  3. Wake up NRF24 from sleeping
7 Posts 3 Posters 4.2k Views 1 Watching
  • S
    Spezialtrick
    Hello Guys,
    how can i wake up the NRF24 from sleeping mode without sending a message?
      Pin Interrupt or timer.
      • S
        Spezialtrick
        Thats my sketch:
        #include <MySigningNone.h>
        #include <MyTransportNRF24.h>
        #include <MyTransportRFM69.h>
        #include <MyHwATMega328.h>
        MyHwATMega328 hw;
        MySensor gw(radio, hw);
        unsigned long AWAKE_TIME = 20000; // Sleep time (in milliseconds)
        unsigned long SLEEP_TIME = 7000; // Sleep time (in milliseconds)
          gw.sendSketchInfo("Relay", "1.0");
          // Fetch relay status
            gw.present(sensor, S_LIGHT);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          gw.process();
          Serial.print(" Awake for "); Serial.print(AWAKE_TIME); Serial.print(" ms");
          delay(AWAKE_TIME);
          Serial.print(" Sleeping for "); Serial.print(SLEEP_TIME); Serial.print(" ms");
          gw.sleep(SLEEP_TIME); //sleep a bit
          if (message.type==V_LIGHT) {
             // Change relay state
             // Store state in eeprom
             // Write some debug info
             Serial.print(message.sensor);
        In my eyes the NRF24 doesn't wake up, because i can't send messages to the node.
        It also just uses 3,8 mA, when it's awoken.
          Please read about the sleep function in the API on the main site.
          • S
            Spezialtrick
            wrote on last edited by Spezialtrick
            I already did, but i can't find the mistake. :(
            It's for an LED candle.
            Is the mistake in here?
            • S
              Spezialtrick
              This post is deleted!
                As hek says, read the API documentation.
                "Waiting using the Arduino delay() command is not a good idea. It halts all MySensors processing and should be avoided. Instead you should use the provided wait function which calls process() while waiting."
                Exchange delay with gw.wait and you should be fine
