  3. Find parent - hardware or software issue?
7 Posts 3 Posters 3.3k Views 1 Watching
  • M Offline
    M Offline
    Marco van Noord
    I've recently started playing with the MySensor library. I ordered some NRF modules and connected them to an arduino Nano 3.3v and an arduino Uno.
    However, i don't seem to get anything working. I've tried pinging each other with a RF24 library (pingpair example from the RF24 lib), and that seems to work. That would mean that the modules aren't completely broken or misconnected(right?)
    When i upload PingPongSensor to both devices, it boots up and tells me "find parent". Same thing when i upload SerialGateway to one arduino and a sensor (MockMySensors or anything else).
    Could someone guide me in the right direction? I've added 10uF to the power lines to rule out power issues. I've got the
    http://forum.mysensors.org/uploads/files/1427268777747-1427268738276-453722785.jpg modules, which others point out are NRF24l01(without the +). Could this be the issue?
    D 1 Reply Last reply
    • M Marco van Noord
      Dwalt
      @Marco-van-Noord Are you using a controller? 'Find parent' is the Arduino looking for an ID from a controller.
      • M Offline
        M Offline
        Marco van Noord
        I am not using a controller, but am i correct that even without a controller i should at least see some output on the serial port of the gateway when another device starts up?
        I''m using MYSController to see the messages that the gateway sends and receives, but whenever i restart a sensor, i do not get any new messages, is this correct?
        R 1 Reply Last reply
        • M Marco van Noord
          R Offline
          R Offline
          rvendrame
          Yes
          No
          What the node shows on serial monitor during startup?
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          M 1 Reply Last reply
          • M Offline
            M Offline
            Marco van Noord
            I think thanks to your reply i got it working, i thought it would receive the parent_id from the gateway, not the controller. However, i still expected communication from the sensor, requesting a parent (which doesn't happen, so i'm still at a loss there).
            Either way, using
            gw.begin(incomingMessage,254,false,0);
            I made the sensor skip finding the parent( is this smart?)
            If i set the nodeId to AUTO, it also doesn't receive a nodeId from the gateway, shouldn't that hand out the id's?
            • R rvendrame
              Yes
              No
              M Offline
              M Offline
              Marco van Noord
              Yes
              No
              When i use one of the standard sketches(like the mockMySensor sketch) the serial debug just says "find parent", nothing else.
              • R Offline
                R Offline
                rvendrame
                The controller is responsible to handle NodeIDs. If you don't have a controller, you must hardcode sensorIDs at the gw.begin, like you did. Gateway is node 0 and nodes should have different IDs ranging from 1 to 254.
                Once you do like that, you should see your gateway receiving data from nodes.
                Alexa / Google Home
