dev/ttyUSB0
                        :~$ echo "9;1;1;1;2;0" >> /dev/ttyUSB0
                        what is strange is that it is the sensor 1 and not the 0, but the way the demo code is you have to do that...
                        digitalWrite(message.sensor-1+RELAY_1,
                        @hek sending a message would be good in http://www.mysensors.org/download/serial_api_14 in § serial communication example, it is missing...
                        • HomerH Offline
                          HomerH Offline
                          Homer
                          Sorry about bumping an old thread...
                          I am using one of these boards to make a relay and temp sensor. I am trying to use Gregl's example that is linked here and stored on Codebender. For the record, here it is:
                          //This is Motion/Door & Temp Sensor with Relay
                          //Hardware is Mini RBoard ftp://imall.iteadstudio.com/Mainboard/IM140704001_mini_Rboard/SCH_IM140704001_MiniRboard.pdf
                          #include <OneWire.h>
                          char sketch_name[] = "Multi Sensor";
                          char sketch_ver[]  = "2014.11.15r1";
                          #define MySensorTESTBED 0
                          #if MySensorTESTBED == 1
                          #define CLIENT_ID 9  // Sets MYSensors client id
                          #define RADIO_CH 96  // Sets MYSensors to use Radio Channel 96
                          #define RELAY 4   // Set 4 for mini rboard
                          #define TRIGGER	3	// On Mini Rboard there is D3 (Interupt 1) available on the RX Module pins
                          #if MySensorTESTBED == 0
                          #define CLIENT_ID AUTO  // Sets MYSensors client id
                          #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
                          //Temp Sensor bits
                          #define ONE_WIRE_BUS 14 // Pin where dallas sensor is connected - on Rboard this is A0(D14)
                          OneWire oneWire(ONE_WIRE_BUS);
                          DallasTemperature DallasSensors(&oneWire);
                          float lastTemperature ;
                          #define CHILD_ID_T1 3 //CHILD ID for relay
                          //Relay Output bits
                          #define RELAY_ON 0  // GPIO value to write to turn on attached relay
                          #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
                          #define CHILD_ID_R1 1 //CHILD ID for relay
                          //Trigger Sensor Bits
                          #define CHILD_ID_S1 2 //CHILD ID for Reed/Motion sensor
                          boolean lastTripped = 0;
                          MyMessage triggerMsg(CHILD_ID_S1,V_TRIPPED);
                          MyMessage relayMsg(CHILD_ID_R1,V_LIGHT);
                          MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
                          	// Startup OneWire Temp Sensors
                          	DallasSensors.begin();
                          	gw.begin(incomingMessage, CLIENT_ID , false,AUTO,RF24_PA_MAX,RADIO_CH,RF24_250KBPS);
                          	gw.sendSketchInfo(sketch_name, sketch_ver);
                          	gw.present(CHILD_ID_R1, S_LIGHT);
                          	gw.present(CHILD_ID_T1, S_TEMP);
                          	gw.present(CHILD_ID_S1, S_MOTION);
                          	pinMode(RELAY, OUTPUT);
                          	pinMode(TRIGGER,INPUT_PULLUP);
                          	//Ensure relay is off
                          	digitalWrite(RELAY,RELAY_OFF); //turn relay off
                          	gw.process();
                          	// Check for motion change value
                          		boolean tripped = digitalRead(TRIGGER) == HIGH;
                          		if (lastTripped != tripped ) {
                          			gw.send(triggerMsg.set(tripped?"1":"0")); // Send new state and request ack back
                          			Serial.println("Tripped");
                          			lastTripped=tripped;
                          		DallasSensors.requestTemperatures();
                          		float tempC = DallasSensors.getTempCByIndex(1);
                          		if (lastTemperature != tempC && tempC != -127.00) {
                          			gw.send(tempMsg.set(tempC,1));
                          			lastTemperature=tempC;
                          	if (message.type==V_LIGHT && !(message.isAck()) ) { // look for messages for the relay and that are not ACK messages
                          		// Change relay state
                          		digitalWrite(RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
                          		Serial.print(message.sensor);
                          Just as the code stands, when I try to compile it, I get an error. First I got one because the Mysensors library had the last letter 's' missing, but even after I make that correction I can't get it to compile. This is the error that I get:
                          Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
                          WARNING: Spurious .ci folder in 'MySensors' library
                          WARNING: Spurious .mystools folder in 'MySensors' library
