  3. [SOLVED] Compile error for ESP8266 Wifi Gateway
6 Posts 2 Posters 7.8k Views 1 Watching
  • ATXCoderA Offline
    ATXCoderA Offline
    ATXCoder
    wrote on last edited by ATXCoder
    Trying to get the WiFI Gateway (http://www.mysensors.org/build/esp8266_gateway) built but I keep getting the following error message when trying to compile the code:
    Arduino: 1.6.5 (Windows 8.1), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Serial, 115200, 4M (3M SPIFFS)"
    In file included from C:\Users\Thomas\Documents\Arduino\libraries\MySensors\MyGateway.cpp:13:0:
    C:\Users\Thomas\Documents\Arduino\libraries\MySensors\utility/MsTimer2.h:7:2: error: #error MsTimer2 library only works on AVR architecture
    In file included from C:\Users\Thomas\Documents\Arduino\libraries\MySensors\MyGateway.cpp:14:0:
    C:\Users\Thomas\Documents\Arduino\libraries\MySensors\utility/PinChangeInt.h:103:19: fatal error: new.h: No such file or directory
       #include <new.h>
    compilation terminated.
    Error compiling.
      enabled in File > Preferences.
    Curious if anyone has seen this issue before or have any ideas on how to fix it (honestly not even sure what it means, still kind of new to all this).
    OS: Windows 8.1
    IDE: Arduino 1.6.5
    ESP8266 Board: NodeMcu Lua ESP8266 ESP-12E (www.banggood.com/NodeMcu-Lua-ESP-12E-WIFI-Development-Board-p-985891.html)
    • Y Offline
      Y Offline
      Apparently the compiler is compiling for AVR (e.g. Arduino UNO) instead of ESP.
      Top line of your output however shows "Board: "NodeMCU 1.0 ..." Strange...
      Which MySensors branch/version do you use?
      You could try compiling using the suggestion:
      Maybe that output would help.
      ATXCoderA 1 Reply Last reply
      • Y Yveaux
        ATXCoderA Offline
        ATXCoderA Offline
        ATXCoder
        @Yveaux I tried both the 1.5 and Development MySensor libraries. I have re-downloaded the 1.5 MySenors Library and unzipped it into my sketchbook location. Yet I still get the same error. I have included the error report with verbose on
        Using library EEPROM in folder: C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM
        Using library SPI in folder: C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI
        Using library ESP8266WiFi in folder: C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi
        Using library MySensors in folder: C:\Users\Thomas\Documents\Arduino\libraries\MySensors
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\GatewayESP8266MQTTClient.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\GatewayESP8266MQTTClient.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM\utility C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM\EEPROM.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\EEPROM\EEPROM.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI\utility C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI\SPI.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\SPI\SPI.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\ESP8266WiFi\ESP8266WiFi.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src\WiFiClient.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\ESP8266WiFi\WiFiClient.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src\WiFiClientSecure.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\ESP8266WiFi\WiFiClientSecure.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src\WiFiServer.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\ESP8266WiFi\WiFiServer.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src\WiFiUdp.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\ESP8266WiFi\WiFiUdp.cpp.o
        C:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0/tools/sdk/include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\cores\esp8266 -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\variants\nodemcu -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\EEPROM -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\SPI -IC:\Users\Thomas\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WiFi\src -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors -IC:\Users\Thomas\Documents\Arduino\libraries\MySensors\utility C:\Users\Thomas\Documents\Arduino\libraries\MySensors\MyGateway.cpp -o C:\Users\Thomas\AppData\Local\Temp\build2217209677853778315.tmp\MySensors\MyGateway.cpp.o
           #include <new.h>
        Error compiling.
        Y 1 Reply Last reply
        • ATXCoderA ATXCoder
             #include <new.h>
          Error compiling.
          Y Offline
          Y Offline
          @ATXCoder Well, from this log it is at least clear that the xtensa toolchain for ESP8266 is in use, so that is correct.
          Did you try with a clean skets & library directort, except for the mysensors library?
          Other than that, I don't have a clue... Maybe @hek has seen this before?
          • Y Yveaux
            ATXCoderA Offline
            ATXCoderA Offline
            ATXCoder
            @Yveaux I switched to a different network, re-downloaded the 1.5 Library, erased everything in my sketchbook and library diretory, unzipped the 1.5 MySensor Library into my sketchbook direcctory and now it complies.
            So either it was my network connection flaking out and causing a corrupt download or I just had to completely wipe my sketchbook directory. In either case, thanks for the help!
              Y Offline
              Y Offline
              Don't think so; it didn't compile, so it didn't even get to download.
              Anyway, glad you fixed it!
