  3. Wake up NRF24 from sleeping
7 Posts 3 Posters 4.0k Views 1 Watching
  • S Offline
    Spezialtrick
    Hello Guys,
    how can i wake up the NRF24 from sleeping mode without sending a message?
    • H Offline
      H Offline
      Pin Interrupt or timer.
      • S Offline
        Spezialtrick
        Thats my sketch:
        #include <MySigningNone.h>
        #include <MyTransportNRF24.h>
        #include <MyTransportRFM69.h>
        #include <MyHwATMega328.h>
        MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
        MyHwATMega328 hw;
        MySensor gw(radio, hw);
        unsigned long AWAKE_TIME = 20000; // Sleep time (in milliseconds)
        unsigned long SLEEP_TIME = 7000; // Sleep time (in milliseconds)
          gw.sendSketchInfo("Relay", "1.0");
          // Fetch relay status
            gw.present(sensor, S_LIGHT);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          Serial.print(" Awake for "); Serial.print(AWAKE_TIME); Serial.print(" ms");
          delay(AWAKE_TIME);
          Serial.print(" Sleeping for "); Serial.print(SLEEP_TIME); Serial.print(" ms");
          if (message.type==V_LIGHT) {
             // Change relay state
             // Store state in eeprom
        In my eyes the NRF24 doesn't wake up, because i can't send messages to the node.
        It also just uses 3,8 mA, when it's awoken.
        • H Offline
          H Offline
          Please read about the sleep function in the API on the main site.
          • S Offline
            Spezialtrick
            wrote on last edited by Spezialtrick
            I already did, but i can't find the mistake. :(
            It's for an LED candle.
            Is the mistake in here?
            • S Offline
              Spezialtrick
              • mfalkviddM Offline
                As hek says, read the API documentation.
                "Waiting using the Arduino delay() command is not a good idea. It halts all MySensors processing and should be avoided. Instead you should use the provided wait function which calls process() while waiting."
                Exchange delay with gw.wait and you should be fine
                12.2k