                          In file included from C:\Users\Dean\Documents\Arduino\testingagain\testingagain.ino:7:0:
                          C:\Users\Dean\Documents\Arduino\libraries\MySensors/MySensors.h:405:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                          Multiple libraries were found for "MySensors.h"
                          Used: C:\Users\Dean\Documents\Arduino\libraries\MySensors
                          Not used: C:\Users\Dean\Documents\Arduino\libraries\MySensors-2.3.1
                          Multiple libraries were found for "DallasTemperature.h"
                          Used: C:\Users\Dean\Documents\Arduino\libraries\DallasTemperature
                          Not used: C:\Users\Dean\Documents\Arduino\libraries\MAX31850_DallasTemp
                          exit status 1
                          Error compiling for board Arduino Duemilanove or Diecimila.
                          option enabled in File -> Preferences.
                          I really don't know where to go to from here, because all I have done is tried to compile a working sketch so it should work, shouldn't it?
                          Keen to hear back from someone who knows a lot more about this stuff than me! Thanks
                          • HomerH Homer
                            //Temp Sensor bits
                            //Relay Output bits
                            	gw.process();
                            exit status 1
                            mfalkviddM Online
                            mfalkviddM Online
                            @homer that sketch was made for MySensors 1.x and needs to be converted to work for MySensors 2.x.
                            Followthe guide at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x to convert it.
                            Alternatively, remove MySensors 2 and install MySensors 1 instead.
                            HomerH 1 Reply Last reply
                              HomerH Offline
                              HomerH Offline
                              Homer
                              @mfalkvidd said in rboard - Cheap relay/radio/arduino board ~$10:
                              Thanks mate! I was thinking something like that might be the case, but I didn't know for sure.
                              Thank you so much for pointing me in the right direction!!
                              • HomerH Offline
                                HomerH Offline
                                Homer
                                I just wanted to say that I managed to upload a sketch and I have it working!
                                I attempted to change the code so it was compatible but I gave that up and decided to merge two sketches. It was good fun, and I enjoyed learning!
                                • alowhumA Offline
                                  alowhumA Offline
                                  alowhum
                                  Could you share the sketch? Perhaps others will learn from it too?
                                  • alowhumA alowhum
                                    HomerH Offline
                                    HomerH Offline
                                    Homer
                                    #57
                                    @alowhum said in rboard - Cheap relay/radio/arduino board ~$10:
                                    Great idea! :relaxed:
                                    Here it is
                                    // Setup Relay bits
                                    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    // Setup Temperature bits
                                    #define ONE_WIRE_BUS 14 // Pin where dallase sensor is connected
                                    int numSensors = 0;
                                    bool receivedConfig = false;
                                    bool metric = true;
                                    MyMessage tempMsg(0, V_TEMP);
                                    void before()
                                      for (int sensor = 1, pin = RELAY_PIN; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                                        pinMode(pin, OUTPUT);
                                        digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
                                      sensors.begin();
                                      sendSketchInfo("Temp and Relay", "1.0");
                                      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                                        present(i, S_TEMP);
                                          present(sensor, S_BINARY);
                                      wait(conversionTime);
                                        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                    #if COMPARE_TEMP == 1
                                    #else
                                          send(tempMsg.setSensor(i).set(temperature, 1));
                                          lastTemperature[i] = temperature;
                                      wait(SLEEP_TIME);
                                        digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
                                        // Store state in eeprom
                                        // Write some debug info
